Question about Xerox Phaser 7750DN Laser Printer
Reboot Printer Received Complaint From Customer that the Printer is Working Properly , Print Copy Quality is Good. But Some Times When Processing The Job, Suddenly The Printer re-start by itself .
    Brigadier General:
  • 6,966 Answers
May I offer an alternative possibility? If none of the usual checks, resets, menu settings works, then it could possibly be a hardware fault. Initial suspect would be the power supply. depending on the age, could be anything which includes but not be limited to:
  • loose connection or cold solder;
  • blistered or leaky filter capacitors;
  • heat related issues.
Should this be the case, then the unit has to be opened up for a look and see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
    Master:
  • 505 Answers
1. turn off the printer
2. Disconnect the power chord. make sure there is no loose connection. If the plug is not connected properly the printer will reboot. try a different wall outlet. If connected to surge protector disconnect from it and connect to the main wall outlet.
3. also delete all printjibs
4. Uninstall and resinstall the drivers
if the printer still restarts you will need a technician for checking the internal connection on the connector board.
Thanks
Posted on Oct 23, 2008
    Genius:
  • 2,035 Answers
Try to reset the printer :Please follow the steps
Resetting the Engine NVRAM values will reset the color, margin and paper settings to default.
  1. Press the Down Arrow and scroll to Troubleshooting.
  2. Press OK.
  3. Press the Down Arrow and scroll to Service Tools.
  4. Press OK.
  5. Press the Down Arrow and scroll to NVRAM.
  6. Press OK.
  7. Press the Down Arrow and scroll to Reset Engine NVRAM NOW.
  8. Press OK to reset the Engine NVRAM.
and please let me if the you the same problem..
Good luck...
    Genius:
  • 1,269 Answers
Try to unplug the USB and Power Cable of the printer for about 3-5 mins. You can also try to use a different USB cable to isolate if it's just the physical connection problem. Otherwise, It's a problem with the driver. Try to uninstall and reinstall the driver first. Updating the driver will fix it.
    Sergeant:
    Champion:
  • 331 Answers
The power cord  may  be  loose.....
or the  usb  connection...........
did u try checking  for those
Cleaning head and nozzles
Cleaning the Print Head
r_bullet.gifUsing the Head Cleaning utility
r_bullet.gifUsing the control panel buttons
If you find that the printout is unexpectedly faint or some dots are missing, you may be able to solve these problems by cleaning the print head, which ensures that the nozzles are delivering ink properly.
You can clean the print head from your computer using the Head Cleaning utility in the printer software or from this product itself by using the control panel buttons.
  • Print head cleaning uses both color and black inks. To avoid wasting ink, clean the print head only if the copy quality drops (for example, blurred printout, incorrect or missing color.)
  • Use the nozzle check first to confirm that the print head needs to be cleaned. This saves ink.
  • When the Error light is on and a message appears on the LCD panel to prompt you to replace the ink cartridge or to indicate the ink is low, you cannot clean the print head. In this case, replace the appropriate ink cartridge first.
Refer to the appropriate section below to use the Head Cleaning utility.
For Windows
Follow the steps below to clean the print head using the Head Cleaning utility.
r_1.gifMake sure that A4 or Letter size paper is loaded in the sheet feeder.
r_2.gifMake sure that this product is on and the ! Error light is off.
r_3.gifAccess the printer software.r_arrow2.gifAccessing the Printer Software for Windows
r_4.gifClick the Maintenance tab, then click the Head Cleaning button.
r_5.gifFollow the on-screen instructions.
Head cleaning... appears on the LCD panel while this product performs the cleaning cycle.
r_space.gifr_caut.gifCaution:r_space.gifr_space.gifNever turn off this product while Head cleaning... appears on the LCD panel. Doing so may damage this product.
r_6.gifWhen Head cleaning... disappears from the LCD panel, click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Good: print head does not need to be cleaned yet.
Not Good: print head needs to be cleaned.
If the nozzle check page does not print satisfactorily, you may need to repeat the head cleaning and print the nozzle check pattern again. See Cleaning the Print Head.
  • If the copy quality has not improved after repeating this procedure four or five times, turn this product off and leave it alone overnight. Then, perform the nozzle check again and repeat the head cleaning if necessary.
  • If the copy quality still has not improved, one or both of your ink cartridges may be old or damaged and may need to be replaced. To replace an ink cartridge before it is empty, see Replacing an Ink Cartridge. If the copy quality remains a problem after replacing the ink cartridges, contact your dealer.
  • To maintain good copy quality, we recommend copying a few pages at least once every month.
Apr 14, 2013 | Epson Stylus CX6400 All-In-One InkJet...
Hello....I am on my second Canon Pixma printer and this one I bought in May of 2009......suddenly it is making faeded looking prints.....I changed all of the ink tanks and did deep cleaning about 10...
refill cartridges most of the time will not give you good quality prints on average sometimes they simply just do not work I know i refill them best advice before cleaning printer heads get original cartridges perhaps from another machine just to test if the copy quality is good buy originals
Oct 13, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Same on kodak...
Just try cleaning the printhead using the AIO home center program and i'm sure you would be able to restore good print quality again
Sep 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
No printer dialogue box appearing when i ask my computer to print
If you can find the presence of the printer, right click and click properties, there must be a setting for print quality
Aug 27, 2009 | Epson Stylus C84 InkJet Printer
Color and black gets shadow on print out
Go to the printer Setup button, hit Ok, then look for Print Quality, acess print quality and go to calibrate colors, run this calibration for 3 times.
Then go to services and run a 2 cleaning modes
You can try printing blank pages selecting "cardstock" as paper type to clean the fuser
Mar 16, 2009 | HP Laserjet CM2320nf All-In-One Color...
Output color problem
try to off toner save mode
to press * printer setup - print quality
and adjust print density also in the menu.
Feb 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Copy Problem
is scaning working properly? check the scanner section.
Oct 16, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Epsom cx3200 off brand ink refill
Make sure the print head nozzles are not clogged. You may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
When you don't turn on your EPSON CX3200 for a long time, the print quality can decline. It's a good idea to turn on your EPSON CX3200 at least once a month to maintain good print quality.
1. Make sure the EPSON CX3200 is turned on but not printing, and the Error light is off.
If the Error light is flashing or on, you may need to replace an ink cartridge.
2. Press the left Menu button on the control panel several times until you see Cleaning and then press the Copy button.
Cleaning takes about 30 seconds, during which the EPSON CX3200 makes some noise and the Operate light flashes. Never turn off the EPSON CX3200 while the Operate light is flashing, unless the EPSON CX3200 hasn't moved or made noise for more than 5 minutes. setViewedFAQCookie(14082, 31605);
Oct 02, 2008 | Laser 3115cn All-In-One Printer
Papaer jam
same thing happens to me
May 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Xerox Phaser 7750DN Laser Printer Logo
129 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
