Question about Panasonic Audio Players & Recorders
Panasonic SA-PT660 no power
I had the Panasonic SA-PT660 in my living room and it worked great . I replaced it with a bigger, beefier system. I saved the 660 for use in another room. Well, the unit has been sitting for a while and when plugged in it no longer powers up. Is there a reset or anything?
ginko
  • 19396 Answers
SOURCE: Unlock Panasonic SA-PT660
I will see if there is any known hack for this model, some unit does not have any unlock procedure.
Posted on Sep 11, 2008
  • 4234 Answers
SOURCE: sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Posted on Apr 09, 2008
  • 18 Answers
SOURCE: garmin 660 locked up / frozen
Resetting the device merely resets the power connection, on some devices there is a reset to manufacturer defaults on settings, but not your stored data. Working with GPS's 40 hours a week I constantly have to use the reset button when they lock up. Just press it in for a few seconds then if it doesn't power back up just hit the power button and everything should be fine.
Posted on May 09, 2008
SOURCE: Panasonic SC-Pt 660
I fixed the main problem. It has inputs, not labeled as such. one set right next to all the outputs labeled only aux.after plugging in to the TV outputs, and putting the unit on AUX, this was fixed. The surround speakers were harder to work out, After downloading the manual, I was able to get sound out of them, however at a lower level than all the others. Even following the speaker level adjustments in the manual, cant get more volume out of them...I'll keep trying.
Posted on May 28, 2008
SOURCE: Panasonic SA-HE100 5.1 system error code F70
I was able to fix this problem by replacing a fuse. Remove the cover (7 screws). Directly behind the fan are 2 boards with 5 fuses on them. The boards are 1 over the other. The fuse I replaced was labeled F5 and on the top board with the fuse facing down on the underside of the board.
Posted on Jun 23, 2008
I had to replug things in for my dish and unit sat sidewards to get to plugs. It now says locked and can eject disc, select source. Help
Try this:
Press and hold [?] (Stop) on the main unit and [>10] on the remote control until "INITIALIZED" disappears from the TV. Turn the unit off and on again.
All settings should return to the default values.
Not saying it will work though!
Not
Dec 31, 2015 | Panasonic...
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
SA-PT660 service manual
I'm not sure if You're really looking for service manual or user manual. If You need the former here's link to one SA-PT660P service manual
Aug 06, 2012 | Panasonic Audio Players & Recorders
How and where can i get a new panasonic dvd for my home theather system. model number sc-pt660. the disk changer does not open and close.
Considering that this unit comes as a bundle it wouldnt be profitable for stores to carry the parts seperatly. The best bet here would be if it still is within the 30 return policy then to take it back to the store you purchased it from to swap out for another. Since Im sure this isnt the case or you would have already done this you can try to save a dime by searching ebay for part systems and repairing or replacing the problem part in your tray (specifically being the tray motor). Theres plenty of tutorials for similar products found on DIY.com. Heres a link...
http://cgi.ebay.com/Panasonic-SA-PT660-5-disc-DVD-player-SC-PT660-AS-IS-/370503039935
May 05, 2011 | Panasonic Televison & Video
Resubmitted: How do I resynchronize my 5 trays in the DVD player portion of a Panasonic SA-PT660. A manual seems unavailable or I would not have posted here.The only manual I have seen a clue to exists in...
  • Here is a manual that will server your purpose. It is not the exact same model manual to a 'T' but I looked it over real well and it is for your unit too. Your gonna go down to page 16. This is for a model SC-PT660. same unit really.
http://static.highspeedbackbone.net/pdf/Panasonic-SC-PT660-Manual.pdf
Regards, Tony
Apr 27, 2011 | Panasonic Televison & Video
208 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
