Question about Fujitsu FI-4860C2
Non working unit
Shows error code: Front Side Background Alarm..
Pulls paper on test mode thru machine. When on kofax software, paper is pulled and stops at entry feed rollers. Could this be a bad sensor?
Please advise ,thanks, Walt
  • 4 Answers
Just clean all mirrors & lense of front side CCD
Posted on Jul 03, 2009
Error EF
The error code EF displayed on your fi-5750c scanner front panel explains Background switching mechanism alarm. The probable causes are:- Background detection sensor connector disconnected.
- Defective background detection sensor
- BW motor connector disconnected, Defective BW motor
- Defective background unit F
- Defective background unit B
You are rceommended to visit nearest Fujitsu service station for rectification.
Thanks & regards,
ScanCare
Nov 07, 2013 | Fujitsu fi-5750C Flatbed Scanner
Hi, i have a Canon dr 9050c scanner. I have the folowing Problem: When the Scanner power on then the Tray move up and down. if i start a scan from PC than can the Scanner not lift up the tray. It sounds...
It sounds like you diagnosed it.
The tray "paper detect sensor" thinks it has paper in it, and if it doesn't have paper in it...there's a problem with the sensor.
Take the tray off and inspect the sensor. Blow out around the sensor and it's PCB and make sure it is not out of position. Check the sensor lens for anything blocking it, and retest. If it still shows always on, then replace the sensor. Press the "count only" button to illuminate it, and press the "start" button. If the scanner works properly (tray lifts, pulls paper through the scanner, and counts it)...well then you have software or connectivity issue.
Hope that helps,
Scan-R-Store Scan Store provides service and maintenance contracts on all Canon Fujitsu...
Aug 26, 2013 | Canon DR Office Equipment & Supplies
Has Fujitsu fi-4340c scanner. Worked for a while then it showed Front Side Optical Alarm. I tried to clean sheet path, and replaced roller and pickup pad. Still the same error. Does anyone has the...
Explanation:
Front Side Optical Alarm only generated when start command is received or when white level reference is checked (every 50 scans). CCD output must be above predetermined slice level when reading the white reference. Slice level is set in F/W and compared to the read range values. The read range is approximately pixel 120 to 4800. If CCD output does not reach slice level the AGC tries to adjust the output of the amplifier to exceed the slice level. If any portion of the read range is lower than slice then Optical Alarm is generated. Also, it can be generated by dirty optics or reference, bad lamp or CCD.
Resolution:
If "Front Side Optical Alarm" appeared, clean the glass (small and large one) of the flatbed and carrier unit.
If the issue persists, then check if CCD harness or CR cable is disconnected? Connect the connector.
If the issue persists, then replace Front lamp.
If the issue is not resolved, then replace the Control PCA or Carrier unit or Optical unit.
Pls acknowledge if the issue is resolved.
Regards,
Tech Satya
Dec 08, 2009 | Fujitsu fi-4340C Flatbed Scanner
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
Fujitsu M4099D
Sounds then like a loose camera cable , dirty glass, or white background plate.
Jul 11, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Fujitsu 4860c scanner error
There are 2 sensors on the background unit(Front) SF1.5 and SF 2
Both sensors look like black boxes. SF2 is nearest the reading glass and SF1.5 is below it. Make sure both are clean. There are also tests you can run in test mode to recalibrate the sensors, if that doesn't work you have to replace it.
Apr 24, 2008 | Fujitsu FI-4860C2
Fujitsu M4097D error about Front side optical alarm
HI,
I work on the fujitsu scanner hotline. This message means that the optical unit needs to be replaced, there will be very little you can do to fix this problem.
Apr 06, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Fi 5750c adf will not initialise
Just something simple to try...check your software setting to see if it is set for ADF or Flatbed feeding. You said the light bar moves when power is interupted or the adf opened. But you never said if it is scanning in Flatbed mode. If the Flatbed scans, then check the software setting. Most of the flatbed/adf hybrid scanners start up defaulted to flatbed, so when you try to scan, the adf won't pull anything thru until you change to ADF mode.
Mar 13, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu FI-4860C2 Logo
144 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Mohan Sriraman
Mohan Sriraman
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
