Question about ASUS P5KPL-AM SE Motherboard
Blue screen my PC screen is blue i also checked my monitor its working fine wht is the problem and audio is also not working
  • Arshad Ayoob
    Arshad Ayoob Feb 10, 2012
    i have done this but when i use graphic card it works perfectly is this VGA port problem
  • Brian Sullivan
    Brian Sullivan Feb 10, 2012
    how are you running/using your graphics card it will be running when your computer is running
  • ASUS Master
  • 27,725 Answers
Is this happening all of the time or when your computer is running??
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty
computers need power and data to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
if you need more help with this post a reply
hope this helps you
Posted on Feb 09, 2012
  • Brian Sullivan
    your graphics card should/will be used all the time your computer is running
    if your computer came with a motherboard disc the sound drivers could be on it
    click start control panel administrive tools computer management device manager
    scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
    if you dont have a disk with the drivers you will have to download them
My asus 501 j has no display on its own monitor but works fine when attached to an external monitor
Check on the keyboard on most laptops if you hold down the fn key (function key usually blue writing) & then look for another key (blue writing) that may look like two monitors that will turn on or off the screen if that does not work your screen may be broken
Jan 24, 2013 | ASUS Eee PC 4GB Notebook
Have A Samsung 940Bw connected via DVI connection and has worked fine for last 3 years. Monitor was on and working fine went out of room and came back to black screen and the blue light flashing on the...
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | Samsung Syncmaster 940BW LCD Monitor
Audiovox PVS69701 Dual Screen DVD player monitor has blue screen
I had the same problem, and it seems to be a short in the video cable between the two monitors. I can bend my cable until i see the second screen and then tuck it under the headrest. I am currently looking for a replacement cable. I see it at 1800customersupport.com, but will also check the local radioshack since I need it quickly.
Jul 30, 2010 | Audiovox PVS72901 Portable DVD Player
No sound
if you have external speakers for your pc make sure they work first. next take the audio cable that came with the monitor , and plug the blue end of audio jack into the back of monitor. the other end is green , that plugs into your audio out of your computer which is green. if it still does not work , you need to check to make sure your volume is set correctly in windows , linux or mac os. win xp go to start button , control panel , sounds speech and audio devices. next adjust the system volume , make sure device volume is all the way set and that mute box is not checked. if you have other operating system the same method applies , just different process of getting there.
Feb 04, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
Blue lines on dell lap top inspiron
Check whether blue lines are present in bios screen, if Present then Hardware issue
If Blue line not present in bios screen, Software issue = Restore system back to factory settings
Connect External Monitor, use Fn + F8 to extend display on external Monitor ,
if display is fine on Ext Monitor = Replace LCD Kit
if Blue lines are displayed, on Ext Monitor = Replace Motherboard
Jan 09, 2010 | Dell Computers & Internet
Tower powers up great,but monitor has no signal
1st if the monitor light is yello and as soon as u switch on the comp,or if the monitor goes to sleep even though u ave checked the connection wht u need to do is u need to reset the graphic card if u ave a add on card and then clean the slot check for any damage or moisture and then put it back and reboot.i m working for hp ave got lots of those cases
'2nd wht u can do is press space bar and slightly tap the power button of comp seeif tht helps.let me know wht happened and in detail
Aug 25, 2009 | Compaq Presario 5000 PC Desktop
Power on - blank (black) screen
Disconnect the monitor signal cable from PC and switch on your monitor. It should show some logo with Red, Green and Blue colors with a message similar to "No signal". If so, your monitor is working fine. Sometimes if the brightness and contrast is set to zero using controls present in the monitor, it will not show up anything. check wheather somebody set your monitor brightness and contrast to zero. If so incease them. As a last try connect to different PC and check before approaching a service center. I hope this will help you out. :)
Aug 21, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My gateway fpd1975w tft lcd monitor does not work. the power button just flashes blue and nothing comes on. i put an old monitor to my computer and it worked fine, and i hooked my monitor up to an old...
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
Jul 05, 2009 | Gateway FPD1975W 19" LCD Monitor
Dell monitor not working
just try running the Test on the monitor(monitor self test) ie disconnecting the video cable of the monitor & leaving the power cable connected & then see if u r getting the red,blue,green multicoloured bard moving on the screen or not,if yes then the monitor is fine otherwise the monitor is bad.
Apr 02, 2009 | Dell Dimension 8400 PC Desktop
Monitor changing colors hpvs 15
Try the monitor with a different computer. If it work, then the problem is the other PC, if it does not work, then your monitor is failing.
good luck
Dec 13, 2008 | HP vs15 15"LCD Flat Panel Monitor
ASUS P5KPL-AM SE Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
