Question about Saws
Do you put lubrication in a rockwell 314 trim saw
Where do you put it & would porter cable special high grade lubricant be good to use?
rowdy45176
  • 2176 Answers
SOURCE: Dremel scroll saw 1672 16'' two speed scroll saw slow motor
Go to Dremel.com or call toll free1-800-437-3635 and tech service might be able to get you a schematic and wiring diagram. It does sound as though the switch is either wired incorrectly or put in upside down. If I have helped you on this would you please take the time to rate me accordingly and Thank you
Posted on Apr 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: lubrication and maintenance reciprocal saw DeWalt
Before you attempt any of this I would recommend going to Dewaltservicenet.com and see what the inside of this tool looks like. It appears that you need to remove part of the front gearcase to get into the lube. The back e.g. brushes is not that big of a deal. If there is a Service Center near you they have a Max repair rate that they will fix anything on this saw at a preset firm price and if it is less that is what they would charge.
Posted on May 18, 2009
efs_perpends
  • 1996 Answers
SOURCE: need to lubricate the drive cable on homelite gas edger
Bicycle chain lube works well in these situations. It's usually a teflon based lubricant, light weight, with good penetration, and little tendency to gum up in the long run.
In a pinch, WD40 will work as well...though it will tend to gather more dirt and dust. If you have rust issues, WD40 will drive the moisture out...
Make sure the moving parts attached to the end of the cable are freely moving as well. Frequently they are the cause of the friction, rather that the cable itself...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 03, 2009
efs_perpends
  • 1996 Answers
SOURCE: I have just purchased a Delta Rockwell Industrial
The table can be cleaned and waxed with a good quality paste wax like Trewax clear. If it has rust, you can use automative polish/cleaner and a rag or fine scotch pads to get the rust out, then wax the surface to protect it. Period waxing will maintain a low friction surface through use. Old timers used to recommend rubbing the bare steel table with talc to seal the pores, but I find was is more readily available and gives a better surface for use...Wax is also good on the moving parts of the fence.
The worm gears and trunnions can be cleaned with compressed air and regular 30w motor oil in a pump can. Maybe a soft wire brush or toothbrush if needed to remove built up resin and pitch. If there's a really heavy build up on the gears, get some OxiSolve bit and blade cleaner from Woodworker's supply and it will safely dissolve the gunk to a consistency you can scrub off with a toothbrush. I maintain these moving mechanical parts with oil, which an old pro recommended years ago, and have found it doesn't contribute to sawdust build up as you think it might, not nearly so much as an assembly lube or white grease, and makes raising and lower the blade a joy. If you're concerned about dryness, you can try triflow or some kind of bicycle chain lube, but I've decided the expense isn't worth the results, and oil is readily available when I need it...
If replacement parts are available for your model, try here. Otherwise, and for older machines, you might find a manual or parts info at this site.
After market fences are available for your saw, and depend on user preference. I've been very happy with my Biesemeyer fence, after using it (and many others) for 22 years. It is also heavy duty.
Posted on Jul 23, 2009
puertobori
  • 7733 Answers
SOURCE: I have a Craftsman 10" 1/3 hp band saw, after
Looks like are the motor brushes.
Try open the motor and look for.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 23, 2010
What are the specialities of Trabon lubrications ?
It was proved by sage engineers that lubrication is very much important for each and every single component of a mechanical machine. In order to keep the machines running for long time use trabon lubrication. More Info at : Home FDJohnson
Jul 19, 2014 | Skil Worm Drive Saw Lubricant
Jawhorse left outside and is now locked up
did you try a lubricant on the threaded components ?
IE WD 40 or other lubricating chemical
Oct 06, 2013 | Rockwell RK9000 Jawhorse
Rockwell 34 345
I have a band saw and I am using a sawing fluid for blade lubrication. Try looking at lowes . You can ask them how to lubricate and what lubricant to use. Watch this video .
Apr 26, 2013 | Saws
I have an old Rockwell 368 circular saw 81/4".
Well, here is the link for the breakdown of your peticular saw
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=368&selectedType=11998
As far as the manual, the closest you will get without finding one at a garage sale is the 368-1 Type 1. When Porter-Cable absorbed Rockwell's tool line, they kept this saw and threw a -1 on the end. Some parts are different, but the operation is the same, thus, the manual should provide any information you may need, but I'm sure that you would just like to have it, and probably don't need it. Here is the link for that. Just click on the Instruction PDF Icon.
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=368-1&selectedType=13481#
I hope this helps.
Nov 29, 2010 | Porter Cable Saws
Where can I find a blade cover for a Rockwell Radial Arm Saw that is over 20 years old.Serial # 85Fo8158 I cannot find a model # but there is a parts# 438-02-314-0911 and there is a Cat. # 33-890
Any porter cable dealer/ repair shop. Will be able to tell you if its still available or obsolete by the cat# 33-890. This is the catalog # they did not use a model # per say.
Dec 22, 2009 | Saws
Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
Saws Logo
196 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
