Question about LG Televison & Video
What it is "the desired RC"
  • 734 Answers
United States is the regional code 1 and is usable on all DVD players.
Posted on Feb 09, 2012
I was trying to transfer data from the RC-50 to my computer and pulled out the USB cable by mistake from the computer and now the RC-50 says Data Damaged. I think I may have put the file in the trash in...
Usually in any type of situation when data is being transferred and the connection is prematurely lost there is data lost and or file corruption.
My suggestion:
Connect the Boss Rc 50 to your computer and backup its entire contents to your computer if possible.
Next perform a Hard Reset: While simultaneously holding down the "PLAY MODE" and "LOOP SYNC" buttons, turn the power on. Everything should be restored to factory settings.
If your backup was successful, then you can transfer desired files (one at time) to determine if the are usable. If a file causes errors or malfunction, then most likely it is corrupt.
Hope this helps
Apr 05, 2011 | Boss Rc 50
Tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
on Feb 25, 2015 | Roland Boss RC50 Loop station (with )
Tip
Known Mintek DVD Code Hacks
window.google_render_ad(); Mintek MDP-1010 / MDP-1020 / MDP-1030 / MDP-1070
  1. Press SETUP
  2. Go to "Preferences"
  3. Press 255 135 (or 225422)
  4. Press LEFT and DOWN quickly
  5. Current RC should be displayed
  6. Press the button for the desired RC (0 = codefree)
  7. Press SETUP
Mintek MDP-1060
  1. Press SETUP
  3. Press 253 135
  4. Press LEFT, DOWN, ENTER, SETUP quickly
  7. Press ENTER, SETUP
Mintek MDP-1720
  1. Press SETUP
  3. Press 215 345 (or 251251)
  7. Press (PLAY,) SETUP
Mintek MPD-1730 / MDP-1770
  1. Press SETUP
  3. Press 251 131
  7. Press SETUP
Mintek MDP-1750 / MDP-1810
  1. Press SETUP
  3. Press 251 345 (or 252315, 251251, 255135, 253135, 251251, 251422 / 212425)
  7. Press SETUP
Mintek MPD-1760 / MDP-1815
  1. Press SETUP
  3. Press 224 455
  7. Press SETUP
Mintek MDP-5860 / MDP-5861
  1. Press SETUP
  3. Press 222 443 (or 222443, 242112, 221441 [->MDP-5861], 224441, 245512)
  7. Press SETUP
Mintek MP 1710
  1. Open & close the disc tray
  2. Push SETUP on the remote control
  3. Push 1, 3, 6, 9
  4. Push the left menu arrow button 3 times -- NOT the |<< or << button
  5. Push the right menu arrow button 1 time -- NOT the >>| or >> button
  6. If you see a new menu item named "VERSION", enter that menu
  7. Change "REGION CODE" to 0
  8. Press SETUP
Mintek DTV-233 / DVA-8700 / DVD-1500 / DVD-1600 / DVD-1710 / DVD-2110 / DVD-2580 / DVD-3610 / DVD-5830 / DVD-8350 no known hacks
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
I need the region code and process to unlock my samsung DVD P490 player
  1. Power on your player with no disc in the tray
  2. Press REPEAT for 5 seconds
  3. Enter the corresponding combination for your current RC (see top of the page)
  4. Current RC should be displayed
  5. Press the button for the desired RC (9=multi-region)
  6. (Press OPEN)
  7. Power off your player
Mar 27, 2011 | Samsung DVD-P190 DVD Player
A dvd is from a different region how do i change it to my region
  1. Open the disc tray
  2. Press 1, 1, 1, 1
  3. Press the button for the desired RC (0 = codefree)
  4. Current RC is displayed
  5. Close the disc tray
Dec 08, 2010 | Philips DVD724 DVD Player
Need codes for samsung dvd player
The sequence will depend on what region your machine is preset; Take a lok at the back of the DVDR and check. Once you know that use the codes bellow- Region codes for Samsung: RC 1: 2, 9, 3, 3, 4 RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8) RC 3: 5, 6, 7, 3, 2 RC 4: 7, 6, 8, 8, 4 RC 5: 5, 3, 8, 1, 4 RC 6: 2, 4, 4, 6, 2 1)Power on your player with no disc in the tray 2)Press MENU for 5 seconds 3)Enter the corresponding combination for your current RC (see top) 4)Current RC should be displayed 5)Press the button for the desired RC (9=multi-region) 6)(Press OPEN)Power off your player ATTENCION: after step 3 the current RC appears for less than 2 seconds, be ready to press 9 (all regions)right after you press the combination. Tha press enter.
OR....
Go to www.samsung.com they have a lot of software downloads and paths that may help you
Aug 30, 2009 | Samsung DVD-R155
How do I make this model region free?
I've found this on a site. Please post back with results. "Desired RC" is region code. '0' is region free.
  1. Power on (with no disc inserted)
  2. Press PAUSE
  3. Press 3, 1, 4, 1, 5, 9
  4. Enter the desired RC
  5. Press PAUSE
  6. Turn the player off and wait a few seconds
  1. VCD playback
  2. Press PAUSE, 1, 4, 7, 2
  3. Press UP 6 times, '07 00' should appear on the display
  4. Press Program 6, Program 5 ('07 FE' should be displayed)
  5. Press ENTER
  6. Press RETURN
  7. Power off and on again
Apr 15, 2009 | Televison & Video
Samsung dvd-v5600 is set on region 4
This code is for DVD-5500 and DVD-6500. It may work for DVD-5600 as well.
  1. Turn on the player (without a disc inserted)
  2. Press and hold PLAY and FW (or STOP)
  3. "No Disc" is displayed
  4. Release the keys
  5. Press SUBTITLE, REPEAT (or just SUBTITLE or just REPEAT or MENU)
  6. Enter the corresponding combination for your current RC (see top of the page)
  7. Current RC should be displayed
  8. Press the button for the desired RC (9=codefree)
  9. Open the disc tray
  10. Turn the player off
Apr 13, 2009 | Televison & Video
Looking for region unlock codes
Can't find one for the AWA, but one for your samsung is:
  1. Turn the player off
  2. Press and hold PLAY and STOP
  3. Turn on the player
  4. Language menu shows up
  5. Release the keys
  6. Select language
  7. Press REPEAT
  8. Enter the corresponding combination for your current RC (see top of the page)
  9. Current RC should be displayed
  10. Press the button for the desired RC (9=codefree)
  11. Open the disc tray
  12. Turn the player off
Region code for Samsung DVD-R100a
This is one for DVD-R100 (not R100A). Tell me if it works.
  4. Release the keys
This is another I found.
  6. (Press OPEN)
Apr 12, 2009 | Samsung DVD-909 DVD Player
Televison & Video Logo
Computer Repairing
Computer Repairing
