Question about HP Pavilion dv2911us PC Notebook
Hp laptop has blinking red square above touch pad, comp. won't allow for reboot or restoring to factory conditions
I've been able to reboot to factory conditions several times a year after backing up on alternative hard drive, the prompt screen "f1, f 3, f4 ect. never accepts entered options, "reboot system" factory restoration. whatever I choose usually f8 -directs me to start windows normally, and which the enter or accept key won't accept or enter.
  • 734 Answers
If you do an illegal shut down which is power off by holding down the power switch for 8 seconds. The HP computer will then boot with the scandisk program, which will restore your hdd to perfection. Windows XP or later now use 'system restore' to rearrange registry from a previous calender date that the computer used to work perfectly.
Posted on Feb 09, 2012
2 Suggested Answers
alberleu
  • 98 Answers
SOURCE: No puedo encontrar la tecla para bootear, he
ES F10 PARA HP. SI NO VE A BIOS PRESIONANDO F2 OR ESC Y CAMBIA EL BOOT ORDER.
Posted on Dec 03, 2010
My laptop uses all RAM
clean your registry and turn off unneeded programs,get advanced system care pro,free,run it and reboot,then if that works good,buy the full version,it will keep your comp running well Advanced SystemCare 8 Free
Jun 11, 2015 | HP G60-535DX 15.6in Laptop PDC 2.1G3GB...
HP G56 Notebook PC. I have been trying to reboot my laptop but the restore system is not working. I can do a system restore but not a reset to factory settings. Any ideas anyone?
A system restore is actually as per factory setting. You will or should end up with the laptop just like the first day you got it.You won't have any of your stuff on it any more though. you will lose your picture and other documents during the process. If you are thinking of a system rollback which some versions call a restore that un-installs updates and other bits that might be causing problems.
To do a factory on an hp you just press F11 during boot or select it from the boot screen if that is set to show. It then asks if this is what you want to do and wipes everything out before setting up the operating system again. You can also boot from your restore dvd. This can either be a factory provided or ones you did when you first got the system. If you have Vista you may find the boot restore and the restore disks are useless. I've had several hps with that problem happening on top of the original issues. There were defaults in the files and the only way to fix was to order a new dvd from HP.
Past these basic things you can do you may have to take it to the shop as more software/tools will be required.
Sep 06, 2012 | HP Computers & Internet
Touch pad light doesn't come on
Download and reinstall the touchpad drivers.
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Touchpad drivers.
Apr 24, 2012 | Computers & Internet
My ph pavilion dv7 touch pad's light is off, what must I do to get it on again?
Looking at a picture of the laptop, it is like most HP computers. There is a button directly above the touch pad. This is your on/off button. Press it and wait a few seconds, and the light should turn blue.
Mar 16, 2012 | HP Pavilion dv7-1137us Notebook
How to restore my laptop to its factory settings
Proir to restoring computer devices, ascertain that resources that would require backup is securely preserved. For example, computers loose resources least complented by the manufcturer with restoration to factory settings. Also significant is consulting with technician to ascertain the condition of device that least require facory settings. Usually a condition is resolvable with an alternate means least requiring factory settings. Prior arrangments that make restoration attainable includes acquiring the tool resources either as disk roms that contain programs. Usually the computer manufacturer would have provided the restore resources either as disk roms either CD or DVD. Recent computers however have built in programs restore media in which instance restore is possible without disk roms materials. Depending on the condition of the computer considering recent innovation would either require disk material to attain restore or builing functions. Usually refering to the computer support experts with conditions that are encounted would attain means to resolve.
Feb 19, 2011 | HP Mini 210-1030NR Netbook
Tap-click reset on Reboot
This should do it Restore Factory settings OR Make sure your driver is OK. Cheers
Nov 30, 2009 | HP Compaq Presario V2000 Notebook
My HP Mini touch pad is locked up. There's a red light right above the touch pad that is usually white.
on the new hp mini - you double tap the touchpad indicator (upper left) to toggle the touchpad on & off
Oct 30, 2009 | HP 2133 Mini-Note Notebook
I want to restore my DELL LAPTOP to the factory settings?
Okay, do as follows.
(a) Boot the computer. When you see a blue bar with www.dell.com on the screen, hit Ctrl + F11.
(b) On the next screen, click "Restore".
(c) Next, click "Confirm".
(d) Let the restore process run. It will probably take 10-ish minutes. Don't touch it while it's doing it's thing.
(e) When prompted, click "Finish" to reboot the computer.
(f) When prompted, click "Yes".
(g) When prompted, click "Next".
(h) After the computer restarts, click "OK".
Dec 29, 2008 | Dell INSPIRON 6000 CENTRINO...
HP Pavilion dv2911us  PC Notebook Logo
90 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
