Question about Canon PowerShot S1 IS Digital Camera
Flash is Stuck
I have the Canon S1 SI Power Shot, and the flash is stuck and wont come up. All my pics are coming out dark bc of it. How can i fix this???? i tried pulling it out but i dont want to break it.
You have to yank on the flash, its the only way. Mine gets stuck most of the time, but does open on its own on rare occasion. it must be a defect of the model.
Posted on Aug 24, 2006
My Canon Rebel Sii wont take picutres
And the battery is still ok? See the LCD display.
When the battery is almost empty, it won't be able to charge the capacitor in the flash, and the flash can't fire. The camera protects the shot, because if the flash was needed, the shot would be much to dark.
Feb 01, 2014 | Canon Eos Rebel Sii 35mm Camera Body
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
Dark on lcd screen when turn on. no display or picture.
A stuck shutter is another common failure mode for digital cameras, especially the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Also pay attention to the blurb there about Canon possibly fixing this for free (for the S2 IS only).
May 08, 2010 | Canon PowerShot S3 IS Digital Camera
I shot 200 pics w/Canon EOS rebel XT 8mp camera on a new San Disk Ultra 4GB card. All pics look like flash did not work. It was working and I've shot hundreds of pics in same place, same lighting, using...
The CF card has nothing to do with the information that is sent to it. It is just a recordable medium that stores what the camera sends to it. There is some other problem with the settings of the camera that caused the photos to be underexposed. Do you use RAW mode for capture of the images? If you do then the Canon RAW conversion software can batch process the photos to correct the exposure.
Apr 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
The display does not come on, there is a "busy" sign flashing
Sounds like the problem Canon had to fix for me with my S2 IS which did the same thing. My camera shot blank pics. It turned out to be a stuck shutter. The camera makes all the usual noises, but the shutter is stuck closed.
Sep 08, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Sony DSC W50 Camera - Trouble with Flash
Hi, I guess you are using the automatic mode ( not the "P" mode).
You should enable flash only when there is insuffient light. If you use flash in broad day light, your pic will be whited out. If you dont use flash in dark or low light, your pic will be dark or very dark.
So, when it comes of dark, try enabling the flash. If its still dark, increase the flash compensation (the eV value). If its still dark, increase the ISO number.
Hope these help.
cheers,
Sep 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
My camera wont stay on after i turn it on
Hi. It can be a problem with flash capacitor. To check if it is the case you should be able to power your camera at least for 10 seconds. If you can not power your camera for this time from batteries, try to use external DC 7.4V 2A power supply. After powering your camera just follow this procedure. 1. Turn on the camera. 2. Turn off the flash by pressing flash button (be sure that flash is OFF but not in AUTO regime). 3. Turn off the camera. 4. Turn on the camera. If after these operations camera can be powered from batteries and you can make pictures than the problem is in the flash capacitor which should be replaced. Or you still can make pictures with your camera without using a flash.
Jun 10, 2008 | Canon PowerShot S1 IS Digital Camera
Flash does not pop up when it on automatic
hello
unfortunately, the only solution is to return it to the store where you bought it from or call Canon. I had that issue when I first bought my camera and i had to return it to the store
Mar 07, 2008 | Canon PowerShot S1 IS Digital Camera
Canon S1 flash stuck
Mine does the exact same thing but I just pop it open manually when I need it. The great thing is that unless you have a very dark night shot you can pretty much shoot with out it, but don't be afraid to pop it out manually. It will close again!
Feb 20, 2007 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
