Sony wega kdf-e60a20 clean behind screen
I bought my tv refurbished from sony and I didn't notice for some time that there is a gap on the bottom right between the screen and the face plate. This didn't affect the picture quality at all but now after 3 years of people smoking and general **** in the air I have noticed some discoloring in this area compared to the top left of the screen. I would really like to know how to remove the screen so that I can clean the back of the sceen and maybe fix my gap. Ideally I would like to find a link to a service manual but any help getting to the back of the screen would be good.
SOURCE: sony kdf-e60a20 problems
Replace the main lamp( sony XL-220). Step by step instructions in owners manual, takes about 10 minutes and is very simple.
Posted on Dec 24, 2008
  • 4 Answers
SOURCE: screen appears blue
It's the Light Engine (also called an Optical block) -very expensive.
Posted on Jan 08, 2009
  • 197 Answers
SOURCE: Sony Grand wega KDF-E50A10
bad lamp
Posted on Jun 07, 2009
  • 16 Answers
SOURCE: sony 60 model kdf-e60a20 wega
KDF-E60A20
Posted on Dec 03, 2009
  • 308 Answers
SOURCE: On my KDF-E60A20 there is a yellow discoloration
the light engine is failing.
Posted on May 02, 2010
I'm having the same problem with my tv (wega sony kdf e60a20) just like a few other people here, with the sensor cutoff fuse, how do you replace this item?
If you mean the thermal fuse, the set should have a red blink code of 5 blinks. The thermal fuse is way inside on the frame of the lamp housing but can be tested with rear cover removed.
If you have one bad the red blinking light will have to display some code.
Dec 22, 2012 | Televison & Video
Cleaning an LCD chip on a Sony TV
Use only a lens cloth and some dust is normal.
Jul 17, 2012 | Sony KDF-E60A20 60 in. LCD HDTV
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60 model kdf-e60a20 wega
is the led blinking anything? When was the last time you replaced the lamp? A bad lamp can cause this kind of problem.
Dec 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
I have a Sony WEGA KDF-E60A20 the screen goes dark with no sound intermittently. Will replacing the lamp solve the problem?
i have the same problem and i am finding out that the lamp replacement is the problem but make sure when replacing bulb to wear latex gloves and clean all of the dust out of the tv to extend the life of the new bulb. hope this helps
Oct 12, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
On off on off on off
possible cause is the thermal fuse for the light bulb which is the back of the tv, next to the cooling fan.
Dec 29, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I noticed a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Aug 22, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
KDF-E60A20
do this for me turn off tv hit the follow hit this button display,5,vol down, power and till me the error code for this set this a have a
cpu in them ever time the led blink on front of set that mean thear is some pu with tv. so chech it and git back to me with code
thank you. bob..
Jun 12, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have this sony kdf-e60a20
lamp is monitored by an over-current protect circuit. When the lamp starts drawing a little more current than normal, the set starts shutting off the video and audio then in a couple minutes restrike the lamp. Unique to sony WEGA's, replace w/ new type xl-2200u, you should be o.k.
May 03, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20 Going on and off by itself..no blinking lights
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
hope this helps.
Dec 05, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
