Fault f61 on technics model sa-eh50. what is faulty?
Technician thinks it might be the power module
marsrover
  • 682 Answers
SOURCE: Fault code
speaker cord connector problem:-
remove all speaker connectors and insert it one by one each time until you find the bad one and change its connector with a new one.
(you must play something and listen).if all above does not work you will have problem in power supply and need to fix.
Posted on Apr 04, 2008
robotek
  • 1512 Answers
SOURCE: Panasonic stereo SA-PM28 displays fault
Hi dearnley1
The error code your unit is presenting relates to either a speaker cabling fault or a fault speaker. Sometimes, it is neither, and may be a fault inside the unit. Needless to say the unit is in protection moe to prevent more damage occurring. Check you speaker wiring for any short circuits or frayed wires. If all appears to be ok, disconnect the wires from the unit and see if it turns on and stays on then. If it still presents f61 with speakers and cable disconnected, then I am afraid that you may need to take the unit to a Kenwood service center near to you for an inspection . Good luck
regards
Graeme
Posted on Apr 06, 2008
otacon
  • 1944 Answers
SOURCE: sa-dv250 with fault code f61
Could you please tell what brand is your receiver?
Posted on Apr 18, 2008
  • 4234 Answers
SOURCE: Technics SA-AX540 Receiver
It is unlikely that the display itself is faulty although it can happen. The typical problem is either the backlight is defective or the suply to the unit has a bad connection. If you can solder, try resoldering the pins on the display itself. The pins on the ends are the power and ground. I don't recall whether or not your model has a separate back light bulb or not. That too could be burned. Chack for that too.
Keep us posted,
Dan
Posted on Mar 02, 2009
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
Panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
Aug 26, 2009 | Televison & Video
F61 ERROR
The F61 code is a power amplifier or associated circuitry problem. You'll need to have the unit serviced as it requires test equipment and a trained technician.
Mar 15, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic sa-ht995 will not work ...... when turned on it says hello.......then f61 then turns off again how do i fix this problem?
F61 in the user manual says , check your speaker connections if ok then see your dealer, the reason f61 comes up is a amplifier fault , most likely a blown audio amplifier ic is faulty, and needs replaceing by a compenent electronic technician.
Jul 09, 2008 | Audio Players & Recorders
POSSIBLE FAULT CODE
Yes, it is possible. The F61 error is a failure in the power supply or the amplifier. I repair these every day and it will require good soldering and troubleshooting skills to fix this yourself.
If you would like to try, let me know, and I will give you more information. But the best thing to do is take it to a service center and let a professional technician check it out for you.
Jun 28, 2008 | Panasonic Audio Players & Recorders
Panasonic home cinema model sa-ht75 . shows f61 disconnet output ic ,still shows f61
F61 error codes could either be IC501 or the regulator (IC502) in the power supply section.
For reference, pls view these two (2) posts here and here of similar concern on other models.
Other possibilities are:
1. fan not turning;
2. cold solder;
3. looses connections;
4. one of the other components/systems hooked up to the power supply is causing a fault (tuner, disc player).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 26, 2008 | Televison & Video
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
F61 code on SA HT540 system
i think it means that the cooling fan is faulty.
cheers Mark
Jan 06, 2008 | Lands Phones
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
200 people viewed this question
 Grubhead
Grubhead
