Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Dosenot seem to clean the carpets as good as before, we have cleaned the filter and keep the canister cleaned. What else might it be; I bought it for the express purpose to clean animal hair off my carpet?
  • Official Brand Answer
  • 2,572 Answers
I'm sorry to hear you're having difficulties with your DC17. This machine should have no problem dealing with animal hair, so if it doesn't seem to be picking up as well as usual, this may be due to a blockage. The easiest way to check for this is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
Although I note you've already cleaned the filter, you may want to take a look at the video below to make sure you've washed it as recommended - in normal use, this should be done at least once every 3-6 months. Use cold water without detergent, and allow at least 24 hours for it to dry completely before replacing it.
This should resolve the issue, but if you're still concerned about your machine, please call us free on 1-866-693-9766 - or if you email your details to askdysonUS@dyson.com, someone will be in touch as soon as possible to provide assistance.
Best wishes,
Jack
Dyson Online Customer Support
Posted on Feb 09, 2012
  • 566 Answers
SOURCE: clogged filter
hi if you turn vac over and look at the cover that hides the brush roller and remove the cover ? it is held by nylon twist 45 degree left type screws ? then you may find the brush housing clogged as well as the channel flow tube below the brush ? lift brush out and release from belt to enable to clean of hairs/carpet strands etc ? then reassemble next remove the clear canister and clean you will then see the cone/air filter ? it has hundreds of holes that get clogged due to vacuum created in cyl use a small implement and poke every hole clear ? if these are clogged vacuum remains in operative resulting in no vac at pickup head/brush beater roller assume you have replaced the disposable filters? hope this helps not an uncommon/fault and easy remedy
Posted on Oct 31, 2008
  • 97 Answers
SOURCE: Dyson dc14 animal is falling apart! The canister
the best sol would be to search for vacuum repair half moon bay, ca. To see if there is a vac shop near you. my suggestion's would be either Vacuum Cleaner Shop #(877) 822-8227 or Vacuum solotions #(502) 348-4900. hope this helps
Posted on Jul 20, 2009
b0sslady2001
  • 357 Answers
SOURCE: Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
http://cgi.ebay.com/DYSON-VACUUM-DC07-DC14-DC-07-14-BRUSH-ROLL-BEATER-BAR_W0QQitemZ120452265897QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b83b7a9&_trksid=p4634.c0.m14
Marci
Posted on Aug 07, 2009
SOURCE: Dyson collecting debris/hair, ect on top of hepa filter?
Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
Posted on Oct 29, 2009
jspahn
  • 103 Answers
SOURCE: I have the Dyson animal
You might want to check and see if your cyclones are plugged with hair. this can happen and there is a great site to disassemble and clean the cyclone here: http://www.exonotes.com/content/node/4
Posted on Aug 10, 2010
Water will not go through hose from bowl to clean carpet. Only bought it today and thought it would work first time.
did you unclip the pickup tube and place in the water container, look under the motor assy its a thin tube with a filter on the end. check all hose are clicked in place
Aug 03, 2010 | Numatic GVE370 Canister Wet/Dry Vacuum
Vacuum works but doesn't pickup dirt
there is a clog. check the hose, and the entry to the canister, check the holes inside the canister and check / clean your filter. also remove any threads/ animal hair from the brush so i can freely grab the carpet :)
Mar 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover Savvy has limited suction when cleaning the floor and carpet
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Jan 03, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Deodorizing the vacuum
First of all Clean out the vacum cleaner . Empty canister and take filter outside and hit on something to get all dust out . Now wash canister and filter with vinegar water and let dry before using vacum again. You might try using carpet fresh for pet odors on carpet and empty and clean canister and filter regularly. I own a cleaning business and this is a hard problem to solve with all vac. cleaners. Good Luck!!
Jan 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Little suction in craftsman canister style carpet/floor cleaner
you might have a leak on the suction side...perhaps the housing is not properly secured, or there is a **** in the black plastic hose.
Sep 10, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Filter Queen, carpet attachment problem???
Open it up and see if the dirt inlet is clogged. It would be by the brush roll. But you must have a clog.
Mar 09, 2008 | Filter Queen Majestic Canister Vacuum
Hep! My 3 month old Hoover Mach 5 doesn't pick up!
What is happening is the secondary filters, HEPA and the canister all need to be cleaned. This is vital. What the vacuum repair people are keeping from you is that tidbit of wisdom. This particular vacuum is picky about airflow. Pull the canister, and on the body of the vacuum on top of where the canister sits are the secondary filters. There should be a sticker explaining how to remove them. Clean them throuougly, mine was filthy. Make sure you clean the canister by unlocking it and cleaning out the micro holes and the cone end. Mine was completely plugged. Now brush the dirty side of the HEPA filter with the combo tool. Let the secondary filters dry completely (you can blow dry them on cold) Re-install everything, and the vacuum will run like brand new. I vacuumed the whole house after I completed this maintainence and it works like a champ. Don't return this vac until you clean it completely.
Feb 06, 2008 | Hoover Commercial C1660-900 Bagless...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
73 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
