Question about Air Tools & Compressors
MasterGrip Air Impact gun # 690742 - Air Tools & Compressors
2 Suggested Answers
  • 108 Answers
SOURCE: My Aircat 1404BG impact gun stopped working.
most of the problems accure from being dry try 2 or 3 drops through the air intake fitting every so often depening how much you use your air tools, it may be time for a new one but i would try the air tool oil first before bying a new one, i hope i helped.
Posted on Jan 02, 2010
My newish SIP TN3/100D v twin compressor will not pump above 100psi !!??
100 psi is capable of running the gun
what the problem is the volume of air supplied to the gun
check the specification requiring the air usage for the gun against the volume supplied by the compressor
if you gun requires 20 c/ft of air /min and the compressor is only capable of 15c/ft of air /min, then the volume is too low so the pressure will not build up
modern impact 1/2 guns will operate quite well on 80 psi unless the gun is leaking internally
another point is this-- impact guns come in two configurations-- single hammer and double hammer
double hammer give 2 hits for each revolution of the air motor and there fore use less air to do the job
add the fact with 2 hammers , the torque applied is generally higher than single hammer units
the reality is this , the compressor capacity in c/ft/min should be 2 times that required or used by the tool
Sep 20, 2016 | Air Tools & Compressors
Will 3.8cfm @90lb pressure air compressure 10 gallon 125psi work with impact wrench at average air consumption 8cfm
Air tools demand volumes of air; a 10 gallon is good for something like a finish nailer, or staple gun, or even a nail gun.
It will run the impact wrench, just not for very long, like 10 to 12 seconds if you're lucky.
Most compressors tell you what types of tools they are made for.
And impact gun is best matched with a 21 - 26 gallon compressor.
Nov 03, 2015 | Air Tools & Compressors
Kobalt 1/2in air impact wrench will not take off any nuts. It will hammer 1 or 2 times then air will by-pass out the exhaust. It works good putting nuts on.
Make sure that you have 90 psi of supply air. If you are not running an inline oiler run some air tool oil through the gun.
You could even try running some gum solvent through the gun to clean it. If it still does not work you may have to replace the two o-rings and bushing on the reverse switch shaft.
May 22, 2015 | Impact Air Tools & Compressors
Mastergrip hvlp paint sprayer
Probably have a blockage in your airbrush. Disassemble the air brush and clean thoroughly. Be sure to disassemble and clean after every use session. Be sure to mix the paint. If the paint has settled, it may be too thick to spray.
Oct 20, 2013 | Air Tools & Compressors
I have the titanium 1/2 impact gun and in foward or reverse the gun some times stops working and just blows air like a bad o-ring but i really dont know thanks
The vanes in the air motor are worn. There is a flat spring that pushes the vanes against the cylinder to maintain a seal... They go weak after a while
Aug 15, 2011 | Ingersoll Rand 2135PTI Pneumatic Titanium...
How do you oil a Craftsman Air Impact Wrench Model No. 875191182?
Just put 3-5 drops of air tool oil down the air inlet coupler and then run the gun for 5 seconds. Do this everyday that you run the gun for best results.
Feb 25, 2011 | Craftsman 1/2" Impact Wrench
I need an owners manual for a Mastergrip paint sprayer. It is a 10-pc set and I got it without any instructions. Does anyone know how I can get an instruction manual or owners manual?
I have a Mastergrip HVLP Paint gun set up with the manual. If you would like me to copy it for you, I will. I can also answer questions for you. Ken
May 07, 2010 | Air Tools & Compressors
Jan 02, 2010 | Impact Aircat AC1603 3/4" 1330 Ft - Lbs...
Craftsman 1/2' impact gun
Use a good grease. Don't pack it, just lube the parts. If it is all together, put in about half an ounce of air tool oil through the plug.
Apr 15, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
384 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
