Question about Epson Stylus Photo 925 InkJet Printer
Epson 925 printer spinning/whining action
My Epson 925 printer just shoved out a bunch of paper then when into a whining spin, then the 'general error' message came on. I cannot find anything in the manaul that disucsses a 'spinning' sound. With the cover open, when I turn it off and back on I can see the the belts or bands (tan in color) moving quickly and making the spinning, whining sound. I can't clear the error, or make it quit the spinning. Any suggestions? This printer is about 4 years old and has never had any problem (except when I use cheap paper which causes paper jams!).
  • Anonymous May 23, 2008
  • Anonymous Apr 02, 2009
    Hi the same problem as you, if you solve the problem please let me know, thanks mel.
  • 70 Answers
This is the typical symptom of a paper missed & jam. Clear the paper larger and try again. BE SURE TO UNPLUG ELECTRIC PLUG.
Posted on May 02, 2017
silly girl
  • 513 Answers
SOURCE: jammed
First of all, look at the paper you pulled out - if it's in one piece, no corners missing, then the error isn't a paper jam thing. Now turn off the printer, push "stop", maintenace button and power button toghether, till a message appears. I also found the following tip that's also related to the same error, could be usefull: "As Epson printer users will know, waste ink from head cleaning etc. is channeled into absorbent pads in the base of the printer. Eventually these will fill up and need to be replaced, and some time before they actually fill the waste ink counter in the printer's firmware will signal an error and the machine won't print any more until the counter is reset. This normally requires a trip to the service depot (if the printer's worth the cost, and if it's realised that this is the problem -- lots of otherwise good printers go to the dump through this relatively minor problem.) The service depots have a program that can, among other things, reset this counter (but of course won't part with it -- there's money to be made, new pads to be sold...) There's a third-party utility available that can do this (look for sscserve.exe on the 'net -- carefully read the documentation and use it with great care...), but at the same time the pads need to be changed, otherwise you risk ink pooling in the base, sometimes finding its way out and making a right mess. Replacing the pads isn't for the faint-hearted, you have to virtually dismantle the printer to reach them. Here's how to get around it -- the two pictures below are almost self-explanatory: On the left rear of these printers is a small trapdoor held by a single screw. Remove it, look inside (down and to your left) and you'll see the waste ink tube. The tube is free at one end, and with a suitably curved piece of wire you can hook it and wangle the end out through the opening (you may dislodge a small piece of plastic in the process -- just put it back where it was, it's only a vibration damper.) At this point, you're almost there. All you need now is a suitable container for the waste ink, and to file a small slot in the trapdoor cover so you can put it back without pinching the tube (or you could just lave it off.) The container in the photo is a small square one with a snap-on lid, approx. 60mm square and holding about 150ml -- they're sold in sets of three for a few cents and are for making ice-blocks etc. in your freezer. Make a hole in the lid as shown (slightly larger than the tube to let air escape) insert the tube and forget about the internal pads forever. (I've used a new machine for the photos, don't expect the tube in yours to look so clean.)" Good luck
Posted on May 23, 2006
SOURCE: general error - see your printer Documentation for information about clearing the error.
I have the same problem. The printer makes a whiney noise when I turn it on and I get the same error message. I loaded the wrong type of paper into the printer and grabbed it out from the rear of before i realized what i'd done now i get the general error messase that will not clear regardless of no paper being jammed or any other obstruction that i can see.
Posted on Mar 22, 2009
jasahasch
  • 36 Answers
SOURCE: When I turn on my printer it makes a whining sound
Hello, dreadhead68
How old is the printer? Printer will ware out after a few years, I had an InkJet, and it sounds like yours is doinf the same thing mine did before I had to replace the unit. My printing unit made a single move then ... nothing after that.
Have you tried to re-install the software for the printer? How was it working prior to this?
Posted on Aug 13, 2009
SOURCE: keep getting the error message "Paper jam"
mine does too! help
Posted on Sep 18, 2009
  • 14 Answers
SOURCE: Epson RX595 says "Error-paper jam" but no paper in printer!!!
Press the stop/clear button then press the maintaince button(spanner) and the ON button all at the same time in that order.That will reset it.It should work after that.Hope this helps you.
Posted on Apr 26, 2010
I have Epson stylus photo 925 and get horizontal lines on printed page. I have run the Print Head Alignment program but the printout is too light to see. Aolution?
Hi
I suggest you clean it manually by removing the print head and then rub the print head in a plain paper with isopropyl alcohol until ink flows. Return the ink cartridge into the printer and run the print nozzle for 2-3 times.
Please let me know if you need more help.
Mar 05, 2011 | Epson Stylus Photo 925 InkJet Printer
Epson 300 will not grab paper. Seems to sound
Give it a good check to be sure the belt drive or other rotating parts are not broken or clogged by dirt.
Oct 25, 2009 | Epson Stylus Photo R320 InkJet Printer
When I turn on my printer it makes a whining sound the plastic orange strip turns and the print cartridge holder moves a little and stops. I get "general error" message and printer won't due anything
Hello, dreadhead68
Aug 12, 2009 | Epson Stylus Photo 925 InkJet Printer
My printer is only printing half of the page
half page? just half top page (top-bottom), or left and right. If just left half page, set page setup as actually paper wide that inserted. because, if actually paper wide is smaller than page setup, some epson printer jsut print half. before starting printing, the paper sensor measure paper wide first.
Jun 08, 2009 | Epson Stylus Photo 925 InkJet Printer
Need replacement waste ink pad
Hi...
so bye bye waste pad... can't find any replacements but this is my recommendation for you a waste tank... It's what I did on my 2 Epson Printers... Click the link to get the idea...
waste tank
Or you can use some tissue papers to replace what was thrown away.
Happy Fixya...
Feb 28, 2009 | Epson Stylus Photo 925 InkJet Printer
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
General error - see your printer Documentation for information about clearing the error.
I solved the problem .. during the ignition printer I inserted a sheet of paper in the printer (side cartridge) while the rollers running. the printer has expelled the sheet and the problem is solved
Apr 09, 2008 | Epson Stylus Photo 925 InkJet Printer
ERROR SAYS PAPER JAM
Its already a hardware issue. go to support.epson.com and look for a service center
Feb 01, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus Photo 925 InkJet Printer Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
