How to fix astec lpt 42 dead - Computers & Internet
HP Designet 500 power supply Astec AA20850 dead
Go right to HP dot com and they will have a circuit diagram and parts, service manuals etc.
Jun 02, 2014 | HP DESIGNJET 500 InkJet Plotter Printer
ASTEC 63DV ALARM INSTALLATION MANUAL
Hi.
Would anybody have an Installation Manual for Astec alarm panel.
Feb 11, 2013 | Vehicle Parts & Accessories
I am looking for a product data sheet and/or manual for the Astec SS500-3405 power supply. Might you be able to assist? Thanks,Tony.
The three I have inspected, all of them failed due to the vent. It breaks down and makes the power supply to stop.
Jan 04, 2011 | Astec Computers & Internet
I need a data for the Astec SA302-3515 300-Watt Power Supply?
Everything you need to know can be found here:
http://www.atxpowersupplies.com/300-watt-power-supply-fsp-atx-300-gu.php
(just copy and past the above link in your internet address bar in a new tab)
Mar 31, 2010 | Astec SA302-3515 (6500165) 300-Watt Power...
4.6v on 3v3 out, then to STBY mode
that is problem of pulse width modulator ic in smps it van be solved by replacing the ic
Mar 09, 2010 | Astec (6500110) 145-Watt Power Supply
My astec atx202-3515 power supply blew up. I accidently changed the watt to 115. It was 230 watts before. Will the power supply still work oe will I need to purchase a new one?
just flip it back to 115v hook it up and see if it works. if itdoesnt work replace it . I did that once it was fine the comp didnt turn on til i turned it back 115v
Mar 09, 2010 | Astec (ATX202-3555) (ATX2023555) 200-Watt...
Got a astec sa302-3505 power supply . . . need to know how do you add a switch to turn it on if its not connected to the motherboard
Simple, Just connect a switch to Green wire and one of black wire.
When the green wire got connected with negative (Black wires are negative) the SMPS Fan starts which is also a visual feedback to you that SMPS starts.
----------------------O /
Grean /
-----------------------O
Black
So simple..
Jan 26, 2010 | Astec 300w AT Power supply 190170-01...
Hello, i have a Astec 110s central vac that shut down today.
That means that either the motor or the relay is bad.
Dec 04, 2009 | Vacuums
I am looking for a manual and troubleshooting manual for a astec 73-180-0029 POWER SUPPLY
Look it up on the internet you should be able to find one. Try the www.astec.com website first.
Nov 19, 2009 | Astec Computers & Internet
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
