I put a new black ink catridge in and my printer won't print black at all.
Check the cartridge has loaded properly, then within printer properties, align the heads and clean them, see if this helps.
Posted on Oct 23, 2008
The black ink won't work even though its new
check if the noozles are on the catridges or on the independent print head. if the print head is seperate from catridges, them try print head cleaning. if you it cant work. then dip the print head in hot water for 5 to 10 seconds. dont dry it just put it back into the printer and try again immedeately. let me know if your problem is fixed
Jun 24, 2012 | Brother MFC J6510DW - Multifunction fax /...
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
Words are not printed clearly in black ink. strokes through them
Your black ink has finished, try and get a new black ink catridge, remove the black ink to get the no on the catridge. good luck
Aug 24, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Can i use my scanner without putting in a new ink catridge in
no,both ink cartridges should be installed into the new ink cartridges from kodak online store if u want to buy.
Jul 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Epson 1400 won't print blacks
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Won't print black ink
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........
Unplug the Power Supply from the printer.......
Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button..........
Now the Printer will ask for the Date Time and Country Language.........
Set everything up......
Now try to Print i am sure it should work..........
Good Luck............
Feb 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
214 people viewed this question
