Question about Radio Communications
Uniden zachary t meter adjust - Radio Communications
2 Suggested Answers
Mister 44
  • 35 Answers
SOURCE: Uniden Zachary t no recieve audio
Probably a broken lead on the mic plug.
Posted on Apr 12, 2010
Adjusted mag mount antenna w/a swr meter. When checked it w/the meter on the '06 uniden pc78 elite, ch 40 was a lot higher. Which is correct ?
The coax jumpers between the meter and the radio can change the SWR a little bit. It is very unlikely the the antenna can be that low on 1 and 40. Set it for the lowest on 20 via the radio and as long as you are under a 2 on 1 and 40 then it should be OK.
Oct 10, 2016 | Uniden Radio Communications
How do i adjust the dead key in a uniden pc78ltw
L14,L13,and L12 . You should have a watt meter to watch the power go up or down. If it goes up turn them the other way. turn each one a little bit at a time so as not to overdo it.
Oct 01, 2014 | Uniden Radio Communications
Frequency is off on my Zachary t
you will need a frequency counter and a multi meter.
Jan 28, 2013 | Uniden Radio Communications
I have a president zachary t base station cb radio that squeals on ac power. what can i do to stop it
Hi coonhunter,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
Could I ask you to re-post, your question falls under something
different. I have BASE is that correct?
Jan 02, 2011 | Uniden PC78ELITE 40-Channels Base CB Radio
Best modulation for PC68XL
Most Cobra / Unidens are easy by clipping D9. On this one D9 and L19. Just turn up L19 to top. Clip D9 diode. spread coils 1/16" inch. Also use 100uf capacitor (-) toward final across JUMPER staple near Final Transistor in back. Use meter(adjust to best swing) spread back coils,remove L10,L20 slugs or adjust them to top. The only radio that clips different than D9 is Cobra 29Ltd (D11) or Uniden pro510xl(D14).
Oct 08, 2010 | Uniden PC68XL (40 Channels) 2-Way Radio
Sep 28, 2009 | Uniden Radio Communications
Hello i have a Uniden GMR-325 (7 Channels) Two Way Radio that....
Hi Zachary
I predict that you have trouble with only one unit.
Try to find some one with either the same units ( on same Frequency of course) or a receiver that also covers same Frequency and transmit on one GMR then the other to esablish which unit is faulty!
The faulty unit should then become apparent, the buzzing could be caused by transmisson of the faulty unit, check all Antenna connections, even change antennas over on testing as prescribed above,
good luck John.
Apr 05, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Uniden UH-013 squelch
Had an issue with this unit since new. Squelch adjusted too high. Not hearing some signals showing on meter. Solution - find a trim pot labelled "Meter" on the PC board and adjust it like a knobby squelch control. Made a big difference to the number of received stations. Down side is I need to use SQT tight squelch sometimes.
Feb 20, 2009 | Radio Communications
PRESIDENT ZACHARY WITH LOW RECEIVE
adjust the squeelch tuning, the antena is also a factor and the location, the main receive gain adjustment is inside the unit, rf transformer inside the unit in the receive stage of the circuit.
Dec 10, 2008 | Radio Shack TRC-447 CB Radio
Radio Communications Logo
27 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
