Question about Texas Instruments BA-II Plus Calculator
How do you punch exponents into the calculator? what is the order?
I have an equation that is (80/(1.09)18) and 18 is the power of 18
  • 6 Answers
SOURCE: How to use negative exponents on a calculator?
your calculator will never allow you to enter a negative exponent. so heres what you do.Any negative exponent of a number can be reversed and turned into a fraction for example 4^-1=1/4 or 8^-2=2/8=0.25. Hope this helps.
Posted on Sep 21, 2009
SOURCE: exponent key on the TI-36x Calculator
On the TI-36X there is no rooftop key, there is a yx key. This key is two keys below the on button. To use it, put the number in, press the yx key, put the exponent in, press the equal button.
Posted on Feb 19, 2010
  • 102366 Answers
SOURCE: Hi, I am trying to do a college algebra problem
1 . 0 1 5 y^x 1 8 =
Posted on Apr 08, 2010
  • 102366 Answers
SOURCE: exponents
Press 1 . 0 2 3 EE 3 0
Posted on Apr 19, 2010
  • 7993 Answers
SOURCE: the calculator doesnt graph two equation on the
The Transfrm application for dynamic geometry is probably active in memory. You must purge it from RAM
  1. Press APPS
  2. Scroll Up or Down (Up is faster) to find Transfm.
  3. Select it and press ENTER
  4. Press the number corresponding to the option Uninstall.
  5. Once the APP is kicked out of memory you will be able to draw multiple functions.
Posted on May 15, 2010
How to solve an equation with negative exponent
You probably want to calculate the numerical value of some mathematical expression with numbers raised to negative exponents.
Just enter the expression as you would with positive exponents Except that before entering the value of an exponent press the change sign key, marked (-), or +/- or (+/-). Do not confuse the change sign with the usual minus sign, which is usually displayed bigger then the change sign. Make sure that the (-) is displayed before the value of the exponent. Use parentheses if necessary.
Feb 14, 2014 | Texas Instruments TI-30X Calculator
How to add using scientific notation on a ti-30xs
Try pressing
2 [x10^n] 9 + 4 [x10^n] 3 =
[x10^n] is the button just below the [data] button (three buttons above the 8 button).
Jun 12, 2012 | Texas Instruments TI-30XA Calculator
Just got a SHARP EL-531X, it won't do simple calculations with scientific notation, It keep saying
To enter the power of 10 with exponent use the Exp key followed by the exponent. If the exponent is negative, you must use the negation key (-) not the - key (for subtraction).
When you press the Exp key you do not type in the 10.
Mar 10, 2012 | Sharp Office Equipment & Supplies
Im trying to graph a parametric equation and whenever the equation has an exponent/power in it the calculator says Syn error so i know how to graph x=2 cos T, y=2 sin T and similar equations without a...
To enter powers of trigonometric functions you must enclose the functions in parentheses and then apply the exponent to the whole. For example X1t =(sin T)^3 , Y1t=(cos T)^3 will give you a shape similar to a rhombus with concave sides. The symbol ^syands for the operation of raising to a power. The key is the one with the caret symbol ^ , and it is wedged between the xsqure and EXIT keys (third row of keys).
As regards the cotangent, use the equivalent definition cot(X)=1/tan(X).
Jul 26, 2011 | Casio FX-9750GPlus Calculator
825 - (659 - (410 - 360) x 684)= ?
This is a classic use of the old PEMDAS rule. The order of operation goes by Parenthesis, Exponents, Multiplication/Division, Addition/Subtration. Take it step by step to avoid getting mixed up.
The first operation done is (410-360) which = 50. New Equation: 825 - (659 - 50 x 684) = ? The second operation done is 50 * 684 which = 34200 New Equation: 825 - (659 - 34200) = ? The third operation done is 659 - 34200 which = -33541 New Equation: 825 - (-33541) = 825 + 33541 = ? it becomes +33541 because subtracting a negative is the same as adding the positive. The final operation done is 825 + 33541 which = 34366 Your Final Solution Is:
825 - (659 - (410 - 360) * 684) = 34366
May 07, 2011 | Texas Instruments TI-83 Plus Calculator
How would you do negative exponents for scientific notation? example: (6.0 x 10^6)(2.0 x 10^4), I am required to use the EE button for my exponents since it's a scientific notation equation but I do not...
Use the (-) key for negative numbers (not just exponents) instead of the - key. The - is to subtract one value from another, (-) is to input a negative value.
Sep 09, 2010 | Texas Instruments TI-30XA Calculator
How do you make the calculator ti 30xa convert
I have a few questions and then I should be able to help you. In the equation you want to solve there is a letter g. Is this supposed to be there? Does this represent units such as grams? If this is the only units in this equation the answer will be mass not volume. Lets ignore the units and just punch in the numbers. Assuming the equation you want to solve is 3.70/2.50 x 10^-6. The buttons you need to push are 3.7/2.5 EE 6 [+/-] =. The EE button is the exponent button and the [+/-] button is the change sign button, located just below the 3. The change sign button changes the sign of the proceeding character, in this case it changes the 6 into a -6. This calculator will calculate the exponents before it does the multiplication or division so you don't need to use any parentheses for this equation. I hope this helps you out.
Jan 23, 2010 | Texas Instruments TI-30XA Calculator
Anything I type in I get A number with an exponent!
that must be because you calculator is in scientific/eng mode. press [MODE], then select normal.
May 07, 2009 | Texas Instruments TI-83 Plus Calculator
Exponent change
If you use the replay, left arrow till cursor arrives at the 0 in 10, and press 0 to insert another one. Press [EXE] or [ENTER] to get the new result.
Hope it helps.
Mar 26, 2009 | Sharp EL-531VB Calculator
Calculator
6.02 X 10y*23
y* is y raise to X
Nov 01, 2007 | Texas Instruments TI-30XA Calculator
Texas Instruments BA-II Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
