Question about Cadco Line Chef XAF113 Electric Double Oven
Cadco XAF113 Fan/motor replacement
I have a Cadco XAF113 Convection Over and I need to replace the motor... but I cant seem to get the fan off, or the old motor out of the oven... any tips or suggestion?! Thank you!!
2 Suggested Answers
  • 193 Answers
SOURCE: I need to replace the
Cadco sells parts to the end use through a parts distributer. The phone number is 800 458 5593. Have your model and serial number ready when you call.
Posted on Oct 12, 2010
Loud fan rattling in convection mode
On the repairs I have done, it has always been a bad fan motor bearing. The only way you are going to be able to tell is to tear it down to the fan assembly and feel if the fan blade or blower is loose. Good Luck, Appliance Specialists
Jan 17, 2010 | Ovens
Convection oven making rattling sound.
It is most likeky that the fan bearing is worn and thus causing the rattling sound. You will probably need to replace the fan. Check first that there is no obstacle in the way of the fan rotating.
Replacement of the fan will require the back of the oven to be removed giving access to the fan unit, which will need to have the wires disconnected and the fan assembly unbolted. Fitting is the reverse.
Always remember to switch off the power before working on electrical equipment.
Jan 07, 2010 | GE Ovens
Frigidaire Oven making vibration noise when Pre-Heating or Convection cooking. Only notice when convection fan is running.
This usually is caused by a bad convection fan motor. This is something that you should have a technician replace, but ask for a price quote first. Fairly expensive to fix and usually very complicated to get at. Good Luck, Appliance Specialists
Dec 11, 2009 | Frigidaire PLEB30S9DC Electric Single Oven
Kitchen wall oven there is a buzzing sound when in the convection bake cycle
You don't tell the age of the oven... but the convection fan motor bearing is stressed by the heat of the oven.... and over time can cause all sorts of noises.
You may want to place a small amount of WD-40 on the convection fan motor bearing... just to confirm it as the problem/
Best to replace the motor if it is the problem..
-Jim
Oct 17, 2009 | Ovens
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
Cadco unox Mod XAF193
You can order the XC605 "air reduction kit" from the manufacturer catalogue.
Oct 16, 2008 | Cadco Ovens
Cadco XAF 115 fan not working
make sure you have selected convect bake, otherwise remove oven from wall to acces the back and test voltage at the fan, most likely the fan is bad, if you use conv. bake alot
Mar 29, 2008 | Ovens
Grinding noise every now and then
If this is a self-cleaning model it is possible that the movement of the mechanical parts are at fault. Toward the back you should be able to find the motor and drive rod. Check these first and yes, there could be a loose or faulty fan motor.
How long is the sound there ?
Jan 22, 2008 | Cadco OV-400 Electric Single Oven
Convection fan not working
Check for a bad fan motor or a jammed blade.
Jan 01, 2007 | GE Profile JK915 Electric Single Oven
Cadco Line Chef XAF113 Electric Double Oven Logo
41 people viewed this question
Top Cadco Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Cadco Oven Expert? Answer questions, earn points and help others
