Question about Sanyo Televison & Video
Sanyo jxpsg locked AV1 channel my mistake.
When i push channel buttons on tv it just changes the hdmi to av1 or video channels wont change
Go to menu and find the channel programming option, then search for channels.
Aug 11, 2014 | Sanyo Televison & Video
22 822 cob lux
Chances are that you changed the input setting by accidentally touching the input button on the remote. If you press the input button you should see a variety of inputs to select from, try AV1, etc or HDMI1, etc but not TV. When it shows the cable channel it was previously tuned to, press select and that should fix it
Jul 27, 2014 | Televison & Video
I have a SANYO TV jxpsg ,the AV1 has locked so there is no picture ,how can I fix this ?
Do a hard reset to this set and try. Just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This must make it a hard reset.
Jun 30, 2013 | Televison & Video
My tv sanyo cm21kf81A, chassis number FC3-G221 has snow noise on all tv channels, but AV1 and AV2 play good sound
First check cable wire or whatever is connected to set for channels--the leads are connected and wiggle them with set on to see if it clears up--could be a connection where cable wire is connected at end--loose connection there etc.
If tuner is bad causing this and you use a box for signal--most have rear audio/video outputs you can connect to a unused video/audio input on rear of set---bypass the tuner in the set and operate set that way changing channels on box instead of set.
let me know if you have questions or have more information.
Mar 21, 2012 | Televison & Video
NEED HELP IN SETING UP AND HOW TO RECORD TV SHOWS
for best results plug your reception receiver into your input channel (av1) this will give you the very best result in high quality recording of tv
Apr 21, 2010 | Sanyo DRW-1000 DVD Recorder/VCR
Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Mar 20, 2009 | Sanyo DS13204 TV
Change input channel
FIRSTLY consider buying a remote @ $44.95 only
get connected to
www.twenga.co.uk/dis-audio-video.home-cinema.remote-control-228-554k
to change a channel hold both channel buttons at once, your tv will give you menu and later go in programming channel
or
hold one channel button, sweep through all channels at the end you will enter AV
Jan 20, 2009 | Sanyo DS13204 TV
Re sanyo 68cm stereo tv model no. cp29ys2
Hold the button directly under the AV1/Av2 select button for 2seconds..this should unlock..see manal page 12..not 13 like the error list states
Oct 16, 2008 | Televison & Video
Sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to imr4@in.com
Aug 12, 2008 | Sanyo DS24205 24" TV
Televison & Video Logo
102 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
