Question about Apple iPhone Smartphone
I can't open the cover of my iphone
I am trying to take off the back cover of my iphone because the front glass is broken.
I was following one of the youtube videos and they made it look really easy. They used this magic green tool and the cover just came off.
I bought the green tool and tried to do it, but no luck.
Any ideas?
    Problem Solver:
  • 5 Answers
That tool DOES NOT WORK. Try this. this is called the iPhone Cheetah. The easiest way to open the 2G. Check it out http://www.iphonecheetah.com/
Posted on Jul 20, 2009
How do you reset sunroof in a 2001 Monte Carlo with 3400 model I
check fuse and relay if good than possible motor ot track problem their should be a mechanical bypass that will let you close it if stuck open the following information is courtesy of monte carlo forum
To check the condition of your original sunroof guides:
  1. Gl*** in closed position.
  2. Locate & remove 3 torx bolts on each side of sunroof glass. Lift glass out of sunroof opening & set aside in a safe place.
  3. Locate "J" shaped cover plate at front of sunroof track assembly. Remove 2 torx bolts from each cover plate.
  4. Lift up bracket to remove.
  5. Inspect the plastic guides on each side. The sunroof cables attach to guides on front outer corner. Inspect this area closely for damage.
  6. Do not operate the sunroof with the J plates removed.
Troubleshooting:
If the sunroof guides are not broken & the glass is a uniform height along the rear edge your problem may be a stripped gear inside the motor. The motor has a manual override:
  1. Get access to the motor by removing the map light/switch console or lowering the front of the headliner.
  2. Insert a large standard screwdriver into the nylon bushing at the center of the motor hub. Push up & turn the screwdriver to manually move the sunroof glass. If the unit will fully open & close manually, you most likely only need a replacement motor.
If your sunroof is stuck in the open position follow these steps to get it closed:
  1. Remove the glass.
  2. Try to close the unit without the glass. Many times one side will still be operational and close correctly.
  3. Try to slide the inoperable lift arm forward. If it moves, slide it forward until it stops.
  4. You now need to slide the original plastic guide forward to lower the arm to the closed position. Using a standard screwdriver, push it forward. The lift arm should begin to lower.
  5. If the lift arm will still not fully lower, remove the J plate as explained above, sometimes the sunroof cable will need to be lifted up to allow the guide to fully slide forward.
  6. Reinstall glass.
May 21, 2016 | Cars & Trucks
How to fix a i phone 4
Hello Anonymous
This would probably be a good opportunity to take the iPhone4 into an Apple Centre and pick up a cheap upgrade to an iPhone4S at least. (faster processor & better camera). Your phone is getting outdated and Apple offers a relatively cheap way to get to a better model. But.... if you thing your savvy enough to attempt replacing the LCD unit, here are the instructions. Just remember... you can't take it in to Apple if your attempt fails.
Replacing the display assembly will give you a new front glass panel, digitizer, and LCD. The LCD is adhered to the glass at the factory and the two parts are not separable without damage.
See here:
https://www.ifixit.com/Guide/iPhone+4+Display+Assembly+Replacement/11755
Cheers
Trevor
Jul 21, 2014 | Apple iPhone 4 Black Smartphone
Iphone 5 Front Screen Broken
You could visit your local Apple Store. To repair the screen runs around $149 dollars and takes around half an hour. They will also probably offer to replace the entire phone or around $229 dollars. Had a co-worker with the same issue last week and the above is what happened to him. Hope that helps!
Jun 24, 2013 | Cell Phones
My nokia c5-03 is fell down now 4 black lines occurs in my display wt is d solution sir.
Broken front panel
Take a deep breath and see if your iPhone will turn on and operate normally. In most cases, the iPhone is still functional but now a cosmetic disaster. Unfortunately, the iPhone 4S' front glass and LCD are fused together and must be replaced as one piece.
Broken rear panel
Apple did not grace the rear panel of the iPhone 4S with the same high-strength glass as the front, so fractures are much easier to come by on the backside. If your rear panel is smashed, you must replace it with a new one. Before attempting this repair, though, make sure you have the correct screwdriver.
God bless you
Jun 01, 2013 | Cell Phones
Nokia e90 display
Broken front panel
Broken rear panel
God bless you
Replaced the broken glass front of my iphone 3GS. Everything looked fine, but the slider on the screen does not work... Did the replacement protocol all over again, but nope no slider. Any...
On touch screen phones like the iphone and N97, when replacing the screen there is a small ribbon attched to the back of the screen that connects to the main circuit board.This ribbon allows your phone to recognize you touching the screen and makes the screen work. Take the front cover back off and check that the connector is clean and dust free (on the new screen and on the phone) reconnect the ribbon and push down gently until its securely in place and re-attach the screen to your handset.
This should solve your problem and hope it helps please rate thanks
Mar 19, 2011 | Cell Phones
Broken touch screen glass
If the touch screen is broken you need to get the digitzer and front lens replaced. I recommend having it done professionally but you can find out how to do it yourself online.
Broken Iphone 3G Glass Repair
Jan 09, 2010 | Apple iPhone 3G Black Smartphone
Iphone face cracked
Here is an iPhone Repair Guide that shows how to open an iphone. a and replace the glass. Once it is open it's as easy as prying the old glass off the front assembly and installing a new one, the parts are available on ebay.
Mar 15, 2009 | Apple iPhone 3G Black Smartphone
Broken touch screen lcd glass cover
Yes you can find the glass on Ebay and there is an iphone glass replacement guide online that shows you exactly how to replace the glass.
Jun 08, 2008 | Apple iPhone Smartphone
Broken outside screen on razr V3i
hi guide to place front broken glass v3i open phone at the top you will 2 rubber covers remove them with a pin (pick them out) then at the bottom it will be the same but these are little round rubbers also pick the out now you should have 4 screws visible use the screw driver to remove them then once removed use the prize tool and insert it in the bottom of the v3 twist it and it should unclip remove outer panel remove glass its stuck on there very tightly but asgain prize it off then put the phone back together but dont put your glass in yet wait till its back together then remove backing tape from new glass and push it in place once your phones back together but dont push to hard lol or you will need another glass hope this helps mrjazon
Sep 03, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
