Question about Cadco OV-350 Electric Single Oven
The fan in my cadco ov-350 isn't working
My cadco ov-350 oven keeps tripping the hi temp limiter switch. I was checking it out and discovered the fan wasn't working. I need to know if this would cause my problem and best place to get replacement fan
2 Suggested Answers
  • 193 Answers
SOURCE: I need to replace the
Cadco sells parts to the end use through a parts distributer. The phone number is 800 458 5593. Have your model and serial number ready when you call.
Posted on Oct 12, 2010
We have Turbochef NGC N6. The units high limit thermostat had tripped. Re-set thermostat and found cooling fan not working. also found thermal cut out ( top left rear looking from above ) had also tri
ur high limit trip because ur heater overshoots the program setting for the temp replace ur k4/k5 solid state relay for it controls ur temp for the heater.
Sep 21, 2014 | TurboChef TORNADO Electric Oven
Cadco oven wont start ...give error code pre and por
It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
Dec 15, 2012 | Cadco Ovens
The fan is blowing but the oven is not getting hot
It is either the thermal fuse or the relay I have the same problem- now I am trying to figure out how to install the new parts-I have both because the whole oven has to come out to fix it
Aug 14, 2012 | Cadco Ov-023 Oven
Whirlpool self cleaning oven will not heat up after cleaning. Lights and fan come on but not the elements. I have 223 volts to oven.it is model number RS696PXE
Hello Ken, welcome to FixYa.
It sounds like the hi-limit safety thermostat may be tripped, the scenario you described is exactly how this would manifest
...that is the component that typically trips/activates during a self clean on many ranges. You shouldn't need to open the front control panel, but access is through the back. (this can also occur during power surges)
You'll need to slide the range/oven out from the cabinet. If you slide the unit away from the wall and unplug it you can check the hi-limit.
Based on the model number you provided it should be a non-reset type hi-limit or push to reset. If non-reset it needs to be replaced.
**Unplug the range from the wall first of course...safety first**
Once you remove the panel you will need to look for a switch/thermostat which looks like either of these...
NON-RESET
PUSH TO RESET
(Not likely...unless model is wrong)
The replacement if necessary are available at "searspartsdirect.com" or "repairclinic.com" to name a couple.
Let me know how you make out. Good luck. I'll watch for your reply and if you need anything further I'll be glad to help in any manner I can.
Regards,
Macmarkus :)
Oct 24, 2011 | Ovens
Oven door seems sprung as if a spring may be shot and door dose not close all the way?
You need to replace both oven door hinges, as the springs are weak, and there is no adjustment available.
Sep 25, 2010 | Cadco OV-400 Electric Single Oven
High limit switch trips and needs re-set
After grilling or cooking at higher temps leave the oven light on so the cooling fan continues to run for approx 1/4 hour, or whatever setting will keep the fan running...
Apr 22, 2010 | Dacor ECS130 Epicure Electric Single Oven
Oven touches cabinet inner wall of cabinet. Fire hazard or not?
The rear of the oven has approx 3" or better insulation you are ok
Jan 17, 2009 | Cadco OV-250 Electric Single Oven
Grinding noise every now and then
If this is a self-cleaning model it is possible that the movement of the mechanical parts are at fault. Toward the back you should be able to find the motor and drive rod. Check these first and yes, there could be a loose or faulty fan motor.
How long is the sound there ?
Jan 22, 2008 | Cadco OV-400 Electric Single Oven
Blowing circuit breaker
If you live in Rancho Cordova, CA and need appliance repair service call us at 916 823 3070 or visit our website Rancho Cordova Appliance Repair 916 823 3070 Rancho Cordova CA
Sep 02, 2017 | Cadco OV-250 Electric Single Oven
Cadco OV-350 Electric Single Oven Logo
27 people viewed this question
Top Cadco Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Cadco Oven Expert? Answer questions, earn points and help others
