Asus crosshair II forumla motherboard not powering up
Just got the Asus Crosshair II Formula motherboard, AMD 9950 BE cpu & 8 gigs of 6400 ram. Slapped the entire setup together made sure that everything was done correctly and tried to power up the system. Inititally the system stayed on about 5 secs, and then just started cycling. Called Asus tech support and the guy I spoke to said that it sounded like a grounding issue. Told me to put electrical tape over the brass studs coming off the case and then retry. Did that and there is no significant change. Please, I need to have this system up and running before tomorrow morning, so any help at all would be greatly appreciated.
  • 1 more comment
  • Brightdevil Oct 23, 2008
    Thanks for the comment on my system! I purchased all the parts from Newegg.com. It was not a kit, just the parts that made sense to work together. I've also used Asus boards to good advantage before, however in this case, I've pretty much ruled out all the other possibilities except that the board itself is faulty. My current motherboard will not support the 9950BE to it's fullest extent, and so I cannot test the CPU. Basically, what I'm faced with is more than likely RMAing the board back, and hoping that the next board is good.
  • butch welch May 11, 2010
    Good luck. Let me know how this turns out. Jfw46@hotmail.com
    Sounds like you have one hell of a system. Did you get it from Tiger Direct. Was it a kit. I have used Asus boards with good luck. Try taking all of the screws out except maybe a couple that hold the board in the case. Did you use the fiber washer on the studs. Take all of the memory out except one stick. (just to test) The power supplies that comes with the case are usually not enough for a system like you are builing. Is this a water cooled board. Is you cpu getting hot
Sorry this is kinda late, but I have the exact same problem. Turns out, if you have the bios version, 0502, then that will NOT support the 9950 BE processor. You will have to flash the bios to the newer version which is 1003. So I went and bough a $20 sempron 64 3400+ processor, so I can get it to boot up and then I can flash it. Now thats what I call a pain in the ***.
Posted on Nov 19, 2008
    Scholar:
  • 40 Answers
Hi, To troubleshoot a grounding problem like this remove the entire motherboard (keeping all the necessary connections) and lay it on a wood cutting board ( wood is a bad conductor of electricity) and try to boot up and watch it. Make sure its fairly secure so it doesnt get knocked aside, and be especially gentle and touch the board only on the edges.
This will eliminate whether it is a shorting problem.
Present the result to the MOBO support and they will probably replace the board.
I hope this helps, good luck. *s*
Posted on Oct 26, 2008
3 Suggested Answers
charcois
  • 763 Answers
SOURCE: Asus crosshair II forumla motherboard not powering up
sir, did you setup the motherboard to the cpu case all by yourself? tell me exactly what you did. thanks!
CHARCOIS
Posted on Oct 23, 2008
s_4u_11
  • 535 Answers
change the ram of *********** Bord u have to need a 400 mhz ram for to solve this problem dont bye first chak it to anther PC ram then if its work then buy a new ram or change the smps of your system
i think its help u
How do I enable my HDMI out on my Asus Crosshair II Formula Motherboard?
HDMI and VGA are part of the video card not mobo. I don't see ASUS placing an integrated video card on such nice board.
Aug 27, 2012 | ASUS M2-CROSSHAIR II FORMULA Motherboard
CHARCOIS
Oct 23, 2008 | ASUS Computers & Internet
I need manual for asus formual IV
Hello Marrcin Ramsz, go to the "LinK" below,
and select from the "Drop-box;
the OS: eg. Win 7, Vista... [32bit or 64bit].
The "Manual" you need will be at the bottom of the list!
You will down-load the "Manual" on your computer.
"If there is anything slse I can help you with?
Write a follow-up 'comment'.
"Let me know if the manual you needed was there."
"Thanks paul7of9"
*Click here for the Manual: http://support.asus.com/download.aspx?SLanguage=en&m=Crosshair%20IV%20Formula&p=1&s=24&os=30&hashedid=kPGmtxee5RsQVsXG
Dec 27, 2011 | ASUS Crosshair IV Formula AM3 AMD 890FX...
Amd athlon ii x3 450 best compitible mother board
asus makes the Best mainboards in my opinion, All AM3 boards. You get what you pay for so it's worth spending a bit more to get a good mainboard.
Example: ASUS M4A88TD-V EVO/USB3 is a really good option, however I myself would pair this mainboard with a AMD Phenom 2. Though your X3 450 will work well in this mainboard too.
The best compatible mainboard would be the ASUS Crosshair IV Formula or Extreme edtion, however your CPU will be a bottle neck in the system.
The ASUS M4A88TD-V EVO/USB3 is really good looking and it performs really well too.
You could go for an ASUS 785/790/870/880/890 North Bridge chipset AM3 Socket.
You could even purchase an AM3+ mainboard that will support AMD's new Phenom module CPU's.
Go to www.asus.com and check out the AMD mainboard range that they produce.
Take care!
damnor01
Feb 11, 2011 | AMD Athlon II X3 450 / 3.2 GHz processor
Hi, Hope you can help. I've just fitted a new motherboard to my computer (ASUS crosshair 2 formula). My memory is 2 x 2GB DDR2 running at 800Mhz. Th machine will run fine using either of the sticks, but...
Hi. Asus has a great utility that lets you update your bios even in Windows.
http://www.asus.com/product.aspx?P_ID=EIDxaW1Ln3YR9RA2
At the download section select your OS and in Utility section find "ASUS Update V7.14.01 Install Program" This program will automatically update your bios.
As for your Ram issue. Did you try each stick in each ram slots ? If you did and saw no issues, then I am only suspescting of incompability between your Rams.
Oct 12, 2010 | ASUS CROSSHAIR Motherboard
I have an Asus 790GX G65 and when I boot
What that means, is that it cannot find a device that has an operating system on it i.e. a boot track.
Mar 30, 2010 | ASUS Crosshair III Formula AM3 AMD 790FX...
CPU overvolted and burn using 8pin eps12v cable on crosshair
no i dnt think so some time due to manufacturing defects this happens the new one wont burn unless and untill u over volt it.
Jan 31, 2010 | ASUS CROSSHAIR Motherboard
Is there a good diagnostics program for the Asus Crosshair motherboard that will tell me if the board is functioning correctly? I'm trying to figure out why my computer is stalling for several seconds when...
google asus probe and install it to check your voltages and temps. also look at your task manager to see what your cpu and memory loads are. with that sort of setup, things should be running pretty good. my guess is your temp is high.
Oct 28, 2009 | ASUS CROSSHAIR Motherboard
I swithed to asus crosshair motherboard. put in an athlon 6400 x2. Connected everything right. When i turn the power on, it stays on for just like 7 seconds then turn off. at the back the lcd says comp...
HAVE YOU CHECKED TO SEE IF MOTHERBOARD SUPPORTS THAT EXACT CPU.OR YOU MAY NEED TO CHANGE A SETTING(S) IN THE BIOS.TRY NOT USING AUTO DETECT FOR CPU MANUALLY ENTER INFO.RICHARDM69
Dec 02, 2008 | ASUS CROSSHAIR Motherboard
Computers & Internet Logo
412 people viewed this question
David Payne
David Payne
