Question about Philips GGE908
Why my gge908 recoil controller wont work on my pc
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 141 Answers
Update ur system
Posted on Feb 09, 2012
HOW TO FIX MY TORO RECOIL
You need to probably replace or put the recoil spring back in place.,You have to take the recoil off to do it.
Jun 22, 2014 | Toro Power Lawn Mower
I haev a controller for my acer laptop. and it installed somthing when i put it in usb drive but its not working i have windows 7 is it compadable? its a GGE909 recoil controler
When you inserted the device into the USB port did it apply the generic driver? Have you rebooted the machine. Did it come with a installation disk? Is the game controller in Device Manager or in Control Panel, Devices or Printers?
Feb 25, 2013 | Computers & Internet
Have champion 3500 watt generator recoil pull cord wont recoil HELP
need to take the recoil off the engine and check for a broken recoil spring, depending on the engine if it is a honda, they sell a replacement recoil unit, anything else and you will have to get creative....try tapping on the recoil with your palm and see if it trys to rewind, if no resistance or movement when bumping is a good indicator of a broken recoil spring....
Dec 14, 2011 | Electrical Supplies
Pulley cord wont go down unable to start on gas trimmer
Your cord wont recoil?
You should remove the recoil cover and see if you can rewind the rope manually.
It isnt too hard and will let you know immediately if you need to replace the recoil.
Just the recoil unit by loosening the three or four bolts and lift it off the trimmer. Turn it over and look at the recoil spool. There should be a notch in it. This is were you catch a bit of the starter rope and start turning it in the direction of normal rotation. Normal rotation will put tension on the recoil spring.
When you put 4-6 turns into it just let it recoil and see if it pulls all the rope back in. That's it. If the cord didnt recoil something inside the recoil has broken and you need to get the unit serviced or replaced. Most of the time the cost of repairing something like this is prohibitive. Its a better idea to just replace the whole unit.
Good luck and be careful!
Aug 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Recoil starter wont let me pull it out
I would think that your engine control cable has gone bad. There is a brake on your flywheel and your engine control cable releases this brake, this cable is hooked to the handle that you have to hold down to start the engine. you can remove the engine cover and see the brake against the flywheel, pull the handle and see if the brake is releasing. If it is releasing then something in the recoil is defective. I hope this is of some help to you.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
The recoil turns but the crank wont turn at all. is it ceased up?
if you can pull the recoil full out then the fault is with the recoil remove recoil and try to turn crank by hand
Mar 15, 2010 | Coleman Powermate Premium Plus 6250W...
The USB part has broken off my GGE909 Game Elements Recoil PC controller. I want to know if I can use a different USB cord to attach to make the GGE909 usable again. Is it possible to fix?
The GGE909 uses a flat ribbon cable with eight wires, and has a spring loaded spool to store the cable.
Using a standard cable might work, but the new cable probably won't retract in the spool.
Sep 05, 2009 | Video Game Consoles & Games
Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Philips GGE908 Logo
591 people viewed this question
Top Philips Video Game Consoles & Games Experts
James Wishart
Are you a Philips Video Game Console and Game Expert? Answer questions, earn points and help others
