Question about Canon PowerShot SD600 Digital Camera
Lcd Screen brocken
Accidentally i drpped digita camera on the floor.while taking photo
i cannot see anything on the scrren it's blank.if check in the system photos r good.
if i have to replace the lcd screen means how much it will cost.
  • ampmmizak Nov 16, 2008
    LCD screen has what looks like pop art--unable to see what I am shooting
  • Ngengwa Jan 25, 2009
    Crashed the screen.Now inside is in pieces.
    Problem Solver:
  • 13 Answers
I think there are two different problems listed here.
1)Blank screen. This could be a couple things. If the screen is totally dark it may be that the backlight is broken or disconnected. since it is a little older camera it might not be worth buying a new one but it might be worth opening up and fiddling with the connections.
2)Pop Art. This sounds like a broken LCD. You can get a new one from canon for ~$50 and install it yourself. It is pretty straight forward but you will need some little screwdrivers.
images for changing a Canon LCD
Posted on Dec 27, 2008
It will cost u around Rs 3000 in Indian Rupee , and USD $50 if u get it from states
Posted on Oct 23, 2008
Blank screen
Ok did the lens open completely? Does the lens cover open. I have had a Panasonic do this once. If it opens the sensor most likely is gone, or the display. Sometimes if you are careful you can remove the back an check the connections to the screen by removing it an putting back on an it can clear the problem. Sounds crazy bit has worked a few times on other cameras. My guess is camera is gone an cheaper to replace.
Mar 22, 2014 | Fuji FinePix F401 Digital Camera
My LCD screen is blank on my Digital camera
Probably not...sounds like you did about all you can do.
Feb 17, 2013 | Cannon Cameras
When I turn my PowerShot A85 on the Canon Logo appears on the screen for a second then the screen goes blank. I can still take a picture, but can't use the display. Any suggestions? Thanks.
Does your camera have a button or switch on it that says something like this: "LCD Backlight" and "On/Off" for the toggle switch that goes with that LCD Backlight?
If I turn off the LCD Backlight on my digital camera, I cannot see anything, but I can take pictures anyway. When I turn that Backlight back on, I see everything I point the camera at, and can take pictures without problems.
The Backlight helps you to see what it is at which your are pointing your camera.
Makes a big difference. And you can accidentally hit that switch and turn it off without being aware you have done so.
-a.
Nov 19, 2009 | Canon PowerShot A85 Digital Camera
Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
Jul 07, 2009 | Canon PowerShot SD600 Digital Camera
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
Black scrren
Check out the following URL for help:  http://sanyoservice.com/pdf/images/VPCE6(OM)2.pdf
Feb 26, 2008 | Sanyo Xacti E6 Digital Camera
Blank LCD screen
you have accidentally turned the lcd pannel button off.just turn it on.
Feb 03, 2008 | Canon PowerShot A630 Digital Camera
Blank LCD screen
First, let's try the obvious. Did you accidentally hit the "DISP" button (bottom row of buttons, third from the left)?
If not, you mention you can see the photos on the PC. Do they look fine, or are they also black or distorted?
Feb 03, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
LCD monitor is blank
Canon would have to fix this for you. The fault may be the screen itself, or the LCD viewfinder drive IC on the camera's circuit board. In this case they will replace the circuit board.
Jerry G.
Dec 09, 2007 | Canon PowerShot G3 Digital Camera
Canon PowerShot Dropped: Blank Screen
For Ravi, this definitely sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info: http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
By the way, don't tell Canon that you dropped the camera. Sounds like the CCD imager was about to go bad anyway, and the drop just accelerated this.
Oct 31, 2007 | Canon PowerShot S230 / IXUS 179 Digital...
Canon PowerShot SD600 Digital Camera Logo
79 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
