Question about Ovens
My hotpoint electric oven 317b6641p001 does not heat. Stovetop and broiler work.
Hotpoint oven does not work. Stove top works, oven does not. How do I fix it?
ngafm
  • 166 Answers
SOURCE: hotpoint stove fuse confirguration
Remove the old ones ONLY if you know what you are doing, and take them to the parts place with the modl # and serial # found on the tag plate!
Posted on Sep 07, 2008
SOURCE: MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
Posted on Oct 13, 2008
SOURCE: hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Posted on Dec 27, 2008
SOURCE: GE True Temp Oven not heating. Broiler works
we bought a new oven
Posted on Dec 15, 2009
SOURCE: Kenmore electric oven will not heat, broiler and stove work fine
I also have the exact same problem, is ther a possible fix-it-yourself solution for this???????????? if not what should a repair cost?????
Posted on Feb 07, 2010
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
The oven is not heating up, its not even turning on. there's no gas or fire. the stovetop is working. what can be the problem.
Since you didn't include the model number, I cannot check for you to find what type igniter the oven uses but if neither broiler nor oven will turn on, it is probably one that uses an electrical spark that isn't happening. If the broiler works, it is a 'surface' igniter and the one servicing the oven has failed. There is no gas because the flow is blocked if no ignition is occurring. This is an important safety feature otherwise the oven would just fill with unburnt gas and finally explode.
Jun 17, 2011 | Hotpoint Ovens
My Hotpoint electric oven no longer heats up. The top oven works but not the main one. How can I fix this?
HI, seen this before with the ge/hotpoint elec. ovens i worked on when i did apartment maintenance. One could be a bad control switch(knob u turn to turn on oven).turn on broiler and see if it comes on,if it does not that could be it.If it comes on it u might have to replace lower element,but could still be control switch not working for that section.But it will one or the other.
Mar 12, 2011 | Hotpoint Ovens
Hotpoint oven model rgb745wea1ww oven doesn't light. Broiler and stove top work fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 04, 2011 | Hotpoint Ovens
Hotpoint oven not heating up;broiler ok
the element is burned out, remove itand check it with a ohm meter. if it moves when you touch the leads to both sides its good if it don't its bad. ps i take them all the way out to check them. you must unplug the oven before repairs!
Jan 19, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Hotpoint oven glowbar not working
Dec 27, 2008 | Ovens
May 22, 2008 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
HOTPOINT ELECTRIC STOVE
two things---when you open the oven door do you see a button on the right or left side?if so thats a door switch and if its bad you will get no voltage to the element.the next thing is your hi limit is bad.this is a sensor that monitors the temp of the oven and if its bad you wont get any heat.some hi limits reset themselves others you have to manually reset them.let me know.
Jul 30, 2007 | GE JKP15 Electric Single Oven
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
