I have a Auria model EQ3402 sound bar and im having trouble getting sound from my 32 inch toshiba tv.. but the mp3 seems to work fine..
Model eq3402
dsacco86
  • 1077 Answers
SOURCE: Element 32'' LCD TV, has picture but no sound
The S-video cable doesn't have hookups for audio, only video. It's better than the video coaxial cable. But, you still need to hook up the right and left audio coaxial cables.
Posted on Feb 09, 2009
  • 75 Answers
SOURCE: I have a Sanyo 32 inch tv, model # DS31650, that has no sound
My book says no audio, storm damage need to replace ic 3601 (CXA1279AS part number 409 279 3109) this is probley a surface mount ic on the bottom of board.
Posted on Mar 09, 2009
praky16
  • 744 Answers
SOURCE: Proview 32' without picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jul 07, 2009
dave1645
  • 834 Answers
SOURCE: I have a 32 inch Emerson tv..model # LC320EM8AN
t-con board is failing have a tech replace it
Posted on Sep 20, 2009
SOURCE: Dell 32 inch LCD Tv volume and menue problems
I had the same problem with my tv.No sound! I finally figured it out. It was the speaker wires! Once I changed them to a slightly stronger speaker wire, it worked great! I have sound to my tv and I haven't had any problems since then.
Posted on Dec 16, 2009
Need to buy a remote for eq3402
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 13, 2013 | LG Lsb316 280w Sound Bar Wireless...
32" toshiba 36a60 plays DVDs but not cable TV
Did you switch video inputs from the remote, each input has its own menu item.
May 19, 2017 | Toshiba 32DF46 32" TV
My remote doesn't turn on my tv AURIA EQ5588, do I need a code
I also have an Auria EQ5588, the on screen prompts are the same as my APEX 32" 720p I bought over a year ago so either both are the same company or they share the same software. Both are Chinese Mfg. so who knows??? If your factory remote doesn't work call the phone # on the warranty page. There are universal remote codes listed on P. 6 of the owners manual if you are trying to code a cable or dish remote. There is also a reference to LG codes which are carried by Best Buy, Perhaps they can help you out if nothing else helps. The only glitch I've noticed is switch back to TV before turning off your blue ray player. If I turn off my Sony blue ray player and then go back to TV mode I get no sound, turn off the TV and restart it and it's fixed. Seems to be an issue between the brands. I'm pretty happy with the Auria since I got it for $700. Could have spent a lot more!!!!
Feb 23, 2011 | Televison & Video
I have bought a new Toshiba 32'' LCD TV and cannot get the Wii hand to display properly, I had a rear projection Tv (28") and it worked fine
The plug for the sensor bar was not in the back of the Wii properly, so the hand would only appear partially and very jumpy.
Jan 05, 2010 | Toshiba 32A33 32" TV
Problem with 32-inch Toshiba flat screen tv
yes take it back sounds like a back light issue
shad
Jan 04, 2009 | Sharp R-1480 Microwave Oven
Sound is distorted on 32-inch GE TV when auto tuned
Problem in the IF section of the tuner. May need to just replace the tuner pack...accordianman
Feb 19, 2008 | GE 32GT740 32" TV
Toshiba TV repair
I have a Toshiba HD LCD tV, model 37AV50U. the screen is black. I still get audio and can change the channels but the screen stays black. It doesn't even show the menu box. Is this something I can fix myself?
Dec 23, 2007 | Toshiba 57H81 57" Rear Projection...
Large vetical bar on left side of screen
sounds like you did everything correctly?? HMMM well there is no adjustment thats for the consumer to try,your right about that. Sometimes a set can be working well and its moved ever so slightly , the Printed circuit board cracks or a solder connection becomes loose and starts giving problems. This seems to be in the width circuit or the horzontal sweep?? there are no user serviceable poarts inside these sets and there is dangerous Hi voltage so the only thing I can recomend is to have a shop take a look at it and maybe they can find the solder connection or crack in the circuit without too much trouble. Sorry I coundnt be of more assistance. good Luck
Jun 14, 2006 | Toshiba 32A43 32" TV
Televison & Video Logo
604 people viewed this question
Top Televison & Video Experts
Electro Med Services...
