The new cartridge which you have installed are not detecting by the printer.
either they are faulty or they are not inserted in the printer properly.
also check whether the new cartridges you had installed are of same number as you were using before for printing.if it looks same but the number is different then it will not support.
just power OFF the printer remove all the external wires connected to the printer from its back.remove the power cord from the electrical outlet.wait for 1 minute.then reconnect all the wires firmly and properly at their respective places and then check .it may work.
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
The Power Light Flashes Orange - Error Codes
When
an error occurs, the power light flashes orange. The number of orange
flashes followed by a long green flash indicates the cause of the
problem. Two orange flashes:Out of paper, paper jam, or paper feed error
If
no paper is loaded in the auto sheet feeder, or if the paper is not
loaded correctly, set the paper correctly and press the Resume button
on the printer to continue printing. Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly
Remove
and reseat the cartridge correctly. Make sure the orange protective cap
and tape have been removed. Make sure the blue locking lever is locked
down securely. Six orange flashes: BJ cartridge (printhead) is not installed
Remove
down securely. Seven orange flashes: BJ cartridge (printhead) is defective
Remove
the BJ cartridge and check that the contacts on the cartridge and
cartridge holder are clean. Make sure the orange protective cap and
tape have been removed and reinstall the cartridge. If the error occurs
again after you resume operation, you may need to replace the BJ
cartridge. Eight orange flashes: Waste ink absorber almost full
The
printer has a built-in waste ink absorber to hold the ink that is
consumed during print head cleaning. This error indicates that the
waste ink absorber is nearly full. Press the Resume button to skip the
error so you can continue printing. The POWER light flashes orange and green alternately: Service error
A
service error means the printer requires the attention of a qualified
technician. Count the number of flashes. (You may be asked this
information.)
There are some possibilities due to the above phenomena. Let's discuss about it: 1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green. 2) If the CHARGE/ERROR light is flashing orange with beep 3times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue. 3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3times, then your printer may facing a very serious error and maybe need a replacement.
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see?
At any rate here is the code:
Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician.
If you have any more questions let us know otherwise please don't forget to rate this post.
