Question about Remote Start System
Viper 4103v model auto start messed up my windshield wipers on HHR
I purchased the viper 4103v viper auto start for my chevy HHR. Best Buy installed it. NOw my windshield wipers dont work correctly. Wipers wont work on intermittent. They also never gave me a manual to operate the autostart. I have told them about the problem and they say, " we didnt do anything to the wipers."
  • 3 Answers
SOURCE: i had a viper
If your vehicle has daytime running lights they will be on when remote started no real way around that try leaving your parking brake on.
The new vipers default setting is constant rather than flashing.
Posted on Jan 07, 2009
insanegtp
  • 112 Answers
SOURCE: Viper 5701 2001 Chevy
:) Sending you a link for the wire info, as far as the bypass... the 451m is wrong.. I think you need something else, I send you a link to that as well...
Posted on Jan 26, 2009
reynosaelect
  • 165 Answers
SOURCE: Kill switch is on and I cant deactivate
you to disconect the main harness from the alarm.and take your car to a alarm repair shop.
Posted on Mar 17, 2009
Boole5555
  • 160 Answers
SOURCE: Viper 5101 Manual Transmission - can't start
First off, is it in neutral? It can't engage the starter motor if it's in gear. Secondly, If it was professionally installed, why not just take it back and demand that they fix it?
Your wiring should somewhat match this.
Posted on Jan 13, 2010
  • 4 Answers
SOURCE: Viper
did it ever work before?
A couple things here. It is best to have a "tach wire" and the system needs to be programmed to learn the tach signal in order to know if the car is running or high reving or dead. If it gets no signal of the sort the next option is voltage monitor, it monitors the voltage for an increase to show that the alternator is running. Either way that signal is not gettting to the viper brain or it has not learned that signal. You need an install manual, did you install the alarm?
Posted on Mar 25, 2010
Wiper motor
Possible wiper linkage has broken/seperated from wiper motor. The wiper cowling covering the linkage assembly will need to be removed to inspect/repair
Feb 13, 2016 | 2008 Chevrolet Impala
Where can we buy replacement blades online?
Amazon.com: Silhouette Replacement Blade
www.amazon.com > ... > Replacement Blades
Amazon.com, Inc.This replacement blade is compatible with all Silhouette electronic cutting tools. .... center" from Silhouette online store) It has taken me 3 blades to get through ...
Windshield Wiper Blades - Advance Auto Partsshop.advanceautoparts.com/c3/windshield-wiper-blades/15566462 results - Save on Windshield Wiper Blades with great deals at Advance Auto Parts. Buy online, pick up in-store in 30 minutes. ... Replacement Parts (460).Wiper Blade (Windshield) at AutoZone.com - Best Wiper ...www.autozone.com/ignition-tune.../wiper-blade-windshieldAutoZoneReplacement Parts ... Vehicle Specific Bosch Evolution/Wiper Blade (Windshield).Price: $15.19. Part Number: 4820; Application: Front; Notes: Beam Design
Nov 02, 2015 | Cars & Trucks
What size windshield wiper blades do I need for a '96 Chevy Blazer?
20 inch and all the auto parts store will install them for free after you buy them, so let them do it!
Feb 06, 2015 | 1996 Chevrolet Blazer
How do you replace windshield wiper motor on a 1997 ford e250 van
REMOVAL
  1. Raise and support the hood.
  2. Remove the windshield wiper pivot arms.
  3. Remove the cowl top vent panels.
  1. Disconnect the windshield wiper mounting arm and pivot shaft.
  1. Remove the access cover from the dash panel.
  2. Remove the mounting arm and pivot shaft retaining clip.
  3. Disconnect the windshield wiper mounting arm and pivot shaft from the windshield wiper motor.
  1. Remove the windshield wiper motor.
  1. Disconnect the electrical connector.
  2. Remove the three bolts.
  3. Remove the windshield wiper motor.
INSTALLATION
  1. Install the mounting arm and pivot shaft retaining clip on the windshield wiper mounting arm and pivot shaft.
  1. Install the windshield wiper motor.
  1. Place the windshield wiper motor in the dash panel.
  2. Install the three retaining bolts.
  3. Reconnect the electrical connector.
  1. Reconnect the windshield wiper mounting arm and pivot shaft.
  1. Press on the windshield wiper mounting arm and pivot shaft after it is aligned with the windshield wiper motor.
  2. Install the access cover in the dash panel.
  1. Install the cowl top vent panels.
  2. Install the windshield wiper pivot arms.
  3. Adjust the windshield wiper pivot arms.
This is technically for the V6 4.2L but I'm sure those Ford E250's have the same setup for windshield wiper motor. Let me know how it goes.
Nov 17, 2014 | Cars & Trucks
2009 chevy hhr--The passenger side windshield wiper control arm popped apart. Can it just be squeezed together, or do I need to replace the little "ball and socket".
The rubber gets hard and makes noise. Wash the rubber blades in vinegar, that's supposed to soften the rubber.Hope this helps.
Sep 10, 2014 | 2009 Chevrolet HHR
I bought a Viper 5701 and I go to use the remote starter, and it turns on and within a few seconds, it turns off. It goes thru the motions of starting again, but it is aggrivating. Any solutions?? I...
I work at best buy. Bring the unit and the reciept back to any best buy and they'll reprogram it for you. The unit is not having a strong enough tach signal.
Sep 30, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Where does the windshield washer go?
The washer fluid is in the same container as the front washer, under the hood.
Is there a problem with the wiper operation in the rear washer/wiper?
Jan 04, 2010 | Chevrolet HHR Cars & Trucks
Windshield wipers dont work
Hi there, Best thing to do is buy a Haynes or Clinton's repair shop manual for your particular vehicle. Then read up on it in the trouble shooting section or the step by step replacement section. You can purchase these at your local Auto Parts store or buy them on line at ebay burdfrenzy
Oct 16, 2009 | 1997 GMC Jimmy
Windshield wipers will not turn off - 2003 Chevrolet Silverado
Fixed the wiper problem which was identical to Brad's by changing out the wiper module which is also called a pulse module or something of that nature. Pretty easy fix. You have to remove the grill that the wiper blades protrudes from in order to get to the motor (4 clips in front which can be removed by hand, remove radio antenna, a center push down retainer, two plastic end caps which pop off and then 1 star type screw on each end under the end caps). Getting the blades off seemed difficult. I used a small puller to pop them off after removing the nuts.
You can't buy this module at a regular parts store. I had to get it from the dealer so be prepared to spend $130 to $140 for the part or go to the salvage yard. Works great now.
Mar 14, 2009 | 2003 Chevrolet Silverado 1500
Remote Start System  Logo
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
