Question about Tools & Hardware - Others
Rockwell sander grinder model 31-352 manual?
Model 31-352 1" belt sander
SOURCE: looking for a manuel for a makita belt sander model #9401
I have just purchased a Makita 9401 belt sander however, have no manual and it is unclear how to change the belt. Any help would be appreciated.
Thanks
Joe
Posted on Mar 15, 2009
  • 384 Answers
SOURCE: Tool Shop Belt sander - can't align belt tracks to thee inside
The problem is that you have not set the adjustment properly. Back off the adjustment screws,slide on the belt and center it over both rollers, addust a little at a time both screws, after belt begins to tighten up stop adjusting. Turn the power switch on for about 1 second. Is the belt tracking? Adjust as necessary. Try the power again for longer and longer periods untill belt tracks in the center of the rollers. Tighten nuts to keep adjustment screws from backing out.
Posted on Jun 12, 2009
SOURCE: User Manual for Delta 31-460 Sander
I'm not sure if this is the correct way to post a response, but I have a manual for Delta 31-460 sander. Let me know if you still need one.
Posted on Oct 22, 2009
SOURCE: broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
Posted on Jun 16, 2010
  • 40 Answers
SOURCE: I need manual for Craftsman 315.11720 belt sander
On my model 315.11720 3"x21" Craftsman belt sander to change out sanding belts you push the front roller in until it clicks to lock in its retracted position (a pry bar may help here), switch out sanding belts then unscrew the tracking tensioner a bit on the opposite side with a allen wrench until the roller snaps back in place. I never remember anything about using a screw driver to force it back forward position again. Then readjust the tracking if necessary with a few short sanding load tests and you're good to go. Oil is dropped in the front roller center by removing the flat head screw - it should say "Oil Here" around the screw.
Posted on Aug 19, 2010
Where do i find a dust bag for a rockwell belt sander model rc4355k
If you have the instruction book there could be an exploded diagram and parts list and instructions where to buy spare parts.
You could ask the retailer where it was bought.
You could try the manufacturer's website.
Failing those options there are lots of websites providing a spare parts service for power tools. Just google spare parts for your model of power tool...
Oct 24, 2016 | Sander Tools & Hardware - Others
I would like a pdf copy of the manual for a Rockwell 361 belt sander?
this covers the 361
some one loaded the instuction booklet side ways
page 6 is the belt fitting
14 pages
http://www.manualguru.com/rockwell-sonicrafter/361c/users-manual/page-4
Apr 29, 2016 | Tools & Hardware - Others
Where can I find a Manual for?
The manufacturer's website might have a pdf or similar in its support page.
Aug 21, 2014 | McFeelys Dayton Belt & Disc Sanders 2" X...
How to replace the sanding belt
Google the model number and "manual".
Mar 24, 2014 | Rockwell RK7866 Belt Disc Sander
Slow to start oscillation, at times will eventually get to high oscillation. any suggestions or resolutions ?
I solved my problem , by taking it into pieces and found the bearing needed to be clean with super penetrating lubricant PL-100, then blowing air. Now ,work like a new one
Sep 25, 2013 | Rockwell Speed Block Sander Model 330
Need switch for milwaukee model no 6066 serial no 0075355593 sander/grinder.please help THANK YOU.
Part # 50
http://www.ereplacementparts.com/milwaukee-6066-ser-753a-sander-parts-c-131_4779_5141.html
Aug 12, 2013 | Milwaukee Tool Milwaukee 6066 - 6 7''/9''...
Need a manual for a Craftsman belt & circular sander
I found a PDF file on Sears.com website for the original manual for my belt / circular sander.
Oct 21, 2009 | Tools & Hardware - Others
Looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Dec 26, 2008 | Tools & Hardware - Others
Tools & Hardware - Others Logo
513 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
