Question about Minolta Office Equipment & Supplies
Konica minolta bizhub 750
Como retiro la unidad de fusion de imagen de una bizhub 750?
  • Minolta Master
  • 6,161 Answers
What about it the code or the location of the problem
Posted on Feb 18, 2015
  • 3 Answers
SOURCE: c451 Bizhub Konica Minolta printer
press utility. press metercount. press metercount details. press stop 0 0 stop 0 1 to access service mode in service mode look for admin initialialation function
Posted on May 22, 2008
checkitright
  • 1362 Answers
SOURCE: Konica Minolta Bizhub c350 error code c-0510
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Posted on Sep 26, 2008
jqsababa967
  • 145 Answers
SOURCE: KONICA MINOLTA
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Posted on Nov 04, 2008
Bubbabear64
  • 2794 Answers
SOURCE: konika minolta
CDC##  Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
Posted on Nov 07, 2008
  • 44 Answers
SOURCE: How do you do a hard reset on a Konica Minolta BH 600?
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
Posted on Nov 29, 2009
Tengo una television sharp y no se como programarle el control universal dish podrias ayudarme con los codigos y la manera en la que se programa
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Sharp. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 628,739,741,605, y 835. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Apr 04, 2011 | DISH Network IR Remote Control
Hola. el prblema que tenia al principio con este
CERTIFICADO DE EXPERTOS AQUI TV, siga esta información que he proporcionado tres soluciones de largo a este tema / s
Solución 1
Antes de empezar a desmontar cosas, le permite probar su simple rutina retire el enchufe de alimentación y sistema de poder una copia de seguridad. También, por favor, intente su unidad en una canales diferentes para ver si el problema persiste en cada canal. Su principal del Consejo, Power Board, T-Consejo Regulador se sospecha que los problemas en este momento. Pulse y mantenga pulsado el botón de encendido durante unos 15 segundos, la unidad debe apagar por sí mismo después de haberlo encendido. Si no es así, entonces no te preocupes. Quiero saber si el problema persiste. El primer enlace a continuación le llevará directamente a la guía de solución de problemas si tiene que seguir adelante con el mismo error.http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Información adicional No se pudo TV y Monitores: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plaguepartes: www.shopjimmy.com
Le permite centrarse en la parte externa de la primera serie de televisión (95 por ciento de todos los problemas de la televisión están relacionados con cosas externas a la propia televisión) Compruebe la conexión física de todos los cables mediante la eliminación de cada cable pelado o RCA y volver a instalarlo (Cada cable de potenciaasí), una vez que haya quitado un cable, compruebe que no se deshilache, y si ya está desnudo, de empalme de una conexión nueva y fresca para ello. 5. Asegúrese de que NO hay otras radios uneeded, el sistema de las cercanías.estos sistemas, cuando se enciende, hará que la interferencia electromagnética y evitar que más que grave la interferencia de televisión SURGE PROTECTOR protectores contra sobretensiones representan más del 75 por ciento de las fallas eléctricas a los equipos de estéreo. Vamos a empezar con su toma de CA de pared. Es norma en América que 220 voltios de fuera de estos puntos de venta. Esto implica que cada dispositivo va a utilizar 220 voltios (dentro de esa zona de la red). En todo caso incluye un reloj de alarma está conectado a cualquier enchufe de salida de CA en las proximidades del equipo estéreo / TV, causará interrupción eléctrica, electrónica e impedir incluso de encender! El televisor necesidades dedicada energía eléctrica.Si el televisor se encuentra en la sala a continuación, desconecte todo lo demás en la sala de estar. Permite conectar el televisor a una toma de Dedicado. Revise todos los interruptores de luz para asegurarse que el poder es para el que toma. Compruebe el cable de TV para Desfibracion tanto en el extremo de la pared de CA y donde se conecta a la televisión.Compruebe todos los puntos de GFCI para garantizar que todos los botones rojo de reposición se empujan, compruebe los interruptores automáticos para la conexión adecuada y que están encendidos. Ahora, vamos a tratar el televisor sin que relacionada con cualquier servicio de cable, vídeo, dvd, equipo de música, etc Por favor, responda si hemos encontrado una solución.
Cuando la reparación de estas unidades, hay siempre varias variables a considerar. Primera visita para ver lo que ocurrió por última vez con la unidad, como hicieron los hijos juegan con videojuegos, ¿la electricidad salir debido al mal tiempo. Usted puede ver que hay muchas posibilidades, pero vamos a concentrarnos en lo que se produjo el pasado a la unidad. Una vez que determinemos lo ocurrido el pasado, podemos identificar la causa real del problema. La causa real puede estar asociada con problemas de proyección, las versiones anteriores (tubo de imagen), la interferencia de los dispositivos en las cercanías, e incluso una radio encendida y situada muy cerca de su unidad. Esto es normalmente conocido como interferencia electromagnética a la electrónica y es muy común el error que usted ha proporcionado hoy. Por favor, seguir buscando algo externo a la unidad antes de ver los componentes internos. He estado trabajando en estas mucho tiempo así que siéntete libre de seguir conmigo.
Jan 24, 2011 | LG Studioworks 552V 15" CRT Monitor
Necesito driver de escaner de bizhub C350, no se si me podras ayudar solo del escaner por que tengo de printer
Hola buscalo en la pagina de konica Minolta driver en support es que esta nombrado como twain
Aug 18, 2010 | Minolta C350 Color Printer/Scanner/Copier
Desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
May 18, 2010 | Konica Minolta bizhub 161f All-In-One...
NINGUNO DE LOS XP PUEDO INSTALAR
10GB es bastante espacio para instalar Windows XP.
10GB is enough space to install Windows XP.
¿Sigue habiendo la instalación para en cierta localización y dice algo como de 6 minutos?
Does the installation stop at a certain location and say something like 6 minutes remaining?
¿Puede usted describir su problema mejor?
Can you describe your problem better?
Nov 19, 2008 | Compaq Computers & Internet
91 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
