Question about Ulead Videostudio 8 for PC
I cant use my ez grabber.
I have ez grabber usb device. What software will work for win 7?
My ez grabber wont work with windows 7 what can i do
The product is supposed to work with both 32- and 64-bit editions of Windows 7. Make sure you install the latest drivers, obtinable here -
VC500CXT Product Manual .
To improve chances of success, uninstall any relevant old drivers first.
As this is an older product, and although USB3 ports are supposed to be backwards compatible with USB2 devices, I'd suggest you try to get it connected to a USB2 port (these USB ports do not have a small blue plastic tab in them).
Dec 23, 2017 | Computers & Internet
How do you edit with the ez grabber vc500
Hi
I give below a link to the EZ Grabber installation manual.
http://www.derbymagic.com/files/EZGrabber_manual.pdf
I have been through this but can find nothing to indicate an "edit" facility.
I then tried this link
http://www.dmmdownload.com/downloads/CURRENT/PVR/Diamond%20VC500CXT%20Walkthrough%20Response.txt
which clearly indicates an edit facility via some Arcsoft software which presumably is supposed to come with the grabber.
It is possible that one of the "software utilities" on the webpage (link below) may contain the software required.
http://www.diamondmm.com/driver-downloads.html?option=com_content&view=category&id=599&Itemid=1014&select_item=354_598&select_item_354_598=355_599
Good Luck
Aug 25, 2014 | Diamond Multimedia ( VC500) Video Capture
Sm-usb 007 device unplugged
hi, the 64 bit driver may be the issue , somehow it's not correctly installed or using a 32bit driver, remove step back on system restore so there's no trace of the installed driver, or un-install however there may be some entries in the registry left behind... okay reboot.... just plug in the device. Does Win7 install a driver ?? I had a issue with similar hardware in Win 8 however it did solve it and it's working now..
Goodluck
Rob.
www.gewizpc.co.uk
Jan 08, 2014 | DekCell EasyCap USB 20 Video Capture...
? software for ez cam pro 307 SO1763A for laptop with win 7 oper system
1st You download Webcam Driver.
software for ez cam pro After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Ezonics Camera Drivers for Windows XP Vista Windows 7
Jan 14, 2013 | Ezonics EZCam Webcam
What software works with ez grabber video cap device
I've had success with Pinnacle 9 a few years back also Ulead Studio 11
Sep 03, 2017 | Mygica Ezgrabber Video Capture Adapter...
Can i connect a samsung camcorder vdp453 to windows7 pls?
Most of these camcorders do not have proper usb support for video, so you'll have to buy a so-called video grabber or capture card. You can plug in the video grabber to usb and then connect dvi or firewire from your camcorder. Install the included software, configure your camera. Then press play and the video grabber will record the input from your camera.
When you buy one of those video grabbers, make sure it's a good one. Make sure powerful and stable software (which is compatible with windows 7) is included. Cheap things usually don't work. I've had this Chinese piece of junk for $10 which lagged and kept crashing my computer. Pinnacle was a lot more expensive but it works great and the fun will last a long time.
Jun 17, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
I have an EZ Grabber Item No: A07JR. Trying to get VHS film played on a Sharp VC-MH815 6xHead/Nicam/Hi-Fi Stereo Player Recorder. Useing video composite from the player to USB attached to a Toshiba...
This is a solution, probably resolve your problems as well, for converting VHS to DVD, its a tip I posted some time ago, might help you out:-
There appears to be quite a few problems with people trying to convert their video tapes to DVD using a PC and propriety converters, editing programmes etc.
Friends have also has such issues, lip synch being one of the most prolific.
I've successfully converted mine, without too much issue and managed to avoid these issues.
I hook up my VHS recorder with a DVD recorder2_bing.gif which also has a HDD. Daisy chaining it on to a TV to monitor. All with scart leads.
Play the tape, record to the DVD hard drive. Finally edit and dub to DVD.
Have fun ..............
Nov 25, 2010 | Cameras
I need WIN 7 driver for smc 7003 ez connect usb modem. Can someone please help? Tnx
After navigating to SMC's website, I found the driver for your device, however windows vista/ windows 7 is not listed as supported, however, they did have a driver for
  • Windows 98
  • Windows 98 SE
  • Windows NT4
  • Windows Me
  • Windows 2000 Professional
try using this driver and see if windows 7 will be able to use it.
If you have any questions please let me know!
Thanks,
Mike
May 16, 2010 | SMC : EZ Connect USB Cable Modem...
I have a EZ Grabber but do not know how to work it.
had same problem. ensure right selections are made in the souce menu. & that your connectors are out connectors and not ins.
Sep 18, 2009 | Ulead Videostudio 8 for PC
Ulead Videostudio 8 for PC Logo
881 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
