Question about Yamaha RXV-350 Receiver
YAMAHA RXV 350 Right Speaker not Working
The Right Front Speaker does not work. All other Channel/Speakers work fine. If i raise the volume to the maximum level I could hear the sound faintly. I have tried below trouble shooting; 1. Interchange speakers 2. A/B button for switching channels 3. Reset 4. Unplug and wait for 4 hours and restart Nothing seems to work. Looking for solutions.
  • ajitsank
    ajitsank Feb 09, 2012
    One more observation, to demonstrate the issue to one of my friend I reconnected the amplifier and tried the self test on speaker, surprising this time the front right speaker worked and the problem was with the right surround speakers (rear speaker). Switching on and off again I find now the problem was rectified itself on the right rear surround sound speaker and the problems has moved to center speaker. Thus the problem has now ended up in the front center speaker. There is feeble sound from the center speaker, rest all speakers seems to be working fine. I am going nuts.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 119 Answers
The amplifier for this channel is NOT working.
Posted on Mar 05, 2015
techman
  • 3130 Answers
SOURCE: Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Posted on Sep 22, 2006
maklean
  • 1665 Answers
SOURCE: Left front main speaker level drops after being on for a few hours
Volume Potensiometer may need dismantle and clean with special solvent
Posted on Jul 05, 2008
kevin000
  • 1847 Answers
Run the speaker test mode :
While running the speaker test tone to balance your speakers, you cannot adjust the balance of the Main speakers independently. The speaker test allows you to balance the sound (dB) levels of the Center speaker, Rear Left, Rear Right speakers to match the level of the main speakers. So, the first thing you do is press the [TEST] button on the remote. Next, adjust the [MASTER VOLUME CONTROL] until you can adequately hear the level from the main left and right speakers. Then, as the tone travels clockwise to each speaker, listen carefully from your main seating position in the room to determine which speakers (if any) need to be adjusted in level (either up or down) in order to balanced the sound to the main speakers output. Then adjust the Center, Rear Left or Rear Right speakers accordingly until the proper balance of level is attained. If you would like to change the level between the mains, you can use the [BALANCE CONTROL] either located on the front panel of the receiver or in the Set-Menu. A common challenge people have is that they try to adjust the main speakers to match the center or rear levels. If your center speaker is louder than your mains, You cannot adjust the main level up, you need to adjust the center speaker level down. All speakers need to be adjusted to match the main level.
killer_clown
  • 86 Answers
SOURCE: Yamaha RX-V870 receiver front right channel not working
There is a fuse in side the system you could try but that sounds like the channels is shorted, but yet again there could be a fuse for it
Posted on Nov 09, 2008
welcomejee
  • 10594 Answers
SOURCE: Main speakers A and B not working...
Please preform Test Tone check and adjust front speaker level that seems very low.
Posted on Feb 20, 2009
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
Yamaha RXV-730 6.1 Channel A/V Receiver
the clicking may have been coming from the relay itself, but it doesn't simply mean that the relay is faulty. clicking may also be caused by transformers, indicating that some electronic components have developed SHORT CIRCUIT. try measuring resistance of transistors and diodes near the power unit (unplug/turn the unit OFF of course) check also for the impedance of the output power transformers.
check the amplifier IC for short also.
Feb 29, 2008 | Yamaha RX-V730 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Yamaha rx 530 center channel cuts out
Thanks for all the suggestions guys.
I've tried using the balance for left and right speakers, and when the receiver is acting up with the right speaker having a low volume, I tried moving the balance all the way over to the right speaker. The right speaker volume will not increase in volume but the left speaker will decrease in volume.
Just to clarify, the center and the rear speakers are balanced. The issue only happens sometimes when I first power on the receiver I will have no center channel. If I leave everything alone for a few mins, the center channel will come on.
So it seems to me that something one the receiver is going. The question is, can anyone suggest a physical repair for the receiver for these symptoms?
Thanks
Jul 20, 2012 | Yamaha RX-V530 Receiver
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
I have a yamaha RX-V461B AV receiver. I cannot get the the right front speaker channel to work. All the surround and center speakers work. Even when I run the speaker test, no static comes out from that...
There is no setting that would choose one front speaker to work differently than the other. The amp or something in the audio path within the receiver is failing.
Aug 25, 2011 | Yamaha HTR-6030 Receiver
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Pushing 4 ohm speaker systems
Officially this receiver supports only 6 and 8 ohm speakers. But for surround speakers it should not do any harm, because they are not played at full volume. But be sure to set yamaha for 6 ohm speakers.
Using only 4 ohm speakers makes the amplifier work more hard and produce more heat, that's why you can't use it at high volume.
Nov 30, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha rxv 595 receiver shuts down when volume is increased
THE SPEAKER WIRES ARE REVERSED.... On the receiver the red side is always positive and black is always negative.
change + to - or
change - to + on one or more speakers.
positive side--------------------negative side
red --------------------------------black wire
gold wirew/silver--------------silver wirew/gold
white lined----------------------non-white lined
Oct 30, 2008 | Yamaha HTR-5730 Receiver
Yamaha RXV-350 Receiver Logo
127 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
