Question about Toshiba MD9DM1 9 in. TV/DVD Combo
TV DVD Combo - Won't come on with the first try of the button or remote...
After repluging into an alternate receptacle and pushing the on/off button (on the front or the remote) about 60-100 times it will come on...but only after I have plugged into an alternate receptacle. After I'm finished watching and turn it off, I am able to turn it right back on. However, after it sits overnight I am back to the same problem. Sometimes it will turn on after the 3rd or 10th try (a rare occassion). Once on, all is fine. I have experienced this problem approximately one month. Any suggestions? Is it worth having repaired? TV was mfg. Oct. 2002 and I've had it since mid 2003. Thanks for your help or suggestions. I love having a TV on my kitchen counter to watch as I cook, etc. Gayle
    President:
  • 3,130 Answers
This is a common problem and if you can find an honest repair person(HEHEHELOL)They can easyly find a bad B+ capcitor in the 5 or 9 volt line in the power supply. good Luck
Posted on Aug 05, 2006
I have a problem with my thompson tv i can not turn my tv on or off with my romote or my fingers
Did you try unplugging and replugging the set to reset? Checking remote battery? Actuating each remote function (button by button) twice in succession to reprogram? Also, could you have inadvertently de-programmed by pushing the PROG or similar button? Mfrs not uncommonly but that button in the wrong place where users, especially button mashers, are apt to push them trying to turn of the set. The suggestions above might reprogram. Other wise contact customer service for the TV and let them guide you.
Nov 03, 2014 | Televison & Video
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
Aug 11, 2011 | Apex Digital Televison & Video
I have an advent tv/dvd combo. I dont have a remote and its stuck on video. how can I put it on tv without the remote? thank you
Disconnect the TV\DVD combo from power source (A\C) for two to three days, Replug power cord & see if it returns to normal. 2nd attempt:: Unplug A\C power from wall and take a piece of bear wire or any metal (paper clip, screw driver ) and SHORT the two blades of A\C plug for at least one FULL day.DO NOT PLUG INTO a\c SOCKET FOR ANY REASON !!! After one full day, take the short accross the blades. Replug into A\C power socket. see if that fixes the problem. P.S. Your TV should have a button that switches from TV to DVD play right in the right front.
Jun 19, 2011 | Recoton Advent Advent DV1418A 14 in....
The remote is not working the box and neither is the buttons on the front of the box
Tries Dish box uplug,replug it back by letting the box softwares to updates.The remote have not change batteries in it a few months,change the batteries and push the SAT button on the remote few times.Should be working again.
Jan 18, 2011 | DISH Network IR Remote Control
Need remote code for gpx tv/dvd combo
I have a code of 749 for it,if not ,try this,press and hold TV button until all the lights come on,press and release the POWER button,press the up button once a second while pointing the remote at the TV,when the remote has found the correct code,the TV will turn on or off,press the pound # button, if it is correct, it will blink three times. ..hope this helps..
Mar 29, 2010 | RCA RCU403 Remote Control
Remote is not communicating with console. New
When you put new battery in remote you must re sync the remote with the system.To do this you need to take off the back of the remote then push the red button.Their is a red button on the system that you need to push at the same time. This button is in the front or side compartment of the system.After pushing both buttons push the a button on the remote.Do this for all remotes.You my have to do this a few times to get it to sync.
Mar 13, 2010 | Nintendo Wii Console
I replaced the batteries in my wii remote and now neither one of the remotes will work.
When you take out the battery you need to sync the remotes with the system.You do this by taking off the back cover of the remote and pushing the red button.You need to find the red button on the system and push at the same time then push the a button on the remote.The button on the wii is in the side or front compartment on the system.Do this for each remote.
Mar 08, 2010 | Video Game Consoles & Games
Toshiba MD9DM1 9 in. TV/DVD Combo Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
