Question about HP Pavilion ze5470us Notebook
Ze5470us DC jack
I am trying to open my ZE5470US laptop to replace the DC jack and there is something keeping the base from seperating from the top. The side where the DC jack is located is where the problem is. I can easily open it at the other three corners. Any ideas or hints?
Thanks, Rodney
Asd
Posted on Oct 30, 2008
Won't charge, purchased new battery and new AC adapter, still does not charge. AC charges other Dell I have so must be in charging circuit or connector. How do I disassembly computer to voltage getting to...
You are right, most of the situations like this end up that the charging connector fixed / soldered to the motherboard get damaged because of shaking the connector when ever we connect and disconnect it .
Mar 06, 2011 | Dell Inspiron 2600 Notebook
I LOST THE SOUND DRIVER AND I CAN`T FIND IT
Goto the Link :-
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=326406
Select the Operating System if anything other than Windows XP and click next. Then under Audio Driver click and download and install it.
Nov 09, 2010 | HP Pavilion ze5470us Notebook
Have hp pavilion ze5470us that powers on but only blinking cursor shows on screen. Was working fine just a few days ago. Nothing new has been added.Hdd tested ok. What else?
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Oct 25, 2010 | HP Pavilion ze5470us Notebook
How to open case Toshiba Satellite L355-s7905 laptop. Relace dc jack. Opening laptop case. Does replacing dc jack require soldering? Does rewiring require soldering, or are there connectors with new dc...
Hi I have the same laptop and had the same thing happen. I am not a tech, just some dude that is handy and has "messed" with hardware for a bit. So this advise is "USE AT YOUR OWN RISK", I'm not responsible for anything. Well with that said here you go.
Remove the batter for safety. As you go keep the screws separated so you don't have to remember which is which when you put it back.
Flip the laptop over and you will find about a dozen screw holes labeled F7. You need to remove all of these to open the laptop. You'll find some running along the back edge of the laptop as well.
In the battery well, you'll find some more screws labeled F4, you should remove these as well.
There is a slider screw towards the right center of the machine that helps hold the cd bay in place, you don't have to remove this one, but you can in the even that you need to move the bay to gain better access to the DC jack.
Once you remove all the screws, flip the laptop up right. Open the screen as if you were going to use it.
Along the top of the keyboard, you will see that the bezel edge has a break away section the same with as the key board.
Using a small flat head screw driver pry it open from either the left or right side, and continue unclipping it across.
This will expose four very small screws. Remove them making sure to keep them safe, as they are holding your keyboard in place. Once you remove them, slowly seperate the keyboard from the body of the laptop. You will find a flat wire connected to the mother board from the keyboard. You can use a toothpick to slowly slide out the white edge from the brown connection bridge. Once you slide the white plastic peace away from the brown the wire will come out easily. BE CAREFUL with the wire since it is very fragile
Now you should have the keyboard separated from the laptop, put it in a safe flat place and continue.
On the left side hand of the laptop body is a card slot, use it as a finger hold to gently but firmly pry the laptop open. It is held together by clips running along both side edges and the front edge. These can be a little tough to open, so apply slow gentle force till you hear them pop open.
Before you pull it apart after unclipping it, use the same method used to remove the keyboard flat wire from the mother board connection on the three connections holding the top part of the machine to the motherboard. You'll find two towards the bottom center and one at the top left corner. Play close attention to the small flat white one as this is VERY fragile and the copper flanges at the end can bend very easily.
At this point you should be able to freely separate the top half (cover) of the pc from the bottom. Exposing the insides.
You'll be able to easy work with the dc jack now, in my case it was the plastic housing of the body of the laptop that broke. I held it in place with a dab of hot glue.
If you find that the CD drive is in your way, you can remove the two small black screws on either side of its copper connector, then lift the back of the bay up of the body and slow pull it and lift towards the left.
Work backwards to put it back together.
Feb 19, 2010 | Toshiba Satellite Pro L300 Notebook
Tech manual for Asus Z96J lap top. need to replace the dc power jack how do I access the power jack?
