Question about GE Profile Harmony DPGT750GC Gas Dryer
Ge profile dryer not heating model dpgt750gc2pl
Not heating and blowing air out vent pipe. The gas line is connected corretly. The dryer turns on and runs but does not heat up.
Master_Tech
  • 770 Answers
SOURCE: Dryer Not Heating
I can email you the manual for the unit please post your email address and i will send it in PDF format you can print it off or look at it if you have dial up connection it may take awhile it is like 12Mb
Posted on Jan 25, 2008
ginko
  • 19396 Answers
SOURCE: GE Harmony Profile Dryer DPGT750EC1PL not heating & blower not working
Check that the dryer belt is not lose or out of place.
Posted on Apr 07, 2008
  • 54 Answers
SOURCE: GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
If you hear the blower ramp up when you start the dryer and it slowly ramps down or quits all together then you need to replace the blower.
Posted on Jul 04, 2008
jimappliance
  • 42 Answers
SOURCE: ge profile harmony gas dryer- no air flow in or out no heat
Replace the blower motor. Check condition of blower wheel and replace if found defective
Posted on Feb 13, 2010
heatman101
  • 43501 Answers
SOURCE: our dryer tumbles, but does not heat or blow. The
Check out this tip, it goes over your problem in detail..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
Heatman101
Posted on Feb 22, 2010
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Dpgt750gc2pl
Ignitor
PART NUMBER: WE04X10116
Order from Sears about $95
Cheaper elsewhere on line
Sep 27, 2013 | GE Profile Harmony DPGT750GC Gas Dryer
Blower does not blow on profile dryer GE Profile dryer drum turns heats but does not dry
the clip that holds the fan on the back shaft of the motor may have broken so the fan isn't turning, check that , but first check the duct and make sure that you don't have a ball of lint clogging the vent,, also check the venting all the way out of the house,, clean the overhang of the outside vent cover, they get moist and collect lint
Jun 21, 2011 | GE Profile DPSB620GCWW Gas Dryer
GE Profile gas dryer won't ignite
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Jun 01, 2010 | GE Profile DPXH46EAWW Gas Dryer
Dryer is heating but not blowing air
when was the last time you cleaned the dryer?try removing the vent line from the back of dryer to see if any air is blowing out,also is the dryer noisy?you could have a bad blower wheel.you need to clean out the duct that the lint filter slides into and behind that duct you'll find the blower wheel,also vac out the dryer where the motor is and if the vent line is a long run from the back of dryer to the outside i use a leaf blower to blow it out,make sure the outside vent isn't blocked with anything before you blow the vent line out,send model number if you need help getting the blower wheel part number if that's your problem,you should clean the dryer at least once a year so you don't have a fire,good luck
Apr 11, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Heat is on clothes are not drying
The air flow through the exhaust is blocked/clogged.
This usually happens at the vent where it exits the house, but can also be where the dryer connects to the vent in the floor/wall, and also occurs throughout the entire pipe length.
Make sure the inlet, pipe, and outlet are cleared. make sure the lint filter and surrounding area is clear.
You should hjave a good strong air flow comming out of the vent on the exterior.
(Improper airflow prevents the moisture from exiting the dryer.)
Oct 03, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
We have a GE profile harmony gas dryer that is running but is not sucking in air, blowing out air or heating up.
This dryer has two motors one is specific for the blower system I'd guess the blower motor is not functioning and the dryer will not heat due to safety features. I would check those things but also check the venting from the back of the dryer to the outside of the house to make sure there is no blocked airflow just a general maintainance. Hope this helps.
Jan 16, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
79 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
