I do not get Wi-Fi signals out from my Digisol DG-BG4011N modem
My digisol router is not transmitting Wi_Fi signals I thingks. My Laptop do not recieve it. It was OK sonce two days ago, Now it is intermittent, get now and then, sometimes disturbed. The WLAN LED on it lights on. Lan outs' [four of them] have no trouble at all.
  • The Knight
    The Knight Feb 09, 2012
    Two of us uses this modem, just with in the range of 8 Meters. I've vonnected to LAN-3, and is ok, but the second one cannot access tthe Wi_Fi signals.
  • 4 Answers
SOURCE: WIRELESS NETWORK PROBLEM
Consider getting an upgraded antenna. It will increase the signal strength and range.
Posted on Oct 27, 2007
Silverblade
  • 173 Answers
SOURCE: Need help configuring LAN and WI-FI settings...
the first thing you have to check is if your computer is getting a valid IP address from your router. if your using a windows xp laptop just go to your network connections under control panel then right click the connection you want to check and got to status, click the support tab and it will show you the IP address, subnet mask and default gateway(for windows vista just go to details and look for the IPV4 info)
if your laptop has built in wireless you can just turn it off(theres a switch of a button to turn if on/off) so that your laptop will only be using the ethernet connection. there is not option to automatically switch from one connection to another.
Posted on Aug 05, 2008
  • 192 Answers
SOURCE: my d-link 2640t wireless router suddenly no Wi-Fi
This one can be one of two things.
If you have a digital multimeter, check the power connection and make sure that it's not to high (eg. 7.5 V DC should read no more than 7.8 V for it to work properly)
Otherwise, just reset the router. I have a feeling it is the first one.
Once it reaches to 130% above of what's rated, it can fry your network adapter in your computer and possibly more damage if it's wired.
Posted on Aug 09, 2009
  • 19 Answers
SOURCE: All wired ports are sending and recieving data
Your wi-fi radio broadcast may be set to off. Find the wi-fi set up page and make sure the bradcast selection is turned on.
Posted on Dec 23, 2010
Geekman
  • 32281 Answers
SOURCE: My lan lines work but
I know it is a pain but to determine if the D-Link is faulty, try resetting the D-Link back to the default settings and configure it again -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Posted on May 28, 2011
Digisol dg bg4011n router is not working in ubuntu10.04 Isearched for the driver not get sofar
You need a device-driver for the Ethernet adapter inside your computer. Then, use an Ethernet cable to connect from your Ethernet port to one of the 'LAN' ports on the router.
Aug 30, 2014 | Computers & Internet
How to find ip codes on a manual methods
Try with its drive CD. There will be automatic configuration option. I did it with my Digisol Modem Wireless Router.
Jul 05, 2014 | Computers & Internet
I was browsing with my digisol dg-bg4011n,when i disabled the connection and enabled it again its not working..i mean the internet LED light is not turning green...Please help,I'm in big trouble..
try a fact resest should be a pin set hole in the back take a pin/paperclip tooth pick Press & Hold for 10 sec that should reset rotuer to factory defaults. That may help if not unplug router from power & unplug wan ethernet or unscrew wan coax for 30 sec if that still dont work call your internet service provider they can do remote reboots that may help
Jan 13, 2013 | Computers & Internet
I didnt find the 8 digit pin number anywhere on the router of DIGISOL DG-BR4015N, please help me if u know dat number...
Login into 192.168.2.1 it will ask you for username and password default username is admin and password is password here click on wizard-> wireless-> WPS there you will be able to find AP pin
Sep 28, 2012 | Computers & Internet
From where can I downlaod driver for my Digisol DG-Bg 4011N, wireless ADSL Broadband Router
already have a driver attach in modem.is no updated driver because hardware dependent. so sent service center updated your modem hardware then update driver from service center it only for u worked ( it's not joke). or" buy updated modem.
Mar 06, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
Does not wierless work in xp computer and 2 ipad.
Are you using a laptop? If not, the computer that you are using should capable of connecting via wireless connection. And the Modem /router should be transmitting wireless signal. If you can successfully connect via wifi, then all of your wireless end devices should be connected via wi fi a as well. check your local network for issue isolation.
Dec 30, 2011 | 2wire (2701HG-B) Wireless Router
Can I setup a wireless Wi-Fi connection with my Fujitsu lifebook N1061. Does it's wireless modem match with Wi-Fi protocol?
there are two sections to this problem. first it that all wireless devices use 3 types of signals.
they are wireless b, g or n type wireless devices. usually you can set your default to recieve b/g or b/g/n. your wireless router should have a label that indicates what protocols it transmits in. once this has been determained, there is the Authentication process which provides security for your wieless signal so that not just anyone in the area can use your connection to the internet such as in a public business where you see the sign Free WI FI. this Authentication method must ALSO match what your router is set up for. when you go into the routers admin area which is a url number such as (169.254.198.1 ) from a connected computers (internet browser) this your wireless manufacturer will provide. you must MATCH this Authentication type also on your laptop to that what you setup to use for the router to ASK for. there are way to many different products to know exactly which one you need. There are only about three different choices for this security connection protocol to pick from. then you will need the PASSCODE from the router label to enter into your laptop wireless setup area. when all matches you should get a hookup.
Apr 18, 2011 | Computers & Internet
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Computers & Internet Logo
369 people viewed this question
David Payne
David Payne
