Question about Zonet Computers & Internet
Congfigure Mode Failed Zonet ZEW3002
Attempting to set up for Client Mode; manual instructions are incomplete. I select radio button 5 (Client) Wizard asks for preferable mode twice so I select (Client) in the second box I enter name of my wireless router JnKBull Channel set to 11 (box to right shows Frequency 2.462 GHz WDS mode: selected Static Key Remote AP Mac I entered Mac address of my wireless router. The wizard requests SSID a second time, I entered JnKBull Request channel number , I selected 11 and input the MAC address of JnKBull I enabled Encryption Select WPA_PSK Select ASCII Key type Select AES Cipher Key: entered the encryption Key for JnKBull wireless router. Select Apply and get message "Configure Mode Failure" The manual only shows setup for the lower part of the Wizard screen. What am I missing?
anandg27
  • 1272 Answers
SOURCE: I have a Netgear wireless router DG834G and i am
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 13, 2009
  • 59 Answers
SOURCE: My wireless name (SSID) and security settings keep changing on their own!
hi,
well i saw the problem u r facing
and the only soution for it is the upgradation of the firmware ....
i was facing the same one on my router and it got corrected ....
otherwise u can call the customer care no of the the routers company and they will give u the replacement
Posted on Oct 23, 2008
  • 76 Answers
SOURCE: USB Wireless Network Setup Values
during setup it should asked you to create password but anyways those letters are security protocals for your router to prevent peeps from accessing your network...wep is easiest
Posted on Dec 02, 2008
govinda123
  • 2263 Answers
SOURCE: I installed a new Zoom
I think the router firmware is not working properly.
Some routers need power cycle ( reboot ) after any changes on the router settings.
Now make sure that you are getting IP address on the internet part of the router.
When you set up WEP and passphrase , Your actual password for the wireless network will be the number in the key number 1 box and NOT the passphrase.
Click Here for more info about networking.
Posted on Oct 08, 2009
govinda123
  • 2263 Answers
SOURCE: Followed instructions from Best Solution posted on
If you select WPA security mode then you can not add the network manually.
I think the OS on your computer is windows XP.
You can connect to the netwoek using the windws utility.
If you select WEP, then you can add the network manually.
Click here for more information about router and networking
Posted on Feb 16, 2010
I have a lap top and just was given a zonet - zew3200 and want to hook it up so I can go wireless but I'm a novice and need help to install, I do have an
hi Deborah is this not a zew3002? and not a 3200? just wondering as zonet do not have this model registered here is the site for zonet if you look under the router you may find a different number as they sometimes put a number on the front which actually is nothing to do with the model itself, if you would like to get back to me i maybe able to help you, but here is a link to there site so you can check it out before hand hope this helps please rate thanks...just click link below http://www.zonetusa.com/products-21-1.aspx
that will take you to there site
Aug 22, 2010 | Zonet (ZSR0104UP) Router
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
I lost the owners manual for my Innova - Trifecta Digital AM/FM Clock Radio with Built-In Apple® iPod® Dock Model: VR880SA | SKU: 8955222 and do not know how to reset the preset channels
I have the manual.
1. Press the FUNCTION button to select FM or AM mode
2. Press SKIP to select station.
3> Press and hold the Memory button to enter channel saving mode.
4. Press the Memory button to select desire preset channel #.
5. Press and hold the Memory button again to save into memory. If it has been previously set, the former station is replaced.
6. Repeat step 2 and 5 to store addtl. stations.
Any idea as to how to set the volume during alarm mode, it's too loud!!
Jun 04, 2009 | Audio Players & Recorders
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
Need operating manual for Zenith Model Z253W radio
1. Tune the radio to the frequency you want to preset, using the "Tuning/Set" buttons.
2. Press "Time Set" button to enter set mode. Note it says "Preset" below this button, because it is used to set both time set and presets.
3. Select the preset number you want, using the "Preset" buttons.
4. Press "Time Set" button again to exit set mode.
5. Repeat the above process for each preset.
Nov 15, 2008 | Zenith Audio Players & Recorders
Sentry CR-106: setting the projector's time.
I found my manual!
To set month, press the "set" button 2 times then press "mode" to sequence month
To set date, press the "set" button 3 times then press "mode" to sequence date
To set hour, press the "set" 4 button times then press "mode" to sequence hour. (24 hour clock toggles with 12 hour clock)
To set minutes, press the "set" button 5 times then press "mode" to sequence minutes.
I hope this helps!
Oct 07, 2008 | Audio Players & Recorders
GPX clock radio clock question
I emailed the company and they sent a pdf of the manual back the same day.
partsinfo@dpi-global.com
Jun 06, 2008 | GPX CRCD6306DT Clock Radio
Operator/instruction manual
ghilger, First off, has your radio been converted to open up all the other channels(including CB)?? That has to be done first, or it's locked in the ham freq's. I think the factory manual is pretty well detailed, but i've been around radios my whole life. The mode button does the changing from am/fm/usb/lsb.Here's from the manual;
MODE: Operating Mode. Press the MODE control to select the operating mode. The operating mode is indicated on the liquid crystal display: am, fm, usb, or lsb.
* See, there is 2 different functions for each button. One set of functions are by just pushing the buttons, the other set of functions are obtained by pushing the function button first. The function button is activated by pushing in on the clarifier knob.
*Here is for saving of freq's;
Memory Save. To save in memory a specific
frequency and operating mode, select the desired mode and rotate the FREQUENCY control to the desired frequency. Press the FUNC button, and then press the M.SAVE button. S will appear on the LCD next to the frequency. While S is displayed, immediately press any of the memory channel buttons (1 - 5). The mode and frequency is now saved into memory. If the S indicator disappears before you press the memory channel button,
the information will not be saved and the process
must be repeated.
M.LOAD: Memory(Recall). To recall, any of the saved memory channels press the M.LOAD
button. L will appear on the LCD for several seconds. While the letter is displayed press the desired memory channel button (1 - 5). The programmed mode and frequency will be displayed.,
If you have any more questions about the radio, repost them here and I'll try to walk you thru them. The radio is a very good ssb rig, especially set up with a power mic. Hope this helps,, Mechanic
Feb 03, 2008 | Magnum 257 CB Radio
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Can't get ATS to function per instruction manual
You probably have to set the scan function to ATS mode by turning the radio off, pressing and holding the F6 button for 2 seconds, then releasing, then quickly pressing and releasing the F6 button to step through the 3 scan modes. The display will show which mode is currently selected.
Aug 17, 2006 | Eton E5 Radio
Computers & Internet Logo
52 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