For all the function and portability laptops provide, there are also some drawbacks. The biggest problem with laptops is with battery life. To get constant battery power, the laptop has to be plugged into a wall outlet. The wall plug then connects to the DC jack in the back of the laptop. The DC jack is no more than a little piece of metal that conducts the electricity for the computer. These DC jacks are known to be fragile and break off easily. If this happens, you can open the laptop and replace the DC jack yourself.
  1. Step 1 Remove the internal battery pack from your laptop. Flip the laptop over and locate the release button for the battery pack. Hold the button in to slide the battery pack free. It is important that you remove the internal battery pack as well as unplug the power cord from the wall outlet to prevent risk of shock while working inside the laptop.
  2. Step 2 Unscrew all of the screws on the underside of your laptop. The number of screws will depend on the model of computer. There should be one at each corner and then one or two screws that hold the hard drivemag-glass_10x10.gif cover in place. Once the screws are removed, take out your computer's hard drive. Newer-model computers will have a hard drive that slides out of the side of the computer.
  3. Step 3 Locate the two screws at the back of the computer that hold the laptop screen's hinges in place. Once these two screws are removed, gently pull up on the screen until you clear the silver pegs from the holes in the laptop's body. Two wires lead from the screen into the computer, so ensure you do not pull so hard that you disconnect them. Carefully set the laptop screen aside so it does not get damaged while you work inside the computer.
  4. Step 4 Separate the two halves of the laptop's body to expose the computer's internal components. Flip the keyboard on its face, making sure not to disconnect the keyboard's connector. Underneath the keyboard will be a metal plate that covers the computer's motherboard. Unscrew the screws that hold this plate in place and set it aside.
  5. Step 5 Locate the DC jack for the laptop. Most all laptop's DC jack outlets are located at the back left corner of the computer. Using your tweezers, remove the old DC jack. Identify the slot in the motherboard that the old DC jack came out of. If the DC jack was loose before you removed it, there will be a small slot at the base of the opening in the back of the computer that the DC jack pops into. Using the tweezers again, slide the new DC jack into this slot until you hear a clicking sound. To hold it in place you can solder the new jack to the motherboard, or simply superglue it in place. Don't use too much superglue or you will risk losing the ability for the jack to conduct electricity.
Nov 14, 2009 | Computers & Internet
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
HP ze5470us memory upgrade not fully recognized
I am almost sure that you, by accident of course, switched the memory blocs, so that you have put in one 256MB and one 512MB.
Have a look at the once you have on the table.
/Teis
Jan 06, 2009 | HP Pavilion ze5470us Notebook
Power problem
You need to remove the screws on the bottom of the laptop. Once the right screws are removed the case will seperate exposing the MOBO and that and you should see the dc jack (power jack) as forwarning, almost ALL dc jacks are sodered to the motherboard..and not easy to successfully replace.
Jul 24, 2008 | Averatec 3200 Notebook
Toshiba Satellite 1415-S173
Hi
DC jack replacement is easy however requires a bit care since its mounted on the mainboard. Desolder the old DC jack. Solder the new one firmly. Dont keep the soldering iron too long on the PCB as it will damage the lines and will deform the DC Jack. You can get DC jack very low cos from local repair stores or you can order from Toshiba parts depot (800-524-8338)
Please post your question if you need further assistance.
Good Luck
Feb 09, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
"Burned" DC in power adapter
hi there generally all laptops can be opened more or less in the same way first undo all screws in the back, next you need to remove the panel where the power button is most of them just unclip and come off easily using a flat screw driver, you'll probably find some more screws underneath,if the hinges covers are part of the panel they should come off with the panel if seperate just check for any screws if not they just unclip undo any further screws, next unscrew the keyboard, unplug it, unplug the mouse pad, then the top part of the laptop base should just lift easily, make sure you remove the battery before you start all this, any drives, hard drive, etc hope this would be of some help regards
Jun 21, 2007 | Sony VAIO GRX550 Notebook
HP Pavilion ze5470us Notebook Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
