Apple iPhone Smartphone Logo
Posted on Oct 23, 2008
Iphone will not let me enter my passcode
Anonymous
Level 1:
  • Contributor 53 Answers
  • Posted on Feb 18, 2009
Anonymous
Contributor
Level 1:
Answers
53
Questions
0
Helped
12232
Points
74
Connect to itunes and try agian
2answers
How to bypass lock screen on iphone 4s
Actually you can. Just follow below steps to turn off screen lock.
To turn off lock screen on iPhone means to turn off passcode. So your lock screen'd disappear as long as your passcode is disabled. Here's how you can disable passcode on iPhone.
Step 1: Open Settings then tap Touch ID & Passcode.
Step 2: The Turn Passcode Off option is right on top of the setting, just tap it and move on to the third step
Step 3: Your original passcode is needed if you are trying to disable the passcode. Enter your original passcode.
Step 4: There is a popping out box asking for your confirmation of turning off the password, tap Turn Off and the iPhone screen lock will be turned off.
When the passcode is disabled, you will no longer have to enter it. But what if you just do not want to enter it over too frequently without turning off lock screen iPhone? The following instructions will show you how to do this.
For more details, please check: How to turn off lock screen on iPhone
How do I turn off the security on my iphone4s
iOS 7 instructions:-
1. Open "Settings" App on your iPhone or iPad, or iPod Touch devices.
2. Scroll down below and select "Touch Id & Passcode" or simply "Passcode" option
3. Enter your current passcode to continue.
4. Then scroll down and tap on "Turn Passcode Off". Enter your current passcode to continue. Se below.
iPhone:
2answers
How to reset restriction passcode
JUST RESTORE YOUR PHONE IN DFU MODE WITH LATEST UPDATE
ALL DATA WILL BE LOST SO BE SURE TO BACKUP ALL
FOR DFU MODE
CONNECT YOUR PHONE TO PC
HOLD POWER + HOME BUTTON WHEN SCREEN GOES OFF
COUNT UPTO 6 AND RELEASE POWER BUTTON WHILE HOLDING HOME BUTTON
Put in wrong password on the phone too many times, now i cant log in to my google acct on it either, its just stuck at the same spot
What Brand and Type of phone ??..
Phone password or google account password ??..
Im thinking iphone ?
Although a passcode limits your iPhone to authorized use only, protecting your vital personal information, if you forget it, you can't use your phone until you enter the correct code or revert your phone to the default factory status.
Apple provides ways to resolve a forgotten passcode problem and improve the iPhone's security.
Wrong Passcode
When you enable iPhone passcode security, the phone requires you to enter the code to display the home screen.
By default, when this protection feature is enabled, you'll be prompted to enter the passcode to turn on or restart the iPhone, wake it or unlock the screen.
When you enter the wrong passcode, the "Wrong Passcode try again" message appears onscreen.
If you enter the incorrect code too many times, the iPhone will lock automatically and display the "iPhone is disabled, try again in 1 minute" message.
This disabling security feature is designed to protect it from unauthorized tampering.
If you keep entering the incorrect code, the iPhone will be disabled for a longer time.
Restoring iPhone
If you don't remember your passcode, unfortunately, there is no way to retrieve it.
Apple says that the only way to solve passcode problems is to restore the iPhone with iTunes.
Before restoring the phone, downloading and installing the latest version of iTunes will improve connection and decrease the chances of errors.
Unfortunately, restoring the iPhone erases saved content and clears custom settings, so create a backup copy of your files with iTunes before proceeding.
From there, you can restore your iPhone by clicking the "Restore" button on the device's "Summary" tab in iTunes.
When the process completes, you can change the passcode settings.
Changing Passcode Settings
iPhone allows you to not only create a new passcode, but specify the amount of time it should take before the screen locks after inactivity.
You can also specify whether you want to use a simple four-digit passcode or a longer one that can include letters and numbers.
Tapping the "Settings" icon on the home screen will bring up the phone's settings.
From there, tapping "General" and then tapping "Passcode Lock" will bring up the "Passcode Lock" customization screen.
Select the settings you want to use to protect your iPhone. The changes will take effect immediately or when the iPhone turns off.
Tips
After restoring your iPhone, create a passcode you'll remember easily.
While creating a longer passcode can increase the security on your phone, you can forget it easily if you don't write it down and store it in a safe place.
gmail password reset
Open the Web browser on your phone and navigate to gmail.com.
Tap "Can't access your account" located under the "Sign in" button.
Select "I forgot my password" and then click "Reset your password here."
Type your email into the "Email" text box and then type the random captcha into the captcha text box.
An email with your new Gmail password will be sent to your alternate Gmail address.
Follow the directions in the email to reset your password.
Type the new Gmail password into the loin screen on your Droid to unlock the account.
http://www.gmail.com/
How can i find my passcode restriction code on my iphone 4s
As for your issue, you can fix it with following instruction.
Step 1: Tap on Settings, then go to General.
Step 2: Tap on Restriction, and enter your existing passcode.
Step 3: Tap on Disable Restrictions, and enter your existing passcode again.
Step 4: Tap on Enable Restrictions, and enter (twice) new passcode.
For more details, check: How to Reset Restrictions Passcode on iPhone
23helpful
3answers
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
What do i do after locking my iphone with too many passcode attempts
If you have forgotten your iPhone’s Passcode you will need to restore your phone via iTunes.
1. First you have to put your phone into the restore mode which is a slightly fiddly process.
2. Plug your iPhone into your PC or Mac with the USB cable
3. Press and hold the power button at the top and then slide to power off the iPhone
4. Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
5. After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
6. Open up iTunes and click on the Summary tab
7. Click on Restore to restore your iPhone. This will reset all your iPhone’s setting to the factory defaults, including the Passcode.
You should then follow these steps below to activate the passcode again.
  1. Click the Home button to bring up the main menu
  2. Click on Settings
  3. In the Settings screen click on General
  4. In the General screen click on Passcode Lock
  5. This will open the Set Passcode screen. Enter a memorable 4-figure code and re-enter it when prompted
  6. You will now be at the Passcode Lock screen. You can change when you are prompted to enter the Passcode. The default setting – Immediately – means you will be asked to enter it as soon as your start using the iPhone. But you can change the setting so that the prompt appears after a certain period of use
  7. Press the Home button to return to the main menu.
1helpful
2answers
Forgot my passcode
Bad News... you may have to Restore from iTunes. Here is some info from the users manual:
Passcode Lock By default, iPhone doesn’t require you to enter a passcode to unlock it. Set a passcode: Choose General > Passcode Lock and enter a 4-digit passcode, then enter the passcode again to verify it. iPhone then requires you to enter the passcode to unlock it or to display the passcode lock settings.
Turn passcode lock off: Choose General > Passcode Lock, enter your passcode, and tap Turn Passcode Off, then enter your passcode again. Change the passcode: Choose General > Passcode Lock, enter your passcode, and tap Change Passcode. Enter your passcode again, then enter and reenter your new passcode.
If you forget your passcode, you must restore the iPhone software. See “Updating and Restoring iPhone Software” on page 204.
Set how long before your passcode is required: Choose General > Passcode Lock and enter your passcode. Tap Require Passcode, then select how long iPhone can be idle before you need to enter a passcode to unlock it.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
