What size fuse does the Kenwood KR-6170 use?
When plugged in the unit does not show any signs of power. Fuse receptor was empty.What size fuse does the Kenwood KR-6170 use?
SOURCE: kenwood kr-720 250 4amp
The audio amplifier IC on your device are damaged.
Posted on Jul 05, 2008
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
SOURCE: kenwood kr-a4060 keeps blowing fuses
Check the audio amplifier Ic maybe its fried.
Posted on Aug 25, 2008
  • 4234 Answers
SOURCE: Kenwood KR-A4070 blowing 5a 125v fuses
I am guessing that the ceramic resistor is close to the output transistors. I would also guess that one or more of the output transistors has shorted. This causes a high current draw that is blowing the fuse. You could also have a power supply problem. The ceramic resistor is a .22ohm dual emitter resistor that is used in the output stage. The transistors located close by are probably shorted and should be replaced. Start there and let us know what happens once the transistors and the resistor are changed.
Dan
Posted on Oct 10, 2008
  • 222 Answers
SOURCE: kenwood kr 3600 volume potentiometer is faulty
try google and it will give you some local electonic stores
Posted on Jun 08, 2010
Where are the fuses on a KR-V127R receiver?
The fuses are inside the unit. Open it up and they will be quite visible near the power cord.
A blown fuse is signs of something wrong BTW.
Good luck
Jan 27, 2015 | Audio Players & Recorders
Where are the fuses located in a kenwood , kr5030 ?
If there are any fuses you will have to take off the cabinet to see them on the inside. If not the fuse then it is most likely the power supply inside.
Jul 17, 2014 | Kenwood Stereo Receiver Am/fm Model...
My Kenwood KR-v8050 reciever will turn on, but will not go out of stand by mode, the visual screen also is not working, what am I looking at to fix this?
Sounds like either the main power fuse is blown,or the power transformer is bad. If the fuse is blown, probably means the amp is shorted.
Dec 31, 2012 | Audio Players & Recorders
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
Hola donde puedo conseguir el manual del receiver
Hola! Puedes buscar un manual por tu radio en el website de Kenwood por supporte.
Solo necesitas a buscar tu numero del modelo de tu radio y puedes copiar el manual ...no cuesta nada... checkas AQUI
May 30, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Dan
Oct 10, 2008 | Kenwood Audio Players & Recorders
Problem with playing my Kenwood KR-X1000
Nov 19, 2007 | Kenwood KR-X1000
Kenwood KR V8080 receiver
if you sent 110v down the speaker wires & into the amp you most likely have damaged the audio outputs or the output ic. Look for a big aluminum heatsing & on one side you may find 1 or 2 ic's or numerous transistors, the ic's are hard to check, the transistors are easier to check, if transistors replace in pairs. also check for burnt /open resistors near outputs
Aug 18, 2006 | Kenwood KR-V8080 Receiver
 Grubhead
Grubhead
