Question about Motorola Radio Communications
Speaker malfunction, need repair/disassembly info
I have an older model Motorola Sport 7 from 1997 and its having speaker malfunction and would like to know how to disassemble the radio so as to inspect/fix it and possibly find replacement parts if necessary Model# P14SHC03F2AA
eradiostore
  • 1654 Answers
SOURCE: Parts for XTN Series Motorola Radio
Call us here at eradiostore 800-872-2627, we can help.
Posted on Jul 23, 2008
SOURCE: I had a problem with my dell inspiron 6400 laptop speakers
Hi perrito20,
Here's a link for you. Just follow the 1-7 instructions on it.
http://support.dell.com/support/edocs/systems/ins6400/en/sm/speakers.htm#wp1012496
Hope this helps!
Thanks,
Karlox™ :)
Posted on Jul 29, 2008
SOURCE: User Manual
talkabout t5725
Posted on Oct 16, 2008
eradiostore
  • 1654 Answers
SOURCE: MANUAL FOR talkabout model T5725 NEEDED
http://www.usersmanualguide.com/motorola/2-way_radio/t5700
Posted on Dec 19, 2008
eradiostore
  • 1654 Answers
SOURCE: removal of charger jack on Motorola sp10 radio
The schematics of this radio are not posted online anywhere to my knowledge. However, I can tell you how to remove the radio from the housing.
First, carefully remove the battery tray by slipping a screwdriver or car key into the slot at the bottom of the battery area. Gently pry up. This will remove the battery frame.
Then, either use a Motorola frame removal tool, or substitute 2 small screwdrivers. Slipping the device under the tabs in the side channels to release the little ears which hold the component board in the housing. (This are about 1/2 way up inside the radio, on both sides. You will see they slide in a channel or groove.)
Once you have gently moved the "ears" inward, you will be able to push on your small screwdrivers (or frame removal tool) and slide the component board out the top of the radio.
At this point you will have access to the accessory jack.
Sidenote: If you want to forego the above, you can simply send the radio in for a flat rate repair, which is approx. $69 at most servicers, during which time the accessory jack would be replaced.
Posted on Dec 23, 2008
How to disassemble
Most speaker enclosure's, both wood composition and metal are hermetically sealed. This prevents damage to integral parts or moisture buildup. When a small speaker is malfunctioning, the magnet or cone may have sustained damage and is no longer viable. It is better to replace the entire unit than try to repair the interlace works.
Apr 17, 2015 | Brookstone Mobile Mini Speaker
HOW DO I FIX IT
Info here seems relevant... too much to explain here. You will have to review and see.
Make: Mitsubishi Code: P1610 Definition: Immobilizer System Malfunction Also posted by Steve Brock @ fixya
have 2001 Mitsubishi Montero Sport wont star scan it got code p1610 no...
Nov 27, 2014 | PIAA 2001 Mitsubishi Montero Sport - All...
Need battery tray for motorola sport 10 x
Unfortunately, the battery trays for this Sport 10X radio, Sport 7X and the later model TalkAbout Distance DPS are no longer available. In our repair facility we often get requests for these battery trays, and as a dealer we have not been able to get them for several years. Your best option is finding a used parts radio somewhere like ebay. In some instances the original tray can be fixed if you still have it.
Best regards.
Feb 20, 2014 | Motorola Talkabout Distance DPS (10...
Samsung SMH1611 microwave clock/tImer is intermittently malfunctioning. Microwave will not count down.
This is often just a bad connection on the bottom of the noise filter board. Look for burns and ring cracks. See the attached photos. For disassembly info, you can watch the video at my site, or see these text files: http://www.microwavecontrol.com/safety.htm
http://www.microwavecontrol.com/disassembly.htm If that doesn't fix it, it may be that the bottom door switch is bad, or its mount is loose, misaligned, or broken. See my help file on door switches here.
Also see the Fast-Track manual for model SMH1611 here.
Feel free to contact me directly (see below) if you have other questions.
.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 28, 2017 | Samsung SMH1611 1.6 cu. ft. Over-the-Range...
I have an older model Motorola sport 10X radio that has two pin connection. I tried several of the Motorola two pin accessories but the pins are too far apart. Are there any adapters available?
You might try contacting the people at http://www.wirelesspro.com/. They seem to have a variety of accessories for the Motorola Spirit and TalkAbout line of radios. The Sport 10X was a predecessor to the TalkAbout Distance DPS.
Otherwise, you might check with your local Radio Shack. It is possible they might have a 1-pin device which might work with the Sport 10X. On some audio devices the second pin is only for stability. The main thing which would make a difference is size, length and placement of rings.
Best regards.
Jan 04, 2011 | Motorola 2 Pin Adapter 2-Way Radio
Need to dis-assemble a Motorola Visar handie talkie fm radio. Radio has intermittent volume, lose connection
The radio is easy to disassemble and has no hidden surprises, but I doubt you're going to like what you see once you get it apart. The large screws that are very visible on the outside hold both halves of the outside to the thick radio chasey and mother board.
Your volume problem is typical for older T6400s, and is caused by the speaker binding internally. Motorola does not sell the speaker separately and it is built into the case so you can't really just un-hook it and install a new one in it's place.
That's a shame, they are great radios.
Mar 30, 2010 | Motorola Talkabout T6400 (22 Channels)...
In referance to a IAI .380acp Back Up model semi
Try this site, it should give you the info you need:
http://pdf.textfiles.com/manuals/FIREARMS/amt_backup.pdf
Jan 29, 2010 | Sport & Outdoor - Others
I have been informed by Boost Mobile the i776 by Motorola has been recalled. I can find no info on the Motorola website regarding this. My phones microphone went 'dead'. Speaker works. Any info?
I heard that some of the older i776 phones had trouble with the software and they were being replaced under warranty. The one I have is from one of the later groups and I've had no problems with it whatsoever. I did hear that the older ones suffered from lockup quite a lot. But I'm not sure about your microphone situation. Don't remember that one.
Nov 28, 2009 | Motorola Mobility i776 Cell Phone
How do I disassemble + clean Harmon Kardon SoundStick subwoofer?
Check for a Fuse. Mine is an older model and has a Fuse right next to the power cord. It probably has a slot for a flathead screwdriver.
Apr 24, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Motorola Stature i9 Speaker Not Working
Its the "loud speaker" that apparently needs to be replaced. I have the same problem with my i9 phone and this is what I came up with thanks to google. I also found that those speakers are just $5 bucks online. The link to that website is below. Now I just need to find a video on how to disassemble the top part of the flip so that I can try to fix it myself. Wish me luck! :/
http://www.phonerepairparts.com/motorola-stature-i9-earpiece-speaker-part-for-repair/
Apr 24, 2009 | Motorola Mobility Naztech Nextel Iden...
Radio Communications Logo
50 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
