Question about Hawking (HWUG1) 802.11g/b Wireless Adapter
Hawking HWUG1 Wireless Adapter
I was having problems with my girlfriend hooking up to my belkin wireless network from a room distant from the router and so I bought the Hawking HWUG1 to use as an extender. It gave a minimal boost and therefore we uninstalled the software. When we did that her laptop's wireless would not connect and said that it was not configured to manage the connection. It seems that the uninstall had taken away an XP file that was used to automatically configure the laptop's wireless. I reinstalled the Hawking software and now her laptop will connect. How can I uninstall the Hawking and have her laptop's wireless function as it did before the initial installation of the Hawking software?
Thanks
First install the hawking software. then when it's done go to the c file and enter to the softer file. there u can see some files of the xp files. just copy the files to the xp file and ur work have been done uninstall the hawking software.....
Posted on Dec 03, 2008
  • 3 Answers
Are you using WINXP? Open NETWORK CONNECTIONS, right click on wifi icon. Click on PROPERTIES. When the popup appears, click WIRELESS NETWORKS. At the top left corner, you should see a box to be checked, followed by the sentence USE WINDOWS TO CONFIGURE MY WIRELESS SETTINGS. If box is not check marked, click it. This will allow WINDOWS to become the primary control for your wireless. I too, use the Hawking HWUG1 usb adapter. I also use the Hawking HA12W wifi antenna. Pricey at $50USD, but improves performance drastically! Hope this helps.
73, n1osg
Posted on Nov 09, 2008
    Master:
  • 538 Answers
Before you remove the hawking software, go to the site for her computer, and download the wireless utility, and keep it handy on the desktop.
remove the hawking software, then re install the wireless drivers from the desktop file.
should work nicely
Posted on Oct 23, 2008
I have a modem hooked up to one computer in my room, but my mom wants internet on her computer in her room, so I went to WalMart and they gave me this and told me it would work. However I really doubted...
You have mentioned that you have a modem connected to one computer already, if you want to access another computer from a different computer through a wireless adapter then you need a wireless router or access point to transmit the wireless signal, because the Belkin N150 Wireless USB adapter which you have bought is just a "receiver".
If you have router already connected to your modem then please give the brand name of the router you have
Thanks & Regards,
Prema.
Jan 06, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
Have a linksy's router and just got a belkin adaptor for the other room.won't work.
the router is Linksys and the adapter is belkin. Well both the devices are compatible with each other. When you tr y to connect to the wireless network , do you see your wireless network ? What is the operating system on the computer ? If it is XP and you are using the Belkin utility to connect to the wireless network , then it will be better to switch over to XP utility. Make sure that you have the correct network key for the wireless network. If you don't know the network password then you will need to access the router set up. Click Here for step by step solutions
Nov 17, 2009 | Belkin Computers & Internet
Laptop and iPhones cannot connect to my network unless they are i
hi! I will be more than glad to help u in this concern..your using a wireless n router and the n router will work with the signal properly if u are using a wireless n network adapter. If you are using a wireless g adapter then u need to use a wireless n range expander in order for the other wireless g adapter to get good signal..or try buying a antena which 9 dbi which will boost the signal from your wireless g adapter..
Aug 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hawking extender hangs
They just issued new firmware: http://www.hawkingtech.com/support/details.php?CatID=32&FamID=105&ProdID=394#Firmware
You might try that...
-Tom-
Dec 26, 2008 | Hawking 802.11g Wireless-G Range Extender
Boost signal to allow xbox live
1 buy and cantenna and a hawking hwug1 (from hawking website). install hawking on computer (usb wireless device) and then run the network wizard to make the connection a proxy server. run a lan cable from the computer to the xbox, and enable the wireless connection on the laptop to be shared with other computers on the network.
Sep 25, 2008 | HP Pavilion dv6000z Notebook
Can't connect to internet
Start-NETWORK CONNECTIONS-right click wifi icon-click properties-click ENABLE. If DISABLE showing, click REPAIR. Hope this helps. The other possibility is no wifi service is in range. Are you able to "see" any AP's in range? Right click the wifi icon, Then click VIEW AVAILABLE WIRELESS NETWORKS. When popup is displayed, do the displayed networks have the lock symbol indicated? These are encrypted networks, and you either need the encryption key, or find an open AP. Hope this helps.
Mar 19, 2008 | Hawking (HWUG1) 802.11g/b Wireless Adapter
Wireless problems
hi sir
when u r trying to connect it with urs gfs laptop
make sure u type in the correct security wep key
thank you
mike
Jan 18, 2008 | Belkin (F5D9230-4) Wireless Router...
Hawking (HWUG1) 802.11g/b Wireless Adapter Logo
688 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
