Question about Sony Cameras
Sony dsc-w200 camera works fine until memory stick is installed
After installing memory stick PRO Duo into the camera all functions will quit and then the screen will go blank. The power light will cycle slowly.After removing battery and memory stick and re-installing only the battery the camera will power on and work fine until memory is installed again! I installed the memory stick into my laptop and all the pictures are there!
  • 734 Answers
Memory sticks now have two types regular and HC. The memory stick is either nor or nand? The new high capacity nand flash cards can not be use in older cameras. Older cameras also have limits on the capacity that it can access. Read your manual to check out the size of memory stick it can use. Most stores sell large capacity memory sticks only good for new digital cameras. you may have to buy older flash cards on ebay.
Posted on Feb 09, 2012
SOURCE: Memory Stick error c:13:01
The problem is compatibility - or lack thereof. The older Sony cameras such as DSC-S50 (I have one), which used the original version of the Sony Memory Stick, can't read the new Memory Stick Pro - even with the "Duo" adapter.
I don't know all the specifics but it has to do with how the memory chip interfaces w/ the camera, how the data is transferred -- newer models of chips/cameras use a different, faster method for data transfer which the older cameras/devices can't do. Similar to "serial" vs. "USB" vs. "USB-2" issues with older computers.
So, sorry to say, but if you have a DSC-S50 camera like I do or similar older model, you're stuck w/ the standard Memory Sticks - which I have just discovered are very hard to find any more. I just finished a sweep of all major electronic stores/outlets in my area (silicon valley - where there's plenty of them), plus many web sites. And all you can find new, now, are the Pro/Duo chips, 1GB & up.
Anyway I hope this helps!
Posted on Jun 07, 2008
welcomejee
  • 10594 Answers
SOURCE: sony memory stick pro duo format error
Use this memory stick in other Sony camera to confirm it. Problem still exist means memory stick is bad/ internal breakage.
Posted on Jun 12, 2008
welcomejee
  • 10594 Answers
SOURCE: format error
If Duo Pro got hardware problem, then it can not be fixed and you can't retieve data on it. Regarding new memory stick, camera will check it and let you know about format it or not.
Posted on Jul 31, 2008
SOURCE: DSC F707 Error C:13:01
If you really have a F707, it won't work with anything over 128MB according to this chart.
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCF707#m1
Posted on Aug 11, 2008
  • 586 Answers
SOURCE: Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
    This error code is for Memory Stick. the Countermeasure are :
Format the “Memory Stick” or internal
memory.
CAUSE :
“Memory Stick” or internal memory is
unformatted.
Thanks for using fixya.
Posted on May 24, 2009
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
Can sony digital camera dsc w 80 support 4 gb memory card pro duo
Yes, DSC-W80 manual says it supports "Memory Stick Duo" up to 8Gb, but there is also a comment that movies with the size set to 640[fine] can only be stored on a "Memory Stick Pro Duo" so therefore they must be compatible.
http://www.docs.sony.com/release/DSCW80.pdf
Mar 23, 2011 | Cameras
Bought used camera Sony Cyber Shot Model DSC-P32. What Memory Stick do I need?
You can use Memory Stick standard, pro or pro duo up to 2GB with the Camera.
    A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo™ or MagicGate Memory Stick Duo media.
I have provided the Memory Stick compatibility chart for your reference.
http://esupport.sony.com/US/perl/support-info.pl?&info_id=12&mdl=DSCP32
Feb 09, 2011 | Sony Cyber-Shot DSC-P72 Digital Camera
Sandisc 4 GB memory stick PRO Duo not working
According to the users manual, the camera does not support above 512 MB cards, however I noticed that there is a firmware update which might address the issue. Go to www.sony.com and support, electronics. Put your model number in the selection box and you'll be taken to the drivers download page.
Feb 14, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Does Sony cybershotdsc w 220 digital camera supports 4 GB SDHC memory card
the dsc w200 can easily handle 4 gb memory stick duo and duo pro but not SD cards ..
Nov 29, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Can i use a memory card SDHC for my digital camera sony cyper shot DSC-w200 or not?
According to Sony, your has 31 mg of internal memory and can use either Memory Stick™ DUO Media, or Memory Stick DUO PRO™media
The information is below:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=20008504#specifications
Sep 19, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
No memory space in internal memory-no more pictures can be taken!
there may be two problems. 1. Format your card before using it. 2. Switch your storage device to memory card and it will work. Hope it works..:))
Mar 10, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
Cameras Logo
123 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
