Question about MSI K8MM-V Motherboard
No POST from my MSI Motherboard
My MSI motherboard is getting power and that's it, nothing else, there is no display coming up on the screen, not hearing any beeps for post or the supposed errors. I also tried cleaning for dust but that too is to no avail
  • 1 more comment
  • Kibwe Wilson Oct 24, 2008
    Hey back at yuh even though i'm am not getting any shrill beep i also tried that as one of the troubleshooting techniques and still nothin. Anymore suggestions
  • jason May 11, 2010
    that beep sometimes just quits , mine did but everything else is good
    have you tried another monitor? or if you have a video card try that
    because if the computer starts up but no video is being processed , then it could be the on board video chip that quit, were you experiencing video stopping wihile you were watching something before this happend?
    do you have the fan that has three wires , on the processor?
    clr bios in the run position?
    what do you have hooked up?
Hey dude when u are turning on ur computer is it making a really shrill beep and nothing is coming up on the screen? if so why don't u try opening the ram and then putting it in again or just putting a new ram in.
Posted on Oct 23, 2008
MSI PM8M-V Motherboard with Power no Display No power on keyboard
A continuous beep POST error usually means there is a RAM problem.
Try re-seating the RAM, and if you still have a problem then take the RAM to your friendly computer repair shop to test the RAM for you.
Jan 20, 2013 | MSI PM8M-V Motherboard
No display on msi 7142 on start up Hi there. When i put my pc on there is no display.The screen when unplug says no signal.but if i put it back on the motherboard it does not show that message,so there is...
When you power on does it beep once and then seem like it boots even though you can't see the screen? Does the caps lock light on the keyboard (if you have one) toggle on and off when you press the key?
Jul 09, 2017 | MSI K8MM-V Motherboard
Installed a new msi 88ogm - e43 motherboard with a amd phenom 2 processer and get no boot/post message of any kid
Go ahead and remove everything but the processor, heat sink, PSU, and the power connectors to the board and attempt to boot up like that. If you still are unable to boot up check to see if you have any yellow lights on your board, if so either your board or power supply are damaged.
Mar 30, 2011 | MSI 880GME41 AM3 AMD 880G HDMI Micro ATX...
No display
first thing, make sure there is a speaker so you can hear the beep codes, those are critical, and then configure your computer with the least amount of prepherals possible, one ram module, the cpu,and the integrated video card, if no integrated, then only one video card, try pulling out all ram modules and listen for a beep code, they can be very quiet, lastly stalk the motherboard for burnmarks, you could have a fried board, especially if you disconnected something while it was on, or within 15 seconds of disconnecting power...
Feb 17, 2010 | MSI K9N6PGM2-V Motherboard
I Just installed a new board ASUS MS 7061 in to HP Pavillion and i cant see nothing on the screen it sounds like it turns on but it wont display nothing on screen
Just a couple of suggestions to get you started.
Make sure the 4pin cpu connector is plugged in, and the memory is properly seated. Please post back if the problem is unresolved.
Thanks
Feb 02, 2010 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
Problems with the P35 Platinum board. Gets stuck at the full screen logo display feature, cant go to POST nor bios.
that's easy check on the motherboard for a battery pull out but carefull to not brake the support put it back and try again .
Nov 30, 2009 | MSI P35D3 Platinum Motherboard
Msi k9mm-v mobo doesn't post
Remove your memory card in the DIMM slots and insert it again. Reset also your bios. To do this, refer to the motherboard manual.
Oct 27, 2009 | MSI K9MM-V Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
MSI K8N NEO2 Platinum NOT Posting + No beep + No display
try to test the CPU on another machine ...
or at least remove it and reinsert it.
But if u say that u reseted the BIOS an it still not doing the post, it just could be that the motherboard is out !
It can also be the PSU as u say, but i doubd it ! Try to remove all hard drives, cdroms, etc... to limit the power usage... and see if it passes the post.
U can also try to remove the motherboard from the computer case and put it on an insolating surface and than try to boot (sometimes shorts appeare betwen the motherbord- case - psu)
Jan 08, 2009 | MSI K8N NEO2-Platinum (MS7025) Motherboard
MSI K8MM-V Motherboard Logo
753 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
