Question about Brother HL 5250DN Laser Printer
Brother printer Drum problem
After changing the printer cartridge also showing the drum problem.
  • 1 more comment
  • gerame Oct 24, 2008
    I also have the same problem. Purchased the printer about a year ago new. After we changed the first cartridge the orange/yellow light flashed drum.
    Did you get any solution for this yet?
  • jon1731 Nov 17, 2008
    Yeap! Me too! It was all going so well... the drum light started flashing and we couldn't print. We even forked out for a new drum but it still doesn't work!
  • seziriak Nov 25, 2008
    We just replaced the drum and the light continues to flash. Printer worked great for the first year then it's not worked since.
    Problem Solver:
  • 7 Answers
Did you reset after changing the Drum? This is how to do it:
Switch Printer on, after warmup open the front cover. Now press the Blue Go button and keep it pressed. Wait as follows befor releasing the button: Each light (starting with the Toner light) will in turn switch to orange and stay on. When all 4 lights are constantly orange, wait for a few seconds then let go of the button.
That should do it
rigsby
Posted on Dec 01, 2008
jtuminaro
  • 56 Answers
SOURCE: Need to reset 'Drum near end' warning on Brother MFC-8460N.
Open the front door
Press clear
then press 1
Posted on Jan 15, 2009
SOURCE: Brother printer HL 5250 DN.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
Posted on Dec 08, 2008
  • 134 Answers
SOURCE: Changing Drum
The drum is where the image is applied before being transfer to the paper. If the drum is wearing down the image will become poor. Changing the drum unit will make the image like new. So, yes you can run the drum catridge until you get a poor print out.
Posted on Jun 30, 2008
  • 10 Answers
SOURCE: How do I replace the drum on a Brother hl 2040.
I have 'reused' the same drum three times and still prints like a charm.
Open the toner door and pull out the toner/drum assembly. Take the toner off the drum tray. Use a alcohol pad or lint free cloth and wipe the mauve coloured drum to remove the excess lint and toner collected on the drum. Rotate the drum with the white gear and keep cleaning until the whole drum is done.
Put the toner back in the drum tray. Clean the corona wire by sliding the blue tab back and forth 3 or 4 times. Put the toner/drum back into the printer and close the door.
After the printer does the self test the drum light will cone on again so then you need to reset the counters.
Open the door again
Hold the GO button until all 4 lights are lit up
Release the GO button
Close the door
Printer will self test and should extinguish all the trouble lights.
Posted on Apr 20, 2009
  • 14 Answers
SOURCE: how to change drum brother 7440n
Open the front cover.
Press Clear/Back
Press 1 for Reset Drum
Loy Glenn - loyglenn@rock.com
Posted on Oct 23, 2009
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
Solusi code eror 4F on brother DCP-145C printer
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
May 25, 2012 | Brother Ink for Dcp145c Lc-980
My printer show me drum error problem i change the drum of my printer of brother MFC-7320 but i face same problem.
It looks like that you printer is old one. Please take out the cartridges & clean the space, roller with a soft dry cloth. After that install the cartridges back in place & power on, do the allignment & take a test print
Apr 04, 2011 | Brother MFC 7420 All-In-One Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Drum light is blinking and not sure how to change it or fix it in Brother HL-5250DN
Hit the purple/blue button on the top of the printer 3 times. This will print a settings report of the printer showing you the toner levels and the drum life.
If you need a new drum purchase one. (I would suggest a new printer at this time but if you like it continue on)
Open the front of the printer and pull out the toner and the drum cartridge. The drum is on the bottom of the toner. Disconnect the drum from the toner and connect the new drum. Replace the toner/drum and you are good to go.
Nov 15, 2010 | Brother HL 5250DN Laser Printer
My all-in-one printer keeps telling me that I need to change the drum soon. I bought a new drum inserted it into the printer and now I can't print anything. Plus, it is still telling me that I need to...
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Note
    Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brother limited warranty does not apply to any problem that is caused by the use of unauthorized third party drum units, toner cartridges or toner.
    If you are using a genuine Brother drum and toner and after following this procedure the unit continues to show "CHANGE DRUM SOON", your machine may require service. Please contact the Customer Service Center.
May 01, 2010 | Brother MFC 7420 All-In-One Laser Printer
Several things to check, the P/U roller is warn down, could be the paper sensor or the paper in the tray is set too tight
Feb 12, 2009 | Brother HL 1450 Laser Printer
Brother drum replacement
you could damage the gears if the drum jams up but that unlikely
Jan 16, 2009 | Brother DR-400 Replacement Drum - 20000...
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
Oct 07, 2008 | Brother Office Equipment & Supplies
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother HL 5250DN Laser Printer Logo
1,532 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
