Question about Fisher and Paykel DD60DCW6 Dishwasher
How to replace dishwaher door handle - Fisher and Paykel DD60DCW6 Dishwasher
Door locked shut
Hi found myself in same situation. Press in latch and insert fingers upwards there is a grey plastic strip push this up with fingers and door should open. Note upward press needed where this catch meets front of machine so just slide fingers up from latch/handle. There's actually no need to take top off to enable this.
Dec 27, 2013 | Smeg STX2 Dishwashers
Dishlex 300 blobal dishwasher. have set dishwaher for normal wash as usual. All lights are one but dishwaher will not start. help please
It is likely the door switch is not engaging properly. Check the gasket is set properly and the door is closing when you shut it. Also confirm if it is not on delay start.
Feb 13, 2011 | Electrolux Dishwashers
My 20 year old dishwaher just broke its lock. Somehow it seized when I locked the door. My husband took it out but we still cannot open its door and take out the dishes. The handle fell out when he tried...
YOU HAVE ELIMINATED THE EASY WAYS, ARE YOU PLANNING ON REPLACING IT OR REPAIR, IF REPAIR CALL A TECH. IF REPLACE, THE LOCK MECHANISM IS AT THE TOP CENTER OF BODY. ACCESS WOULD REQUIRE REMOVAL OF D/W, AND ASSOCIATED CLEAN UP OF THE WATER LEFT. JUST REMEMBER THAT YOU HAVE BREAKABLE DISHES INSIDE. WHEN YOU PROCEED. YOU MAY UNPLUG AND REMOVE THE SIDE SCREWS AND SEE WHAT IS EXPOSED WHEN YOU REMOVE THE BLANK FRONT METAL PIECE.
Mar 10, 2010 | Dishwashers
Ariston LI 45 door will not remain closed and will
Strip the door and re-set the switch. Ensure the metal part of the catch on the machines main body is not distorted
Jan 31, 2010 | Ariston Technologies Dishwashers
Dishwaher will not start a cycle
if your having to wiggle or move the door to get it started then its your door latch/switch.you can take apart and inspect or just get new ang install.God bless ,tom
Jan 04, 2009 | Kenmore 15129 Built-in Dishwasher
MY DISHWAHER WHEN IN CYCLE HAS WATER LEAKING FRON THE FRONT DOOR.
there is some damaga in the rubber sealing please see that and change that front door rubber sealing then you ll find water not leaking after that.........
Sep 11, 2008 | Whirlpool Dishwashers
MR WILLIAMS
Hi error code A13 means the soap dispensor on the inside of your dishwaher door is shorting out and will need to be replaced.
This is a fairly quick job and is relativly cheap to do
Dec 10, 2007 | Dishwashers
Frigidaire dishwasher bottom door gasket replacement
thank you so much for this information it was a god send
Oct 07, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Maytag
If the door handle appears loose, you could have a broken door latch which will prevent the dishwasher from running if the door is not able to latch properly. The latch usually has two micro switches that are pretty delicate. Not to accuse you of abusing your appliance, but if you're in the habit of slamming the dishwasher door shut, you could inadvertently break the switches in the door. The switch assembly and handle are sold separately, so you may need to purchase both. Let me know if this helps.
Jul 08, 2007 | Maytag PDB3600A Built-in Dishwasher
Fisher and Paykel DD60DCW6 Dishwasher Logo
32 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
Alan Matzke
NOEL
NOEL
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
