Question about Panasonic Audio Players & Recorders
Panasonic sc-rt50 af f61
Af-f61 error message
  • 4102 Answers
SOURCE: unlock panasonic sc-rt 50 home theater
hi what code do you need is it the region unlock code or code because the device is locked i need more info before i can assist you further ok
Posted on Mar 18, 2008
SOURCE: Error Message F61
Hi guys,
just had the f61 error code on my home theatre system, now i work with samsung dvds and tv's so the background knowledge is there ( i hope), i dont know if u guys noticed the fans making a noise whenever you switched it on before the fault happened but mine were making a hell of a noise, this prompted me to have a look inside and find 2 fans both of which were very dusty, just a 10 minute clean and a 10 min reassemble and im back up and running on all channels.
hope this helps guys
Posted on Sep 12, 2008
appman67
  • 33 Answers
SOURCE: f61 fault
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Posted on Sep 21, 2008
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Posted on Apr 14, 2009
  • 189 Answers
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Posted on May 12, 2010
What does error message F61 mean on Panasonic SC-AK25 Shelf System
Problem with the amplifier assembly. Check to see if the fan is spinning and if not there could be alot of dust on it which is preventing the unit from powering up. If the fans fine its going to be the I.C audio chip.
Feb 20, 2012 | Panasonic SC-AK25 Shelf System
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Error F61 How to reset SC-HT995W system?
I'm sorry to say, but an F61 error can not be cleared by a reset. Please see the link below for an explanation of protect mode (F61 is Panasonic's version of protect). Usually the output amp pac will need to be replaced. This will cost between $75 and $100 for the part. Feel free to post any additional questions here.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Oct 19, 2010 | Panasonic SC-HT995W System
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
Dec 24, 2008 | Panasonic SC-BT100 Theater System
SC-RT50 Decoding Surround Sound From Aux and Inputs
The other players need to be setup to output digital sound. Assuming you are using a digital or optical audio cable, go into the setup screen of the Blu-Ray or Tivo etc. and select the audio setup screen. Set the audio output to PCM.
Sep 07, 2008 | Panasonic SC-RT50 System
Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
Aug 30, 2008 | Panasonic SC-HT700 System
Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
May 30, 2008 | Panasonic SC-AK600 CD Shelf System
F61
check the fan
If one fan dosent work it will show the error F61
May 15, 2008 | Panasonic SC-HT940 System
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
