Question about Canon Cameras
I took a series of photos on my EOS 10D and checked them before shutting the camera down. A few minutes later when I turned the camera on I found the images had disappeared. I have retrieved them using a recovery program but I'd really like to know what I am doing to have this happen.
  • winterat Oct 23, 2008
    Thanks for that. This has been an ongoing problem, but only occasional. The card has been reformatted after each incident and then a week or two and it happens again.
    I chucked away a512meg card, thinking that it was acard problem. Bought a 1 gig card and the same thing happened, so must be something to do with the camera. I just wonder whether it's repairable.
    Brigadier General:
  • 6,966 Answers
Think of the camera as a smaller brother of your PC. When you checked the series of photos, you were actually accessing the memory storage. The built-in processor of the camera was still reading them, sorting them, cataloging then and other housekeeping functions when power was cutoff. Assuming that by series, you mean a good number of photos, then the camera has not yet finished all of these when you powered off. This in effect is like powering off your PC without exiting properly. Having said this, then it is most likely that the "table of contents" was corrupted. This would explain why you were able to recover the photos but the camera was not able to list them. Again just like a computer storage, all that is required is to format the storage medium be it internal memory or an add-on/extension memeory card.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 23, 2008
    Sergeant:
  • 154 Answers
Please do a full format of the memory card
that is enough to solve this problem
  • 1 more comment
  • santha ram
    santha ram Oct 23, 2008
    i would suggest you to do a low level format of the memory card and then take the photos and then switch off the camera and then again turn it ON.
    this will clear all the errors in the memory card.
  • santha ram
    oh.
    if so try a different memory card borrowed from your friend. just to make sire the problem is with the memory card or the camera.
    i think the problem likes with the memory card only.
    lets check it out. please post back with the results.
  • santha ram
    oh.. may be a firmware update is needed. else the camera firmware needs to be reinstalled.
    first of all try to update the firmware.
    if that does not solve then take it to a service center and do a repair estimate.
    this will help.
    thank you
Canon camera help
  • everytime you backed up your data / photos just have your memory card re-format and observe if this would still be an issue .
Aug 21, 2014 | Canon EOS 60D Digital Camera
Battery door
To purchase a battery door for your D10, go to eBay and search for "10D battery door." You will see several for sale and they run around $7.00.
Hope that helps,
BAX
Jan 07, 2014 | Canon EOS 10D 35mm SLR Camera
Where can I download Canon DS 6031 drive?
Canon has removed the 10D drivers from their web site due to incompatibility with Windows 7 and Windows 10. Your best bet is to purchase a separate CF card reader and use that to download your photos.
Hope that helps,
BAX
Nov 22, 2010 | Canon EOS 10D 35mm SLR Camera
Dropped canon rebel eos
Try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on. Let me know what happened.
Dec 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have a canon ds6031 eos 10d. When I turn the camera on the view screen does not show what your pointing at. Is this normal?
Yes, it is normal. This is a reasonably old DSLR, and it's designed for you to look through the viewfinder (it's more accurate anyway as it's looking through the lens). You'll find if you keep one hand under the lens and one hand on the shutter, it'll feel quite comfortable to look through the viewfinder.
You can still view photos you've taken after you've taken them though.
Aug 31, 2009 | Canon EOS 10D 35mm SLR Camera
Need a canon 10 d manual
Manual for EOS 10D PLS RATE ME FIXYA FOR HELP
http://gdlp01.c-wss.com/gds/0900000229/EOS10DIM-EN.pdf
all downloads for EOS 10D
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=325&modelid=8772
Apr 03, 2009 | Canon EOS 10D 35mm SLR Camera
Canon EOS 10D Shutter getting in the way on fast shutter speeds
Only Canon Technical Support will came to your rescue here
Jul 21, 2007 | Canon EOS-10D Digital Camera
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
