Question about RCA D52W19 52" Rear Projection Television
The capacitor for the D52 TV
Is this the Film Capacitor your referring to? I have to been to component stores and tv repair shops. I can't find one of these film capacitors anywhere. Where would you suggest?
  • RCA Master
  • 5,138 Answers
Electronix Parts 1-800-233-3205
Posted on Dec 19, 2008
I have a wd-65738 TV . Heard pop no picture with
That pop was probably a capacitor blowing up in the power supply. Could be another power component too. Get an estimate from a TV repair shop first to see if it's worth fixing or flat screen TV time.
Sep 07, 2014 | Televison & Video
Old Magnavox television - will not switch on
The problem could be the capacitors to the power supply. WARNING: capacitors carry very high voltages that can shock and kill. I don't know what your skill level is: you would have to 1.) disconnect the power cord from the wall outlet and remove the TV's casement, exposing the internal electronic components. Although lower voltage capacitors will drain and discharge their stored electrical energy over time; larger voltage capacitors (not to be confused with the physical size of a capacitor) do not.
You would have to either discharge all the capacitors using a resistor (3 watts or greater) or by shorting out the legs of the capacitor using an insulated screwdriver rated for high voltages.
To make sure that the capacitors were properly discharged, verify the process using an ohm meter. There are a slew of YOUTUBE videos basics on capacitors; how to identify a bad capacitor; how to discharge a capacitor safely; how to de-solder components and perform re-work soldering. If you need more help I'm happy to oblige. Best wishes, I hope my comments were helpful.
Mar 07, 2014 | Televison & Video
We was watching the tv . we heard a big pop the picture was gone we did have sound if we turn it on it is on a minute then shuts off
A component in the TV has failed, maybe a capacitor, but can't tell without looking at it. Would need to take it to a repair shop for diagnosis and repair.
Jan 02, 2011 | Mitsubishi WD-65733 65" HDTV
My screen goes directly to black when I turn on the television. The Memorex trademark comes up first and that's it.
I worked in electronic repair for 20 + years and recently have have this model in my shop...the problem turned out to be a ruptured electrolytic capacitor on the power supply board reference number EC17 in the backlight inverter supply....Changed this capacitor along with the capacitor next to it ref # EC18, and television worked fine...these capacitors are rated for high temp and high frequency...their value is 10uF/450Volt 105 degrees C...you can obtain them from NTE electronics at a cost of about 4-6 dollars each.
Nov 15, 2010 | Memorex MLT3221 32 in. LCD TV
Tv wont turn on
Issue with Main Power Board..Fail to innitiate to logic board Due to over heat ..Check Hi Voltage board for over heat regulator and Capacitor as to be check for fail signal... May afect IF Board and RF Board for over power Due to Over Heat component ...Refer to Professtional TV Repair ..
Sep 30, 2010 | RCA L42WD22 42 in. LCD Television
My son was moving his sanyo 25" tv in his room and forgot to unhook the cable from the rear of the tv. He ripped the cable nipple out of the rear of the tv, splitting the capacitor connecting to it in the...
Please take this disk capacitor to a commercial electronics store. For example an authorized TV shop, A general electronic supply or an NTE Supply reference catalog. A very good source of info would be your local telephone yellow pages!!!! By far the best place to look. Thanks for asking and good luck!
Jul 03, 2010 | Sanyo DS25390 TV
TV won't stay on...
Either the capacitors in the power supply are bad, or the caps on the main board. You can test them with a capacitor tester or ohmmeter.
It is common, especially in newer devices.
Replacement Parts: Replace the original four (4) 1000µF, 16V, 85ºC capacitors on the DM Module with Radial Polarized, 1000µF, 35V, 105ºC Capacitors.
Description: Computer Grade Electrolytic Capacitors or High Temp Electrolytic Capacitors; Capacitance = 1000µF; Voltage = 35 V; Operating Temperature Range = - 20º C to + 105º C; Termination Style = Radial, Operating Hours = 10,000 Life Hours. The original DM capacitors are rated at 1000µF, 16V, 85ºC. Do not use capacitors with this rating to repair your Mitsubishi television, or else the same issue will reappear in 1-2 years.
The capacitors are available from several on-line electronics stores and possibly from a local television repair
GA_googleFillSlot("TL-IMU-Article"); shop. I recommend that you use ONLY high temp Capacitors rated at 105º C, with a voltage rating of 35 V. Refer to the "General Information" section below for additional information about purchasing the capacitors from a online website.
Oct 28, 2009 | Disney DTD1363-CAR 13" TV/DVD
My jvc av-32d302 tv has sound but i cant get an image i get just a black screen. if i unplug it and plug it in real quick i get a snow image for a second and then it goes black
There is a problem in the power supply, a defective voltage regulator or a bad capacitor. It is a good idea to call your tv repair shop and ask on what a repair would run.
Sep 10, 2009 | JVC AV-32D302 TV
Vertical lines appearing acros the bottom half of my 60' LCD LG...the TV also cuts off when it wrms up. Help
This sounds like a faulty component. The fact that it cuts out when warming up indicates a component is overheating inside the TV, such as a microprocessor or capacitor. Have a TV repair shop take a look at it, or contact where you bought it from if still under warranty.
Apr 19, 2009 | Computers & Internet
Sanyo DS25390 Cable Terminal Ripped off
I personaly would replace the entire unit, the capacitor is a Ceramic "DC Blocking/Couplng" capacitor, possibly a 0.001uF cap... I should think if ya take it to any component supplier/radio repair shop or the like they would be able to give ya a replacement?
Jul 30, 2007 | Sanyo DS25390 TV
RCA D52W19 52" Rear Projection Television Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
