Question about Broderbund PrintMaster Gold 11 for PC
Printmaster Gold 11 have a watermark feature?
Print Shop Deluxe 15 is corrupt and prints with 1 1/2 inch top margin so I'm using Printmaster Gold 11. Does Printmaster Gold 11 have the Watermark feature?
2 Suggested Answers
SOURCE: Can I add a watermark to a flyer using Printmaster...
I am trying to install a watermark to a document with print master gold 18. I'm having absolutely no success whatsoever. Anyone withany suggestions
Posted on Oct 23, 2010
Can't send images via emial to someone who doesn't have printmaster
As far as sending E-Mail is concern, sending an email with photos doesn't need Print Master. Please, it means that you are doing something wrong while emailing.
Oct 22, 2012 | Broderbund PrintMaster Gold 11 for PC
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
We are using 8 1/2 x 11 letter size paper. When we print, the top of page is cut off. How do we correct the alignment?
Have you checked the top margin setting of your print job. It should be less than 1/4 inch. If set higher it may cut off the top of the page, before it's sent to the printer. The printer will not print anything within 1/4 inch of the edge of the page, by design.
Feb 01, 2011 | HP LaserJet 6p Printer
Can I add a watermark to a flyer using Printmaster Gold 18?
May 20, 2010 | Broderbund PrintMaster Gold Version 18
I have Printmaster gold. It will not use the
You need to enter the printer properties in your control panel and turn on the duplex feature. In properties you select paper size, orientation, print quality, and also duplex printing.
Apr 20, 2010 | Office Equipment & Supplies
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Printmaster gold will not center print job
there should be a box to allow you to enter figures for the margins in the setup print job bottom margin etc put a figure in here usually centimetre or millimetres adjust untill your perfect print test page
Find the setup box ! might find it the drop down menu s at the top of the page good luck!
Dec 26, 2008 | Broderbund PrintMaster Gold 16 for PC
Printed 12 inches
check the page setup for header and footer margin sizes and top or bottom margin sizes .
May 13, 2017 | Tally LA650 Matrix Printer
Printing Large Top Margin
check the header and top margin in your application. (word, Note pad, etc..)
default top margin for Microsoft word is 1".
also check the orientation of the printer output.
Nov 24, 2008 | Samsung CLP-500 Laser Printer
Broderbund PrintMaster Gold 11 for PC Logo
69 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
