Fault code of 130-150-05 speed shift sensor door open
SOURCE: 1993 Ford Escort 4 Door Byockey830
speed sensor is only used to tell the processor to shift the trans into overdrive and lock up torque converter, don' know what the orig post was, try to always use the same thread to post new questions about the same issue.
SOURCE: e300 1994 codes read p0720 and p0500 one is speed
try changing the drive shaft speed sensor, sounds like you have a malfunctioning drive shaft speed sensor, change sensor and reset codes and test... e 300 had this problem in 94 and 95 even when they were close to new with very low miles... please rate my help , thanks
SOURCE: windows not operating('05 ford f-150)
Go to ebay and you can buy a new switch with controls for about $50..pry top of arm rest off with a plastic putty knive and just unplug the two terminals and switch out the controls....it will work fine...but you may have to do it again if you own the truck more than four years,,not too dependable
SOURCE: check engine light on. the fault is speed sensor.
how to install speed sensor in 2001 hyundai sonata 6 cylinder
SOURCE: mitsubishi pinin fault code P0421
yes this is your catalytic convertor is clogged you have to change before is damages ur o2 sensors
TH2TNK Sensor Value Offset Shifting
Possible failuer of OBD II Fault code P1F68
These are not standard fault codes for any make, model or year car or light truck I know of.
